Sync3 Updater worked perfectly on an APIM with 3.4.19200 to 3.4.20196. Awesome job!
tried the usb music stick in my truck and had one only forward or backward song movement with the steering wheel, sync screen and tuning knob toggles… had one only backward skip, but had two forward song skips with the media control buttons…
hope that helped
Thank you, this is consistent with my findings. What version of Sync was originally on the 2018 F150?
To fix my issue, I reinstalled a fresh copy of Windows 10 and that worked fine. Same USB stick (sandisk 64gb).
Hello.
Sorry for my english but it’s not good.
Can it write for me step by step how to use SYN3 Updater ?
I have a Ford Escape 2018. with sync3 63GB memory.
I have 3.4_19101 and F8 maps loaded.
What and where should I mark in SYN3 Updater so that everything is fine.
Should I provide the version I have in the first window? marked on the photo.
In the second “Version” picture, what I want or what I have?
Can anyone take pictures of how to set
- I have version 3.4_19101 F8 and I want 3.4_19101 F9.
- I have version 3.4_19101 F8 and I want 3.4_20196 F9
Thank you in advance for your help.
https://cyanlabs.net/applications/syn3-updater/ click documentation down the left side.
I’m reading this right now. Can you confirm that if I do like in the picture it will be ok?
I have version 3.4_19101 F8.
I want to have 3.4_19101 with F9, I have to mark it as in the picture?
Yes that is fine.
OK, thank you very much.
If I want to change it to 3.4_20196 F9, I change it only in the “Version” option, the rest remain unchanged?
If you want to go from 3.4.19101 to 3.4.20196, for the “Map Version” select “keep existing maps” otherwise if you select F9 maps again it will reformat and reset your unit once more
Yes, but he is from EU from what the screenshot shows
Isn’t the EU maps newer with 20196?
There’s some merit in performing a full install again, even if he needs to downgrade…
My 2 cents
If he doesn’t have the new September 2019 maps then sure he can select the new maps package and reformat again. There seems to be very little difference between the old F9 maps and the new one so up to the user if they think it’s worth the reformat.
If I update to 3.4_20196 without maps, then when I want to upload new maps, I will have to do downgradin?
Yes unless you “force autoinstall” which will most likely not work.
Ok. Always if I have over 19200 I have to downgrade and then upload the latest maps or soft if they appear?
Updating maps is much better to do the downgrade + reformat (now all one process) than trying and failing to get the autoinstall working, it takes longer via autoinstall 1.5x-2x longer and has no progress indication and no guarantee it will work.
I have 3.4_19101 maps of F8.
I created a pendrive to upload F9 and stay on 3.4_19101.
Is such a flash drive good?
CYANLABS - SYN3 UPDATER - V1.0.0.2
Version: 3.4.19101
Mode: reformat
USB DETAILS
Model: Kingston DataTraveler 3.0 USB Device (Size: 28,8GB)
ENH_DAB=1U5T-14G658-AD_1544799507000.TAR.GZ
GRACENOTES=4U5T-14G423-AA_123694.tar.gz
APPS=5U5T-14G381-AP_1555085337000.TAR.GZ
VOICE=5U5T-14G391-AK_1571068712000.TAR.GZ
MAP=1U5T-14G421-BAG_1591726015000.TAR.GZ
MAP=1U5T-14G421-BBG_1591726765000.TAR.GZ
MAP=1U5T-14G421-BCG_1591726913000.TAR.GZ
MAP=1U5T-14G421-BDG_1591727234000.TAR.GZ
MAP=1U5T-14G421-BEG_1591727457000.TAR.GZ
MAP=1U5T-14G421-BFG_1591727753000.TAR.GZ
MAP=1U5T-14G421-BGG_1591728190000.TAR.GZ
MAP=1U5T-14G421-BHG_1591728542000.TAR.GZ
MAP=1U5T-14G421-BJG_1591729086000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAE_1580861780000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBE_1580861854000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCE_1580861916000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDE_1580862152000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BJ_1591719092000.TAR.GZ
; CyanLabs Syn3Updater - reformat Mode - Sync 3.4.19101 EU
SYNCMYRIDE FILES (19)
1U5T-14G658-AD_1544799507000.TAR.GZ (61,8MB)
4U5T-14G423-AA_123694.tar.gz (709,2MB)
5U5T-14G381-AP_1555085337000.TAR.GZ (891,2MB)
5U5T-14G391-AK_1571068712000.TAR.GZ (1,5GB)
1U5T-14G421-BAG_1591726015000.TAR.GZ (2,2GB)
1U5T-14G421-BBG_1591726765000.TAR.GZ (451,8MB)
1U5T-14G421-BCG_1591726913000.TAR.GZ (1,6GB)
1U5T-14G421-BDG_1591727234000.TAR.GZ (1GB)
1U5T-14G421-BEG_1591727457000.TAR.GZ (1,6GB)
1U5T-14G421-BFG_1591727753000.TAR.GZ (2,3GB)
1U5T-14G421-BGG_1591728190000.TAR.GZ (1,8GB)
1U5T-14G421-BHG_1591728542000.TAR.GZ (2,4GB)
1U5T-14G421-BJG_1591729086000.TAR.GZ (22MB)
4U5T-14G422-BAE_1580861780000.TAR.GZ (2,2GB)
4U5T-14G422-BBE_1580861854000.TAR.GZ (2GB)
4U5T-14G422-BCE_1580861916000.TAR.GZ (1,5GB)
4U5T-14G422-BDE_1580862152000.TAR.GZ (1,9GB)
1U5T-14G424-BJ_1591719092000.TAR.GZ (1,7KB)
1u5t-14g386-cb.tar.gz (8,5MB)
INFO: Starting process (Sync 3.4.19101 - EU - F9 (2019) - EU (09/2020))
INFO: Downloading 1u5t-14g386-cb.tar.gz
INFO: Downloading 1U5T-14G658-AD_1544799507000.TAR.GZ
INFO: Downloading 4U5T-14G423-AA_123694.tar.gz
INFO: Downloading 5U5T-14G381-AP_1555085337000.TAR.GZ
INFO: Downloading 5U5T-14G391-AK_1571068712000.TAR.GZ
INFO: Downloading 1U5T-14G421-BAG_1591726015000.TAR.GZ
INFO: Downloading 1U5T-14G421-BBG_1591726765000.TAR.GZ
INFO: Downloading 1U5T-14G421-BCG_1591726913000.TAR.GZ
INFO: Downloading 1U5T-14G421-BDG_1591727234000.TAR.GZ
INFO: Downloading 1U5T-14G421-BEG_1591727457000.TAR.GZ
INFO: Downloading 1U5T-14G421-BFG_1591727753000.TAR.GZ
INFO: Downloading 1U5T-14G421-BGG_1591728190000.TAR.GZ
INFO: Downloading 1U5T-14G421-BHG_1591728542000.TAR.GZ
INFO: Downloading 1U5T-14G421-BJG_1591729086000.TAR.GZ
INFO: Downloading 4U5T-14G422-BAE_1580861780000.TAR.GZ
INFO: Downloading 4U5T-14G422-BBE_1580861854000.TAR.GZ
INFO: Downloading 4U5T-14G422-BCE_1580861916000.TAR.GZ
INFO: Downloading 4U5T-14G422-BDE_1580862152000.TAR.GZ
INFO: Downloading 1U5T-14G424-BJ_1591719092000.TAR.GZ
INFO: Verifying 1U5T-14G658-AD_1544799507000.TAR.GZ
INFO: Successfully Verified 1U5T-14G658-AD_1544799507000.TAR.GZ
INFO: Verifying 4U5T-14G423-AA_123694.tar.gz
INFO: Successfully Verified 4U5T-14G423-AA_123694.tar.gz
INFO: Verifying 5U5T-14G381-AP_1555085337000.TAR.GZ
INFO: Successfully Verified 5U5T-14G381-AP_1555085337000.TAR.GZ
INFO: Verifying 5U5T-14G391-AK_1571068712000.TAR.GZ
INFO: Successfully Verified 5U5T-14G391-AK_1571068712000.TAR.GZ
INFO: Verifying 1U5T-14G421-BAG_1591726015000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BAG_1591726015000.TAR.GZ
INFO: Verifying 1U5T-14G421-BBG_1591726765000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BBG_1591726765000.TAR.GZ
INFO: Verifying 1U5T-14G421-BCG_1591726913000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BCG_1591726913000.TAR.GZ
INFO: Verifying 1U5T-14G421-BDG_1591727234000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BDG_1591727234000.TAR.GZ
INFO: Verifying 1U5T-14G421-BEG_1591727457000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BEG_1591727457000.TAR.GZ
INFO: Verifying 1U5T-14G421-BFG_1591727753000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BFG_1591727753000.TAR.GZ
INFO: Verifying 1U5T-14G421-BGG_1591728190000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BGG_1591728190000.TAR.GZ
INFO: Verifying 1U5T-14G421-BHG_1591728542000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BHG_1591728542000.TAR.GZ
INFO: Verifying 1U5T-14G421-BJG_1591729086000.TAR.GZ
INFO: Successfully Verified 1U5T-14G421-BJG_1591729086000.TAR.GZ
INFO: Verifying 4U5T-14G422-BAE_1580861780000.TAR.GZ
INFO: Successfully Verified 4U5T-14G422-BAE_1580861780000.TAR.GZ
INFO: Verifying 4U5T-14G422-BBE_1580861854000.TAR.GZ
INFO: Successfully Verified 4U5T-14G422-BBE_1580861854000.TAR.GZ
INFO: Verifying 4U5T-14G422-BCE_1580861916000.TAR.GZ
INFO: Successfully Verified 4U5T-14G422-BCE_1580861916000.TAR.GZ
INFO: Verifying 4U5T-14G422-BDE_1580862152000.TAR.GZ
INFO: Successfully Verified 4U5T-14G422-BDE_1580862152000.TAR.GZ
INFO: Verifying 1U5T-14G424-BJ_1591719092000.TAR.GZ
INFO: Successfully Verified 1U5T-14G424-BJ_1591719092000.TAR.GZ
INFO: Creating reformat reformat.lst
INFO: Creating reformat autoinstall.lst
INFO: Copying 1U5T-14G658-AD_1544799507000.TAR.GZ
INFO: Copying 4U5T-14G423-AA_123694.tar.gz
INFO: Copying 5U5T-14G381-AP_1555085337000.TAR.GZ
INFO: Copying 5U5T-14G391-AK_1571068712000.TAR.GZ
INFO: Copying 1U5T-14G421-BAG_1591726015000.TAR.GZ
INFO: Copying 1U5T-14G421-BBG_1591726765000.TAR.GZ
INFO: Copying 1U5T-14G421-BCG_1591726913000.TAR.GZ
INFO: Copying 1U5T-14G421-BDG_1591727234000.TAR.GZ
INFO: Copying 1U5T-14G421-BEG_1591727457000.TAR.GZ
INFO: Copying 1U5T-14G421-BFG_1591727753000.TAR.GZ
INFO: Copying 1U5T-14G421-BGG_1591728190000.TAR.GZ
INFO: Copying 1U5T-14G421-BHG_1591728542000.TAR.GZ
INFO: Copying 1U5T-14G421-BJG_1591729086000.TAR.GZ
INFO: Copying 4U5T-14G422-BAE_1580861780000.TAR.GZ
INFO: Copying 4U5T-14G422-BBE_1580861854000.TAR.GZ
INFO: Copying 4U5T-14G422-BCE_1580861916000.TAR.GZ
INFO: Copying 4U5T-14G422-BDE_1580862152000.TAR.GZ
INFO: Copying 1U5T-14G424-BJ_1591719092000.TAR.GZ
INFO: Copying 1u5t-14g386-cb.tar.gz
INFO: Verifying 1u5t-14g386-cb.tar.gz
INFO: Successfully Verified 1u5t-14g386-cb.tar.gz
INFO: PROCESS COMPLETE!
Yes it should be fine
Will the flash drive prepared in this way be good for updating from 3.4_19101 F8 to 3.4_20196 F9.
If something goes wrong, it’s over? Is it always possible to save Sync3 somehow?
CYANLABS - SYN3 UPDATER - V1.0.0.3
Version: 3.4.19101
Mode: reformat
USB DETAILS
APPS=5U5T-14G381-EG_1598634070000.TAR.GZ
VOICE=5U5T-14G391-AM_1598633466000.TAR.GZ
; CyanLabs Syn3Updater - reformat Mode - Sync 3.4.20196 EU
5U5T-14G381-EG_1598634070000.TAR.GZ (848,6MB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
5U5T-14G391-AM_1598633466000.TAR.GZ (1,5GB)
INFO: Starting process (Sync 3.4.20196 - EU - F9 (2019) - EU (09/2020))
INFO: Verifying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Successfully Verified 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Verifying 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Successfully Verified 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Verifying 5U5T-14G391-AM_1598633466000.TAR.GZ
INFO: Successfully Verified 5U5T-14G391-AM_1598633466000.TAR.GZ
INFO: Downloading 4U5T-14G381-AN_1552583626000.TAR.GZ
INFO: Downloading GB5T-14G386-SC_85041.tar.gz
INFO: Copying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Copying 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Copying 5U5T-14G391-AM_1598633466000.TAR.GZ
Yes it’s fine, there is no way to “save Sync” but in almost every case you can recover should something go wrong.
