Sync 3.4.20196 - Feedback & Issues
ONCE AGAIN, NO! it is not possible!
EDIT: i’ve been informed this is actually possible to do, although others have said it isn’t, your mileage may vary and i have not tested this. everywhere you read online seems to suggest you can’t do this so…
Downgrade to 3.3, then downgrade again to 3.0 do not use reformat at all
does anyone else have a problem with the front camera?
I downgrade apps from 20196 to 20136 and front camera and zoom for rear camera work great. after upgrade to 20196 problem returned
check if you have any DTC’s with forscan
no DTC, front cam works fine with auto park
when I switch to reverse gear ® earlier and then change to drive (D), the front camera can be turn on with the button
Yeah, front camera is not working in this one. Seems downgrade is a must to get it back…
Hola se puede pasar de la 20021 a 20196 directamente,y si tiene algun problema esta build,gracias
Your camera was install in factory or was add yourself?
I add the camera, i have no oryginal panel with camera button. I control the camera by a short to ground, not by can network.
Although there is a chance that the application would load with voice, the map partitions are completely different. IF this could be done, the navigation would not work as the partitions stand.
Here is a sample 3.0 partition structure for a 2016 model APIM with NAV:
<d2p1:PartitionHealth available=“121M” total=“128M” type=“/fs/tmpfs/”/>
<d2p1:PartitionHealth available=“635M” total=“12G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“230M” total=“4.6G” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“13M” total=“475M” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“5.1M” total=“1.0G” type=“/fs/Nuance/grace”/>
<d2p1:PartitionHealth available=“612M” total=“1024M” type=“/fs/rwdata/”/>
<d2p1:PartitionHealth available=“172M” total=“1024M” type=“/fs/mp/”/>
<d2p1:PartitionHealth available=“6.8G” total=“25G” type=“/fs/images/”/>
Here is a sample 3.2+ partition structure for a 2018 model APIM with NAV:
<d2p1:PartitionHealth available=“12M” total=“1.4G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“36K” total=“1.4G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“148K” total=“1.4G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“12M” total=“1.3G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“3.0M” total=“922M” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“9.3M” total=“1.3G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“16M” total=“1.7G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“13M” total=“2.0G” type=“/fs/sd/MAP/”/>
<d2p1:PartitionHealth available=“15M” total=“1.6G” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“10M” total=“1.1G” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“24M” total=“2.6G” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“3.1M” total=“465M” type=“/fs/Nuance/”/>
<d2p1:PartitionHealth available=“57M” total=“1.0G” type=“/fs/Nuance/grace”/>
<d2p1:PartitionHealth available=“751M” total=“1.2G” type=“/fs/rwdata/”/>
<d2p1:PartitionHealth available=“35M” total=“35M” type=“/fs/rwdata/quip/”/>
<d2p1:PartitionHealth available=“90M” total=“90M” type=“/fs/rwdata/quip/”/>
<d2p1:PartitionHealth available=“142M” total=“1.4G” type=“/fs/mp/”/>
<d2p1:PartitionHealth available=“3.6G” total=“25G” type=“/fs/images/”/>
This has been discussed at length at FFClub and others and no one has released a method of doing this, not publicly.
Original from factory.
Is it safe to manually install the apps and voice packs using NA? or just install the apps pack?
You mean the North America manual installation? I did it yesterday, no issues.
Yes. Did you installed both? or just the Apps?
Both. Made this…I always use the Interrogator utility to show storage and health of the APIM when I do updates. You can just delete it if desired. (#3)
[SYNCGen3.0_3.4.20196_PRODUCT]
Item1 = 5U5T-14G381-EG_1598634070000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G381-EG_1598634070000.TAR.GZ
Item2 = 5U5T-14G391-CM_1598635923000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-CM_1598635923000.TAR.GZ
Item3 = GB5T-14G386-AC_1587495565000.TAR.GZ
Open3 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
Options = Delay,AutoInstall
THNX!.. Will use that.
I have a 2018 F150 that I updated from 3.0 TO 3.4. I am unable to perform a Master Rest as the settings/General Settings icon is “Gray’d” out. Also the massage seats ICON does not allow any function.
How can I perform a Master Reset to see if these reset?
That’s odd. Just for good measure, was the engine running when you took that photo?.
If not, try it with the engine running; or viceversa. Also, I’d cycle Sync by turning the engine off and opening your door. Then try again.
Also, let’s see if anyone know a physical way to perform a master reset.
Disconnect the battery for 15 minutes…the Sync unit is not shutting down completely for a reboot. This should reset the unit.
If you have a code scanner or FORScan, take a look for DTC codes if you can…
My general option is usually greyed out when I have my phone connected. Make sure you don’t have anything plugged in.
Did someone found a fix for front camera ? Or downgrade is needed ?
