Sync 3.4.20237 - Feedback & Issues
Installed on my 2018 Full Hybrid Mondeo (MY15 / MK5 IIRC). No problem here (that I found at least).
Hi, I’m running 20196 on my 2018 Ford Fusion with NAV, F9 maps ANZ. (Brazil) without any issues, except for Waze/Gmaps navigation not showing the remaining distance in dash LCD screen, but everything else works fine.
Is it worth updating to 20237? What are the new features over 20196? I understand it’s a minor update. Is the dash LCD screen issue corrected?
Interesting find with running 20237 on newer APIMs. I have a 2018 APIM and GPS works flawlessly running 20237 for me. Ford is eventually going to roll out one of these newer builds to the public so they I’m assuming they will fix the GPS issue in a newer build (if it really is a widespread issue on newer APIMs).
As far as we can tell 20237 is simply a bug fix update over 20196. No noticeable new features. There have been reports of a new CPU governor but I think this only applies to newer APIMs (2019+).
I have an APIM manufactured in 2019 for a '20 model year Fusion. How do people discover specifics like that, that is, a CPU governor that only is enabled / controlled in a new s/w release ?
Not entirely sure. Haven’t really looked much into inspecting packages myself, but I’m assuming this would be something in the kernel.
Okay, this is an odd one… Just updated our '14 Fusion to 20237 this afternoon (I installed a 2020 APIM in it). Once it was completed, I did a master reset. As most know, this removes any linked phones, etc, etc so I went to add some back. When the BT search started, it showed the name as ā€œFord F150ā€ ! I’ll take a picture if anyone wants proof. :grin: I know this is a setting I can change with FORScan but it’s not one I’ve ever touched.
Why would this happen ? The SYNC software doesn’t touch the as-built values, does it ?
Initial impression is everything seems Ok on my MY2020 Explorer. GPS works fine. No noticeable changes from 20196
Welcome to the community and thanks for sharing :slight_smile:
from 3.0? if so the values for the BT names likely changed in the new builds of 3.x
i haven’t checked in this instance but usually things like this are detected in the startup_gf.sh file
seen a few people report this, even had some emails saying the same, seems to be limited and unsure on what exact similarities between cases.
Nope, I bought an APIM out of a 2020 model and it already had Sync 3.4. I don’t recall the version but maybe ended in ā€œ05ā€, like 20105. Doesn’t matter anyway because I updated it to 20196 the same night and all was fine. The BT name was ā€œFord Fusionā€ like it should be. Only after updating to this build did it change. The as-built value was ā€œOEā€ which corresponds to ā€œFord F150ā€ too.
Wasn’t this caused by the change you made for the CD player and forcing the write to OEFF?
Updated my 2016 Ecoboost Mustang today to 3.4.20237. Everything seems to work great. I noticed there’s now album artwork (Gracenote powered?) available on FM and SiriusXM, which is a welcome addition. However, the artwork isn’t appearing and only shows a placeholder. The artwork also doesn’t appear when playing a CD (Heavier Things by John Mayer).
I have Gracenote installed, as the version number is showing up in the settings. It’s just not showing up anywhere. Do I need to enable this using FORSCAN? Is there a hidden menu somewhere? I remember in Sync 3.0 there was a Media Player option in Settings that controlled Gracenote, but it appears to be gone in Sync 3.4.
Dang, you’ve got a good memory ! My wife and my phone were already ā€œlinkedā€ so it didn’t impact them connecting after I made the change either. Now I wonder if the CD button has returned ! :grinning:
Good afternoon to the whole community!
I upgraded to 3.4.20237 without any hitch.
Suddenly I didn’t notice anything. What are the differences?
Hug to all of Portugal.
I still don’t have the radio station logos.
Is it possible to have?
my ford import from AUZ Zone ,
can syn3updater update to ROW Zone ( i live in Thailand )
