Sync 3.4.20196 - Feedback & Issues
multiple people in the discord community say their front camera works
good afternoon.
the usb issues of release 20136 are fixed in this new release?
Thanks in advance
Good day.
I am new here and just got my focus mk4 updated from Sync 3.3 to 3.4.20196
However I found two issues from my end :
1. Navigation is out of work
->I guess it’s related to the wrong map version because the map looks like for China only, not for Taiwan (Yes, I come from Taiwan)
2. Cannot get into ā€œBezel Diagnosticsā€ after updated to Sync 3.4
Originally it works in Sync 3.3 following the step : Hold Skip Track on the stereo and Skip Track on the steering wheel for around 10 seconds.
Is it possible to fix the Navigation issue or does someone know where to download Taiwan Navigation map and install in my Focus MK4?
Really appreciate your help.
Hi there,
If you could provide me with the VIN number of your vehicle and a link to the Ford website that provides your country with maps, I will look to see if the correct maps are available. Please private message your VIN to me if you are happy.
On the second point, please carry out a master reset and see it works.
Thanks a lot. Your idea is workable!!!
I downloaded the maps (remark, maps for Sync 3.3) from Taiwan Ford website and installed in Sync 3.4.
Then rooting the system twice and the navigation is back :smile:
Moreover Bezel Diagnostics is available as well.
Excellent news - is there any chance you can send me the website address for the maps?
I have updated to 20196. How do I only update MAP without reformatting?
New user here… Successfully updated a 2019 Lincoln MKT (USA) from 3.0 to 3.4.20196. Noticing a couple small issues:
  1. SiriusXM the album art isn’t displayed however I have channel logos on the screen. Gracenotes says it’s installed and running 1.1.1.1332 (NA-0010)
  2. When browsing the menu, the tiles are skewed to the right a small amount overlapping into the next page. Is this normal?
Thanks!
There isn’t currently a way to do this as part of the app, you can use this autoinstall file autoinstall.lst (1.2 KB)
Download all of these
Map
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BAG_1591726015000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BBG_1591726765000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BCG_1591726913000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BDG_1591727234000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BEG_1591727457000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BFG_1591727753000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BGG_1591728190000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BHG_1591728542000.TAR.GZ
https://ivsubinaries.azureedge.net/swparts/1U5T-14G421-BJG_1591729086000.TAR.GZ
Voice
http://ivsubinaries.azureedge.net/swparts/4U5T-14G422-BAE_1580861780000.TAR.GZ
http://ivsubinaries.azureedge.net/swparts/4U5T-14G422-BBE_1580861854000.TAR.GZ
http://ivsubinaries.azureedge.net/swparts/4U5T-14G422-BCE_1580861916000.TAR.GZ
http://ivsubinaries.azureedge.net/swparts/4U5T-14G422-BDE_1580862152000.TAR.GZ
License
https://ivsubinaries.azureedge.net/swparts/1U5T-14G424-BJ_1591719092000.TAR.GZ
is this the last EU 09/2020 card? If so, the files look the same as when creating the key with reformatting? can i take back the same and just replace the autoinstall?
oh yeah that would work also :slight_smile:
Thx! My 2018 Focus is displaying radio stations logo! Thx!
I never had stations logo!
Ac button has a bug ( the old bug- when is on on Sync is off and when is off on the sync 3 is on)
Maps is great!
Radio is sonds more powerfull!
Great update!
There is a fix for this but only with editing of the software, which can only be done with a hardware flash reader.
The tiles being offset is normal, it’s been this way for a while.
The artwork for SiriusXM is really hit and miss. Remember the Gracenotes file you’re using is from 2017 also. There is no update. Others have stated it start working after a few days or after the SiriusXM is sent a refresh signal.
do you have any contact on discord community?
i need asbuild: apim and ipmb in sync 3.4 20196
Thanks… just noticed another issue after loading the package. Enable mobile apps is Greyed out and I’m not able to connect to the phone via usb to select/add apps. This worked fine in 3.0. Thoughts?
If you have not done a Master Reset since the upgrade, then do that. Remove your phone and then add it once Sync is up and running again. It is a good practice to always do a Master Reset after changes or updates to Sync.
Did a master reset right after upgrade and just did another. Now The Lincoln Way app shows up when running on phone but nothing else does… I.e. Waze
Did you enable location and permissions for the apps in Sync? It’s a newer menu now…under Settings > Apps or something like that. I’m not familiar with how to get Waze to work, but I thought you need to have the phone plugged in USB for that.
Waze has a SYNC app and also an app that works through CarPlay/Android Auto. I usually always run my maps through CarPlay as it is smoother running off my phone than through the SYNC unit.
