Sync 3.4.20196 - Feedback & Issues
Trying the update but getting
" Installation failed Error Code: PKG_ERROR4 Download files again and retry to install"
Any help will be very much appreciated.
Thanks.
This error means that the packages are blacklisted. I am assuming you are trying to do the reformat while in SYNC 3.4.19274+. You first need to select the downgrade option and then try the install again once you are on 3.3.
You can also use the manual method in the downloader to select the upgrade packages. This will allow you to upgrade without a reformat. This route might be more beneficial to you.
Thank you will try that.
In Sync 3, in a Ford Transit Connect 2018, working flawlessly.
Android Auto also working very well.
In Portuguese Portuguese Language.
Had this for a couple of days now. Im not using USB, so no issues there. Works fine, and I finally managed to get DAB station logos.
Hi,
Update done. No issues so far, Logo’s are displayed :grinning:
Only calm mode is not shown …
Cheers
Hi, I come from China and I cannot download the sync3.4 20196 app file while all the other files can be downloaded correctly.The download link address of the app file is “http://ivsu.binaries.ford.com/swparts/5U5T-14G381-EG_1598634070000.TAR.GZ”. So could anyone confirm the download issue and any help is welcome! Thanks.
I don’t think this is the issue but restart the app, i have made it https instead of http, maybe there is some weird http restriction
Thanks. But I still cannot download the sync app file with the https method. And I decided to wait a few days and try to download it again to confirm whether this is a network-related issue or not. Thanks for your response!
can you download it from the url directly? if not then you have some issue your end or a ip block on ford’s azure blob
No, I cannot download it from the url directly. Thanks for your immediate help, and I will try to find a different ip address with vpn to download it again.
Hello to all
Just updated from 20136. I was also initially on 3.0.19205 on an old JR3T-14G381 (8GB/nonNAV) unit!
The latest 20136 is amazing and it integrates beautifully with iOS 14.
Thanks @CyanLabs and @F150Chief for all your help!
Installed on my 2019 S-Max and the Front Camera is not Wirkung anymore. Rear
Camera is okay, but the button for Frontcamera is wothout function
See this from above in the thread…
That’s great! Happy to help. Enjoy…
NM market 2017 Taurus. The dual climate button is backwards. Shows on when off and vice versa.
Known issue unfortunately
I had to downgrade from 20136 to get to 20196. Thanks to all for info. I tried the manual way, no luck. But, I think i may have had a bad usb thumb drive. I ended up getting another usb drive and did the downgrade option, then update to 20196 went without a hitch.
Thanks for the info and help
Press the next key of the center console and jump two songs.
Weird issue after using 20136 for a couple days. Not sure if it’s an Apple CarPlay issue or Sync 3 issue… when using Waze for nav, the volume on the wheel and the center stack only change the prompt volume. I have the microphone disabled in the Waze app in my phone. If I go in and enable then disable again, the volume controls work properly again. I have to do this every time I use Waze. Anyone else seeing this or have any additional info they can share on a resolution? Thanks
