Nick19
18 October 2021 02:44
1
Read some others saying they had issues with changing their ambient lighting on 17 and older F150s. This is a concern for me and I want some reassurance it will work properly. It is not worth me upgrading if I lose this feature. Also, will it still be compatible with front camera and 360* camera? Also, heated steering wheel option?
Thank you,
F150Chief
(F150Chief)
18 October 2021 02:48
2
This has been an exception, not the norm. It has mostly to do with folks who have changed the factory asbuilt.
It is compatible, no issues.
Nick19
18 October 2021 03:16
3
Thanks. What does factory asbuilt mean? If for some reason the ambient lighting does not work, am I able to revert back existing version?
F150Chief
(F150Chief)
18 October 2021 04:16
4
The asbuilt is the APIM or Sync module programming info, different from software or firmware. If it does get affected it can be fixed. You will need a program called FORScan (free) and a OBDII adapter. The recommended ones are $50. (OBDLink EX)
Download FORScan
CyanLabs
(CyanLabs)
18 October 2021 09:17
5
No, as mentioned in the guide/documentation
Nick19
22 October 2021 13:14
6
Thanks. One last question regarding the ambient lighting… I just want to be clear it still gives me option to change the colors, not just change the brightness? I know on newer models with 3.4 it gives you Ambient Lighting options, but its just to change the brightness.
F150Chief
(F150Chief)
22 October 2021 18:20
7
I have a 2015 F150 Platinum that I upgraded from Sync 2 to Sync 3, added a TCU, etc. It has the ambient lighting with illumination and color changes, now set to Lincoln colors. The ambient lighting functions are controlled thru the BCM and the lighting modules themselves, the APIM (and Sync) are just a control surface (HMI). Although there are settings in the APIM for ambient lighting, this is nothing but a control palette for the system.
The only place that I have read of any issues with ambient lighting due to software updates was by folks who have also made other changes to their vehicles using FORScan or other software. This probably ended up in incompatible asbuilt data with conflicts.
bill32399
(bill32399)
22 October 2021 19:27
8
Most Fords, If not all, now use the BCM to supply the Ambient lighting signals now. This status is also sent through the Medium Speed CanBus so the Door modules can pick it up also. Prior to that and until 2019 some models still used the HVAC module to supply the Ambient lighting signals. Mostly the 2011-15 Explorer and 2013-2019 Flex. Up to 2012 many Fords used a dedicated module with a switch for the AL. These were not tied to the Can bus system and could not be changed through the APIM.
Nick19
22 October 2021 20:11
9
So in English, what does that mean for me? lol. All should be good?
F150Chief
(F150Chief)
22 October 2021 20:14
10
Yes, based on experience and previous installations, all should be fine…
Nick19
22 October 2021 21:06
11
I received this error… please help…
F150Chief
(F150Chief)
22 October 2021 21:12
12
Can you post the installation log? On the root of the USB…
Looks like an issue with a NAV-Voice file.
PKG_ERR03 – Error is PKG_UNTAR_FAILURE
Nick19
22 October 2021 21:17
13
Yes I will… I pulled the USB out and went to try again. If it don’t work I’ll pull it out and put on PC. Hopefully this won’t break my sync
SaNdMaN
(SaNdMaN)
22 October 2021 21:19
14
You do not need the USB, the log is on a folder in your computer, check syn3updater, you can browse it from the app.
Also, you do have NAV right?.
F150Chief
(F150Chief)
15
It will be fine, just need to figure out what is going on…like NAV.
bill32399
(bill32399)
22 October 2021 21:30
16
He says he has a 2017 King Ranch and those came Standard with the Nav package.
SaNdMaN
(SaNdMaN)
22 October 2021 21:32
17
Thank you, I’m from Argentina so I do not know those models!.
If that’s the case and the APIM has enough storage, then the issue is with the USB itself.
Nick19
18
Yes, i have NAV. Im in US as well. Log below if this is what you are looking for…
Version: 3.0.20204
FileSystem: FAT32
APPS=5U5T-14G381-ET_1627475308000.TAR.GZ
VOICE=5U5T-14G391-CP_1626959995000.TAR.GZ
VOICE_NAV=4U5T-14G422-CCH_1615429127000.TAR.GZ
VOICE_NAV=4U5T-14G422-CBH_1615429039000.TAR.GZ
VOICE_NAV=4U5T-14G422-CAH_1615428946000.TAR.GZ
MAP=4U5T-14G421-CJD_1615428865000.TAR.GZ
MAP=4U5T-14G421-CHD_1615428793000.TAR.GZ
MAP=4U5T-14G421-CGD_1615428721000.TAR.GZ
MAP=4U5T-14G421-CFD_1615428639000.TAR.GZ
MAP=4U5T-14G421-CED_1615428554000.TAR.GZ
MAP=4U5T-14G421-CDD_1615428467000.TAR.GZ
MAP=4U5T-14G421-CCD_1615428361000.TAR.GZ
MAP=4U5T-14G421-CBD_1615428261000.TAR.GZ
MAP=4U5T-14G421-CAD_1615428059000.TAR.GZ
MAP_LICENSE=4U5T-14G424-CD_1616778089000.TAR.GZ
; CyanLabs Syn3Updater 2.10.6.0 Stable - reformat Mode - Sync 3.4.21194 NA
FILES (17)
5U5T-14G381-ET_1627475308000.TAR.GZ (847.2MB)
4U5T-14G422-CCH_1615429127000.TAR.GZ (549.6MB)
4U5T-14G422-CBH_1615429039000.TAR.GZ (772.4MB)
4U5T-14G422-CAH_1615428946000.TAR.GZ (1.3GB)
4U5T-14G421-CJD_1615428865000.TAR.GZ (657.9MB)
4U5T-14G421-CHD_1615428793000.TAR.GZ (989.6MB)
4U5T-14G421-CGD_1615428721000.TAR.GZ (1.1GB)
4U5T-14G421-CFD_1615428639000.TAR.GZ (1GB)
4U5T-14G421-CED_1615428554000.TAR.GZ (1GB)
4U5T-14G421-CDD_1615428467000.TAR.GZ (1.2GB)
4U5T-14G421-CCD_1615428361000.TAR.GZ (1GB)
4U5T-14G421-CBD_1615428261000.TAR.GZ (1.1GB)
4U5T-14G421-CAD_1615428059000.TAR.GZ (1.1GB)
4U5T-14G424-CD_1616778089000.TAR.GZ (1.7KB)
Summary
[10/15/2021 10:17:17 PM] Selected Region: NA - Release: Sync 3.4.21194 - Map Version: 2.20 (2020) - NA
[10/15/2021 10:17:17 PM] Install Mode: Auto-Detect (reformat) Forced: False
[10/15/2021 10:17:17 PM] MY20 Protection: Auto-Detect
[10/15/2021 10:17:17 PM] Formatting USB drive
[10/15/2021 10:17:17 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[10/15/2021 10:17:26 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10/15/2021 10:17:26 PM] Downloading: 1u5t-14g386-cb.tar.gz
[10/15/2021 10:17:32 PM] Validating: 1u5t-14g386-cb.tar.gz
[10/15/2021 10:17:33 PM] Downloaded: 1u5t-14g386-cb.tar.gz
[10/15/2021 10:17:33 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 10:17:33 PM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 10:21:37 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 10:21:39 PM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 10:21:39 PM] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 10:21:39 PM] Downloading: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 10:26:39 PM] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 10:26:42 PM] Downloaded: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 10:26:42 PM] Checking Existing File: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 10:26:42 PM] Downloading: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 10:28:58 PM] Validating: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 10:28:59 PM] Downloaded: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 10:28:59 PM] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 10:28:59 PM] Downloading: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 10:32:18 PM] Validating: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 10:32:20 PM] Downloaded: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 10:32:20 PM] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 10:32:20 PM] Downloading: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 10:36:43 PM] Validating: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 10:36:46 PM] Downloaded: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 10:36:46 PM] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 10:36:46 PM] Downloading: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 10:44:23 PM] Validating: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 10:44:27 PM] Downloaded: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 10:44:27 PM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/15/2021 10:44:27 PM] Downloading: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/15/2021 10:48:33 PM] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/15/2021 10:48:35 PM] Downloaded: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/15/2021 10:48:35 PM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/15/2021 10:48:35 PM] Downloading: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/15/2021 10:54:22 PM] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/15/2021 10:54:25 PM] Downloaded: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/15/2021 10:54:25 PM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/15/2021 10:54:25 PM] Downloading: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/15/2021 11:00:59 PM] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/15/2021 11:01:02 PM] Downloaded: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/15/2021 11:01:02 PM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/15/2021 11:01:02 PM] Downloading: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/15/2021 11:07:53 PM] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/15/2021 11:07:57 PM] Downloaded: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/15/2021 11:07:57 PM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/15/2021 11:07:57 PM] Downloading: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/15/2021 11:14:47 PM] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/15/2021 11:14:50 PM] Downloaded: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/15/2021 11:14:50 PM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/15/2021 11:14:50 PM] Downloading: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/15/2021 11:22:57 PM] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/15/2021 11:23:02 PM] Downloaded: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/15/2021 11:23:02 PM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/15/2021 11:23:02 PM] Downloading: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/15/2021 11:30:06 PM] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/15/2021 11:30:10 PM] Downloaded: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/15/2021 11:30:10 PM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/15/2021 11:30:10 PM] Downloading: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/15/2021 11:36:41 PM] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/15/2021 11:36:44 PM] Downloaded: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/15/2021 11:36:44 PM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/15/2021 11:36:44 PM] Downloading: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/15/2021 11:42:52 PM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/15/2021 11:42:55 PM] Downloaded: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/15/2021 11:42:55 PM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/15/2021 11:42:55 PM] Downloading: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/15/2021 11:42:56 PM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/15/2021 11:42:56 PM] Downloaded: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/15/2021 11:42:56 PM] Preparing USB drive
[10/15/2021 11:42:56 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[10/15/2021 11:42:56 PM] Copying: 1u5t-14g386-cb.tar.gz
[10/15/2021 11:42:58 PM] Validating: 1u5t-14g386-cb.tar.gz
[10/15/2021 11:42:58 PM] Copied: 1u5t-14g386-cb.tar.gz
[10/15/2021 11:42:58 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 11:42:58 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 11:44:29 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 11:44:56 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[10/15/2021 11:44:56 PM] Checking Existing File: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 11:44:56 PM] Copying: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 11:47:14 PM] Validating: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 11:47:54 PM] Copied: 5U5T-14G381-ET_1627475308000.TAR.GZ
[10/15/2021 11:47:54 PM] Checking Existing File: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 11:47:54 PM] Copying: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 11:48:59 PM] Validating: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 11:49:18 PM] Copied: 5U5T-14G391-CP_1626959995000.TAR.GZ
[10/15/2021 11:49:18 PM] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 11:49:18 PM] Copying: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 11:50:50 PM] Validating: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 11:51:17 PM] Copied: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[10/15/2021 11:51:17 PM] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 11:51:17 PM] Copying: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 11:53:28 PM] Validating: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 11:54:05 PM] Copied: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[10/15/2021 11:54:05 PM] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 11:54:05 PM] Copying: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 11:57:49 PM] Validating: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/15/2021 11:58:54 PM] Validate: 4U5T-14G422-CAH_1615428946000.TAR.GZ (Failed!, Downloading)
[10/15/2021 11:58:54 PM] Copying (Attempt #2 ): 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/16/2021 12:02:18 AM] Validating: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/16/2021 12:02:21 AM] Copied: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[10/16/2021 12:02:21 AM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/16/2021 12:02:21 AM] Copying: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/16/2021 12:04:14 AM] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/16/2021 12:04:46 AM] Copied: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[10/16/2021 12:04:46 AM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/16/2021 12:04:46 AM] Copying: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/16/2021 12:07:35 AM] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/16/2021 12:08:23 AM] Copied: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[10/16/2021 12:08:23 AM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/16/2021 12:08:23 AM] Copying: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/16/2021 12:11:33 AM] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/16/2021 12:12:27 AM] Copied: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[10/16/2021 12:12:27 AM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/16/2021 12:12:27 AM] Copying: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/16/2021 12:15:29 AM] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/16/2021 12:16:22 AM] Copied: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[10/16/2021 12:16:22 AM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/16/2021 12:16:22 AM] Copying: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/16/2021 12:19:24 AM] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/16/2021 12:20:16 AM] Copied: 4U5T-14G421-CED_1615428554000.TAR.GZ
[10/16/2021 12:20:16 AM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/16/2021 12:20:16 AM] Copying: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/16/2021 12:23:53 AM] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/16/2021 12:24:56 AM] Copied: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[10/16/2021 12:24:56 AM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/16/2021 12:24:56 AM] Copying: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/16/2021 12:27:56 AM] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/16/2021 12:28:48 AM] Copied: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[10/16/2021 12:28:48 AM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/16/2021 12:28:48 AM] Copying: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/16/2021 12:32:02 AM] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/16/2021 12:32:57 AM] Copied: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[10/16/2021 12:32:57 AM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/16/2021 12:32:57 AM] Copying: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/16/2021 12:35:57 AM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/16/2021 12:36:50 AM] Copied: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[10/16/2021 12:36:50 AM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/16/2021 12:36:50 AM] Copying: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/16/2021 12:36:50 AM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/16/2021 12:36:50 AM] Copied: 4U5T-14G424-CD_1616778089000.TAR.GZ
[10/16/2021 12:36:50 AM] Generating reformat.lst
[10/16/2021 12:36:50 AM] Generating autoinstall.lst
[10/16/2021 12:36:50 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
SaNdMaN
(SaNdMaN)
22 October 2021 21:33
19
I believe that’s not the actual brand for the USB stick.
Do you have a quality-branded one?
bill32399
(bill32399)
22 October 2021 21:34
20
Its Fat32 also. Might be best to use exFat.
