Syn3Updater 2.10.3.0
The application runs fine UNTIL I insert a USB flash drive and I then get the error “INVALID NAMESPACE” and cannot link to the USB drive. However the program works fine if I remove the USB and select a directory.
I have tried various USB drives and ports but without any success.
Any idea what it causing this error?
you don’t have the management objects that are standard with windows, it’s unclear why you don’t but you are the second person to have this issue
mofcomp.exe C:\windows\system32\wbem\win32_encryptablevolume.mof
Thankyou for the feedback. I am sure its down to a corruption in the WMI but I am unsure how to fix it.
I will continue with the “Select a Folder” option until I can resolve it.
type the command i said above in to cmd
Thankyou. Tried the link and now all is working as it should.
You are my hero !
Great :slight_smile: no idea why some (currently atleast 2) have this issue.
