Sync 3.4.20136 - Feedback & Issues
For each new release i will create a special thread, please use this thread to post any feedback or issues you have noticed for the corresponding release.
ANY COMMENT POSTED NOT DIRECTING RELATING TO FEEDBACK AND/OR ISSUES FOR SYNC 3.4.20136 WILL BE SPLIT TO A SEPERATE TOPIC! PLEASE CREATE A NEW THREAD IF YOUR ISSUE IS NOT SPECIFIC TO THIS TOPIC!
I’m now at 3.4.19274. To update to 20136 first I have to downgrade and after that update to 20136.
Question: F9 is on my system, should I update without map?It will be ok?
the easiest way would be with a special autoinstall.lst file, the long way would be downgrade then update (you will need maps)
http://ivsubinaries.azureedge.net/swparts/5U5T-14G381-ED_1591670365000.TAR.GZ
Download this put in SyncMyRide folder on usb and use this autoinstall.lst in root of your USB
https://cdn.discordapp.com/attachments/718044802330918924/723910653877682196/autoinstall.lst
Updated, I chose the longer way but successful :slight_smile:
USB issue solved (did not play some mp3 files from usb) .
Whats new with 20136? Worth updating?
No idea what’s new on it, a user on Discord has confirmed they were able to downgrade back to 19101 so if there are issues you can go back to an older version. Good news.
upgrade made to work perfectly.
Thank you :smile: :clap:
The bug came back in this build.
Radio is switched off but when I start the car (or just the ignition) the radio shows the last station what I listened like it is ON but it is OFF. If switch the radio OFF before stop the car it shows OFF but next start it shows as ON.
I have successfully updated from build 20021 to 20136 using autoinstall.lst.
Not much to coment really. Perhaps I find this new version somewhat slower than previous one? I mean, transitions when tunring on/off and things like that. But since I haven’t really tested the old build that much, that’s all the feeedback I can provide.
Will this autoinstall.lst file and the attached package work to upgrade any region/nav unit from 20021 to 20136? I currently have NA with nav and am on 20021. Thanks
Yeah it will indeed :blush:
A quick question - mine is Ford Kuga (Escape) 2019 with Sync 3.3, build 18351 and F8 maps with Navigation.
Can I go straight to the latest 3.4, build 20136 with F9 maps + Navi? (or do I need to upgrade to smth. else first, to say in between?)
Thanks a million!
Yes you can go straight to that version :smile:
Thank you Sir!
Once I have updated it, will I still be able to receive over the air automatic updates from Ford, the usual way? I mean via wi-fi.
It’s not known. Your car is 3.3 so in theory yes but until 3.4 is released for your car I don’t know.
The rumor has it, 3.4 is coming officially to MY19+, mine is 2019 June…
2019 ? We are in 2020 and June already lol
MY19+ = model year 2019
Sorry yes I misread that as the update is coming June 2019 lol , it is rumoured to be coming soon to my19+
