After upgrade from 3.0 to 3.4 the screen dim is dark when the engine running but when the engine off screen dim is ok. In settings no option to change dim. How to fix?
Do you have access to forscan? I had the exact same problem on a 2020 explorer, had to change this line in asbuilt. May be different for you. What’s your year and model?
7D0-01-01 to xBxx
Please check the FAQ / Common Issues Thread (READ THIS BEFORE POSTING!)
Yes have forscan. Ford kuga 2014 sunc 3 from kuga 2018
Just change from APIM 7D0-0101: xAxx-xxxx-xxxx to APIM 7D0-0101: xBxx-xxxx-xxxx All forking 100% thanks for help
