Dang - it reformatted my USB, will have to redo it.
Sync_W09W3RMV_1FM5K8HC1MGC26389.xml (10.9 KB)
is blank, so itās not matching with a MY20 model, so itās saying itās fine⦠itās almost defnitely is not!
Yeah, I didnāt think it would be, so I was confused when it started the process. I guess Iām lucky I didnāt try to update?
In Syn3 Updater what do you have your āfull versionā set to in the settings?
Which logging tool did it use? whats the filename? ending in ? AD AC AB ? (check the USB)
Dang! I formatted and Iām trying to downgrade to 21265 now (the usb, that is)
Make sure install mode is autoinstall and you can update to 22110 if you want, you canāt update maps though
Ohhhhhā¦ok, I didnāt know I could do that. Thought it was all or nothing. Iāll try that now. Thanks!
Fixed in now released 2.11.1.0
Note that itās not going to magically make it work on these undetermined models, it just throws an error and doesnāt assume not MY20
Hello! Need some advise. I have this version of Sync 3.4.20351 with F10 maps EU. If I want to download F11 maps, what I have to do? The new maps version F11, what change have it?
As you have not provided any information on your profile for what car you have, what car do you have? what year?
Ford EcoSport Year 2018
Update the maps with the Syn3 Updater.
Canāt download!!! Help pls!
