Sync 3.0 17276 cant update
Hi, I have Sync 3.0 17276 and can’t update. i try newest update and another older version(3.4.22251 and 3.3.19052),both region USA, EU, etc. All the time i have popup “Installation paused
The USB storage device has been changed or removed. Installation will resume when the device is re-inserted.”
Try another usb stick, try disconnect battery, master reset.
No DTCs in APIM
Old SYNC Version: 3.0.17276
New SYNC Version: 3.4.22251
Installation paused
Syn3 Updater Version: 2.11.8
Version: 3.0.17276
Region:
Install Mode: Auto-Wykrywanie (reformat)
My20 Protection Enabled: WYŁĄCZONE / Nie dla MY20
VOICE=4U5T-14G391-AJ_1552513063000.TAR.GZ
GRACENOTES=4U5T-14G423-AA_123694.tar.gz
ENH_DAB=1U5T-14G658-AD_1544799507000.TAR.GZ
; CyanLabs Syn3Updater 2.11.8.0 Stable - reformat  Mode - Sync 3.3.19052 EU
FILES (5)
1u5t-14g386-cb.tar.gz (8,5MB)
4U5T-14G391-AJ_1552513063000.TAR.GZ (1,5GB)
4U5T-14G423-AA_123694.tar.gz (709,2MB)
1U5T-14G658-AD_1544799507000.TAR.GZ (61,8MB)
[29.01.2023 15:54:15] Selected Region: EU - Release: Sync 3.3.19052 - Map Version: APIM BEZ NAWIGACJI
[29.01.2023 15:54:15] Install Mode: Auto-Wykrywanie (reformat) Forced: False
[29.01.2023 15:54:15] MY20 Protection: WYŁĄCZONE / Nie dla MY20
[29.01.2023 15:54:15] Formatting USB drive
[29.01.2023 15:54:15] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[29.01.2023 15:54:24] Checking Existing File: 1u5t-14g386-cb.tar.gz
[29.01.2023 15:54:24] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[29.01.2023 15:54:24] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.01.2023 15:54:26] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[29.01.2023 15:54:26] Checking Existing File: 4U5T-14G391-AJ_1552513063000.TAR.GZ
[29.01.2023 15:54:34] Validated: 4U5T-14G391-AJ_1552513063000.TAR.GZ (Skipping Download)
[29.01.2023 15:54:34] Checking Existing File: 4U5T-14G423-AA_123694.tar.gz
[29.01.2023 15:54:37] Validated: 4U5T-14G423-AA_123694.tar.gz (Skipping Download)
[29.01.2023 15:54:37] Checking Existing File: 1U5T-14G658-AD_1544799507000.TAR.GZ
[29.01.2023 15:54:38] Validated: 1U5T-14G658-AD_1544799507000.TAR.GZ (Skipping Download)
[29.01.2023 15:54:38] Preparing USB drive
[29.01.2023 15:54:38] Checking Existing File: 1u5t-14g386-cb.tar.gz
[29.01.2023 15:54:38] Copying: 1u5t-14g386-cb.tar.gz
[29.01.2023 15:54:38] Validating: 1u5t-14g386-cb.tar.gz
[29.01.2023 15:54:38] Copied: 1u5t-14g386-cb.tar.gz
[29.01.2023 15:54:38] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.01.2023 15:54:38] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.01.2023 15:55:24] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.01.2023 15:55:26] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[29.01.2023 15:55:26] Checking Existing File: 4U5T-14G391-AJ_1552513063000.TAR.GZ
[29.01.2023 15:55:26] Copying: 4U5T-14G391-AJ_1552513063000.TAR.GZ
[29.01.2023 15:57:56] Validating: 4U5T-14G391-AJ_1552513063000.TAR.GZ
[29.01.2023 15:58:00] Copied: 4U5T-14G391-AJ_1552513063000.TAR.GZ
[29.01.2023 15:58:00] Checking Existing File: 4U5T-14G423-AA_123694.tar.gz
[29.01.2023 15:58:00] Copying: 4U5T-14G423-AA_123694.tar.gz
[29.01.2023 15:59:09] Validating: 4U5T-14G423-AA_123694.tar.gz
[29.01.2023 15:59:11] Copied: 4U5T-14G423-AA_123694.tar.gz
[29.01.2023 15:59:11] Checking Existing File: 1U5T-14G658-AD_1544799507000.TAR.GZ
[29.01.2023 15:59:11] Copying: 1U5T-14G658-AD_1544799507000.TAR.GZ
[29.01.2023 15:59:17] Validating: 1U5T-14G658-AD_1544799507000.TAR.GZ
[29.01.2023 15:59:17] Copied: 1U5T-14G658-AD_1544799507000.TAR.GZ
[29.01.2023 15:59:17] Generating reformat.lst
[29.01.2023 15:59:18] Generating autoinstall.lst
[29.01.2023 15:59:18] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
If you search the forums for “installation paused”, you will find A LOT of threads with your exact case, even with the same build number you have.
None of them were resolved, they had to change the APIM.
So perform the search, read those threads for all the suggestions they tried and try them yourself.
If none of those work (which sadly is expected), you will have to change the APIM, since the conclusion was that there was something wrong with the APIM (hardware failure).
In those cases, they could not even run an interrogator log.
Also use a higher end USB stick and not a generic one.
