Thx for your quick answer :slight_smile:
Seems solved so far on 21020… I was experiencing the same!
I updated from 3.0 to 3.4 v20351. All went well except the Sirius travel apps stopped working. I contacted sirius, got several re-boots, did a full reboot on my system, nothing has worked. I’m thinking of upgrading to the next version along with the 2020 maps. Would that help or make things worse?
The Sirius travel apps are subscription based and are separate from the SiriusXM subscription. The initial subscription from Ford is 5 years, then it is up to you to renew. I see that you have rebooted several times, but have you performed a master reset? If you have not had to re-pair your phone, you have not.
Upgrading to 3.4.21020 with NA 2.20 maps will not fix the Sirius issue, but will give you new maps, etc.
Hey,
The 2 tracks skipping is gone, indeed, but the stutter is still there, unfortunately.
True
