Sync 3.0.20204 with 2020 NA2.20 Map Installation.
Read this document fully before starting any actions. It is your responsibility to follow the instructions as outlined below.
NOTE: This procedure requires a specific license file for your vehicle generated by Ford for NA 2.20 maps due to the ESN license file lock. You must source a valid license for your vehicle thru Sync Navigation - Sync3 Map Updates.
NOTES:
- This process does not use the reformat tool and is safe for MY20+ Service Replacement APIM’s.
- This tutorial is targeted for Ford and Lincoln vehicles originally equipped with a 32GB NAV APIM with Sync 3.0 and factory navigation. The maps are not compatible with Sync 2 and 3.2+ versions. DO NOT attempt to place maps on a NON-NAV Sync APIM.
- It is advised that you run the APIM Interrogator Utility to determine the specifics of your Sync unit installed in your vehicle. This can be done thru the Syn3 Updater in the Tools section or manually following the tutorial, Tutorial: APIM Interrogator Utility - CyanLabs.
- It is recommended using a USB 3.0 drive with at least 32 GB of storage.
- This installation consists of multiple reboots, in which the vehicle ignition must remain on throughout the process. DO NOT REMOVE THE USB UNTIL THE ENTIRE PROCESS HAS COMPLETED.
- A ‘Master Reset’ will be performed at the end of this procedure.
Overview
If you have updated your Sync 3.0 NA NAV APIM to Sync 3.0.20204 (or recent Sync 3.0 version) with newer maps and you are experiencing hesitation and lag in the unit response, it is likely due to an incomplete or corrupted nav installation. This happens when the map installation is not performed correctly and leaves a mixture of old and newer files on the APIM. The old and new map files are not compatible and will cause the incomplete loading of the maps on boot, sometimes causing the APIM to constantly reboot. This issue can be corrected using the procedures in this tutorial.
This tutorial covers the installation of Sync 3.0.20204 with the associated Sync Voice and Gracenote files and the installation of NA 2.20 maps and nav voice files. These installations will be performed in two separate procedures, the Sync Apps installation, and the NA 2.20 Nav Package installation.
NOTE: It is required to perform the Sync Apps installation first, as the newer nav package is not compatible with some older Sync versions.
Sync 3.0.20204 NA Apps Package Installation
Sync Apps Package USB Preparation Instructions
- Download the required files. The files can be downloaded from the Software Database - CyanLabs.
Sync App: JR3T-14G381-AX 407Mb Sync3 v3.0.20204
Sync System Voice: JR3T-14G391-CE 381Mb Sync3 v3.2.19056-Pre18.5
Gracenote: JR3T-14G423-CB 724Mb Sync3 v3.0.17024 1.1.1.1139 (NA-0010)
Interrogator Utility: GB5T-14G386-AC 43Kb Interrogator logging utility.
NOTE: Gracenote is optional, but the entry in the autoinstall.lst file (Item3 and Open3) must be removed if Gracenote will not be installed. - Format a 32GB USB for ExFAT/MBR using Windows. Place the files on the USB drive.
a. Open the Downloads folder on the computer used to download the files.
b. Select the files and transfer them to the USB under the SyncMyRide folder.
c. In the root of the USB, place file DONTINDX.MSA. This is a blank text file with an MSA extension to prevent indexing by the Sync system. This can be used from previous installations if you have one. This file is optional. - Create the autoinstall.lst file.
a. In a plain text editor, like notepad, create a file named “autoinstall.lst”. Make sure there is not a .TXT extension, this must be a .LST extension.
b. Copy and paste (as plain text) the following text into the autoinstall.lst file and save the file.
; SYNC3 Consumer Assembly Upgrade — Only for Nav/NA assemblies.
[SYNCGen3.0_3.0.20204_PRODUCT]
Item1 = JR3T-14G381-AX_1599788486000.TAR.GZ
Open1 = SyncMyRide\JR3T-14G381-AX_1599788486000.TAR.GZ
Item2 = JR3T-14G391-CE_1557247163000.TAR.GZ
Open2 = SyncMyRide\JR3T-14G391-CE_1557247163000.TAR.GZ
Item3 = JR3T-14G423-CB_1548263512000.TAR.GZ
Open3 = SyncMyRide\JR3T-14G423-CB_1548263512000.TAR.GZ
Item1 = GB5T-14G386-AC
Open1 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
- Copy the file to the root of the USB.
- The file structure for the USB should now be like this:
USB (root)
autoinstall.lst
DONTINDX. MSA (optional)
SyncMyRide (folder)JR3T-14G381-AX_1599788486000.TAR.GZ
Sync Apps Package Installation Instructions
- NOTE: This installation consists of at least 1 reboot, in which the vehicle ignition must remain on throughout the process. DO NOT REMOVE THE USB UNTIL THE ENTIRE PROCESS HAS COMPLETED.
- Insert the USB in the vehicle, the “Updating Software” message will appear. Once the software has been installed, the system will display a Key Cycle or Reboot message. DO NOT interfere with the process, the APIM will reboot on its own and continue the installation. Be patient and wait.
- Once the first reboot has completed, the “Updating Software” message will appear again. This is running the Interrogator Utility, which should be quick. Once this is completed, the system will display an “Installation Complete” message. It is safe to remove the USB.
NA 2.20 NAV Package Installation
NAV Package USB Preparation Instructions
NA 2.20 Map: JR3T-14G421-CF 9.2Gb Sync3 v3.2.20345-Pre18.5 NA.2.20
Nav Voice: JR3T-14G422-CH 2.6Gb Sync3 v3.2.20346-Pre18.5 NA 2.20
Map License: JR3T-14G424-CF License file for JR3T-14G421-CF NA 2.20
Interrogator Utility: GB5T-14G386-AC 43Kb Interrogator logging utility. - Format a 32GB USB for ExFAT/MBR using Windows. Place the files on the USB drive.
; SYNC3 Consumer Application Upgrade - Only for Nav/NA assemblies.
[SYNCGen3.0_3.2.20345_PRODUCT]
Item1 = JR3T-14G424-CF_1626994374000.TAR.GZ
Open1 = SyncMyRide\JR3T-14G424-CF_1626994374000.TAR.GZ
Item2 = JR3T-14G421-CF_1626995795000.TAR.GZ
Open2 = SyncMyRide\JR3T-14G421-CF_1626995795000.TAR.GZ
[SYNCGen3.0_3.2.20345]
Item1 = JR3T-14G422-CH_1626995976000.TAR.GZ
Open1 = SyncMyRide\JR3T-14G422-CH_1626995976000.TAR.GZ
Item1 = GB5T-14G386-AC_1587495565000.TAR.GZ
USB (root)
autoinstall.lst
DONTINDX.MSA (optional)
SyncMyRide (folder)JR3T-14G424-CF_1626994374000.TAR.GZ
NAV Package Installation Instructions
- NOTE: This installation consists of at least 2 reboots, in which the vehicle ignition must remain on throughout the process. DO NOT REMOVE THE USB UNTIL THE ENTIRE PROCESS HAS COMPLETED.
- Insert the USB in the vehicle, the “Updating Software” message will appear. Once the software has been installed, the system will display a Key Cycle or Reboot message. This is the beginning of the installation of the Map and Nav Voice software. DO NOT interfere with the process, the APIM will reboot on its own and continue the installation.
- Once the first reboot has completed, the “Updating Software” message will appear again. This is continuing the installation of the Map and Nav Voice software. Once the software has been installed, the system will display a Key Cycle or Reboot message. DO NOT interfere with the process, the APIM will reboot on its own and continue the installation.
- Once the second reboot has completed, the “Updating Software” message will appear again. This is running the Interrogator Utility, which should be quick. Once this is completed, the system will display an “Installation Complete” message. It is safe to remove the USB.
Master Reset Required
Once the Sync system seems stable and the maps are loaded, perform a ‘Master Reset’. This is not optional. Once the reset is finished and the system has rebooted, you can now re-pair your phones and make other adjustments.
