I feel like I’m always repeating my self, change download connections to 1 if that doesn’t fix it , nothing we can do, files come from ford servers
I did with the tool, I put my actual version and just update maps but the updater the mode is auto install and it’s apparead like a official update in the sync3…
Try and same result: don’t work!!! Disable my firewall and same story.
The issue is either on your end or Ford’s either way there is nothing i can do, saying which file it fails on might help.
nevermind, turns out you can only download 3 at once, then ford links stop working completely lol
This is commonly called rate limiting, not sure it’s relevant to syn3updater or this thread though as syn3updater only downloads 1 file at a time
There is no issue there, if failed and then retried and worked
All de map files, are Red notice about download. If I can’t download for the first time, it is very hard to do the second, third …. time. And I can stay in front of PC to see if it work the links or not. And it happen on 2 PC, one with W7 and second with W10. So, what is the solution? Other links? Or the leak from Ford is now imposible to download?
For legal reasons i won’t mirror ford’s IP, if the links are not working then i can’t help you!, no one else is reporting issues. this is also not related to an issue with 22110 so shouldn’t be in this topic.
recently installed the 3.4.22110 update, so far the annoying glitch when playing usb music has disappeared. ![]()
Guys, how happy am I!
Now I had an update (downgrade) for the 2nd time via the Syn3Updater / CyanLabs
performed on my Sync3 system. I can tell you, like the first time, it was the worst 45 minute drive again!
What was I sweating? Before the trip, I still had the 3.4.2165 + 10 navigation maps and now the new 3.4.22110 + 11 navigation maps.
I’m sooo glad everything worked out.
You here in the forum have my utmost respect for what you do and my greatest thanks.
guys
you rock
Thank you all
with best regards
bachi1968 ![]()
I think I messed min eup. I’m getting the PPG_04 error and my Nav is not working. When I tried to use the Auto update thing using the previous details, it wasn’t giving me the option to select the Nav files/maps even though I had maps previously. do I need to downgrade first and go again? Took me nearly 3hrs to download and then another hour to install. ![]()
The rest of the install is fine and everything is working as expected except Nav.
" CYANLABS - SYN3 UPDATER - V2.11.1.0
Version: 3.0.20204
Region:
FileSystem: FAT32
VOICE=5U5T-14G391-AS_1644006548000.TAR.GZ
MAP=1U5T-14G421-BCJ_1644009116000.TAR.GZ
MAP=1U5T-14G421-BDJ_1644009729000.TAR.GZ
MAP=1U5T-14G421-BEJ_1644010041000.TAR.GZ
MAP=1U5T-14G421-BFJ_1644010644000.TAR.GZ
MAP=1U5T-14G421-BGJ_1644011311000.TAR.GZ
MAP=1U5T-14G421-BHJ_1644011371000.TAR.GZ
MAP=1U5T-14G421-BJJ_1644011473000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAG_1644245686000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDG_1644012081000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBG_1644011700000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCG_1644011850000.TAR.GZ
; CyanLabs Syn3Updater 2.11.1.0 Stable - reformat Mode - Sync 3.4.22110 EU
FILES (19)
5U5T-14G391-AS_1644006548000.TAR.GZ (1.5GB)
1U5T-14G421-BAJ_1644010894000.TAR.GZ (2.3GB)
1U5T-14G421-BBJ_1644008981000.TAR.GZ (478.9MB)
1U5T-14G421-BCJ_1644009116000.TAR.GZ (1.7GB)
1U5T-14G421-BDJ_1644009729000.TAR.GZ (1.1GB)
1U5T-14G421-BEJ_1644010041000.TAR.GZ (1.6GB)
1U5T-14G421-BFJ_1644010644000.TAR.GZ (2.4GB)
1U5T-14G421-BHJ_1644011371000.TAR.GZ (2.7GB)
1U5T-14G421-BJJ_1644011473000.TAR.GZ (24.1MB)
4U5T-14G422-BAG_1644245686000.TAR.GZ (2.3GB)
4U5T-14G422-BDG_1644012081000.TAR.GZ (2GB)
4U5T-14G422-BBG_1644011700000.TAR.GZ (2.1GB)
4U5T-14G422-BCG_1644011850000.TAR.GZ (1.6GB)
1U5T-14G424-BL_1646159765000.TAR.GZ (1.7KB)
[04/06/2022 12:01:14] Selected Region: EU - Release: Sync 3.4.22110 - Map Version: F11 (2021) - EU (05 2022)
[04/06/2022 12:01:14] Install Mode: Auto-Detect (reformat) Forced: False
[04/06/2022 12:01:14] MY20 Protection: Auto-Detect
[04/06/2022 12:01:14] Formatting USB drive
[04/06/2022 12:01:14] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[04/06/2022 12:01:22] Checking Existing File: 1u5t-14g386-cb.tar.gz
[04/06/2022 12:01:22] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[04/06/2022 12:01:22] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[04/06/2022 12:01:25] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[04/06/2022 12:01:25] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 12:01:25] Downloading: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 12:05:17] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 12:05:20] Downloaded: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 12:05:20] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 12:05:20] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 12:05:35] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 12:05:35] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 12:05:35] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 12:05:35] Downloading: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 12:11:49] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 12:11:53] Downloaded: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 12:11:53] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 12:11:53] Downloading: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 12:23:20] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 12:23:26] Downloaded: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 12:23:26] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 12:23:26] Downloading: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 12:25:59] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 12:26:01] Downloaded: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 12:26:01] Checking Existing File: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 12:26:01] Downloading: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 12:34:58] Validating: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 12:35:02] Downloaded: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 12:35:02] Checking Existing File: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 12:35:02] Downloading: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 12:40:23] Validating: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 12:40:26] Downloaded: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 12:40:26] Checking Existing File: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 12:40:26] Downloading: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 12:48:53] Validating: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 12:48:58] Downloaded: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 12:48:58] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 12:48:58] Downloading: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 13:03:58] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 13:04:05] Downloaded: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 13:04:05] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 13:04:05] Downloading: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 13:14:49] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 13:14:55] Downloaded: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 13:14:55] Checking Existing File: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 13:14:55] Downloading: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 13:30:12] Validating: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 13:30:19] Downloaded: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 13:30:19] Checking Existing File: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 13:30:19] Downloading: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 13:30:27] Validating: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 13:30:27] Downloaded: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 13:30:27] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 13:30:27] Downloading: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 13:40:05] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 13:40:12] Downloaded: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 13:40:12] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 13:40:12] Downloading: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 13:48:09] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 13:48:14] Downloaded: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 13:48:14] Checking Existing File: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 13:48:14] Downloading: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 13:56:43] Validating: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 13:56:49] Downloaded: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 13:56:49] Checking Existing File: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 13:56:49] Downloading: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:03:14] Validating: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:03:18] Downloaded: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:03:18] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:03:18] Downloading: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:03:19] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:03:19] Downloaded: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:03:19] Preparing USB drive
[04/06/2022 14:03:19] Checking Existing File: 1u5t-14g386-cb.tar.gz
[04/06/2022 14:03:19] Copying: 1u5t-14g386-cb.tar.gz
[04/06/2022 14:03:20] Validating: 1u5t-14g386-cb.tar.gz
[04/06/2022 14:03:20] Copied: 1u5t-14g386-cb.tar.gz
[04/06/2022 14:03:20] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[04/06/2022 14:03:20] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[04/06/2022 14:04:18] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[04/06/2022 14:04:36] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[04/06/2022 14:04:36] Checking Existing File: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 14:04:36] Copying: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 14:05:51] Validating: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 14:06:14] Copied: 5U5T-14G381-EZ_1652218180000.TAR.GZ
[04/06/2022 14:06:14] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 14:06:14] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 14:06:19] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 14:06:20] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[04/06/2022 14:06:20] Checking Existing File: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 14:06:20] Copying: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 14:08:35] Validating: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 14:09:16] Copied: 5U5T-14G391-AS_1644006548000.TAR.GZ
[04/06/2022 14:09:16] Checking Existing File: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 14:09:16] Copying: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 14:12:38] Validating: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 14:13:39] Copied: 1U5T-14G421-BAJ_1644010894000.TAR.GZ
[04/06/2022 14:13:39] Checking Existing File: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 14:13:39] Copying: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 14:14:21] Validating: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 14:14:34] Copied: 1U5T-14G421-BBJ_1644008981000.TAR.GZ
[04/06/2022 14:14:34] Checking Existing File: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 14:14:34] Copying: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 14:17:04] Validating: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 14:17:49] Copied: 1U5T-14G421-BCJ_1644009116000.TAR.GZ
[04/06/2022 14:17:49] Checking Existing File: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 14:17:49] Copying: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 14:19:27] Validating: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 14:19:56] Copied: 1U5T-14G421-BDJ_1644009729000.TAR.GZ
[04/06/2022 14:19:56] Checking Existing File: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 14:19:56] Copying: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 14:22:20] Validating: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 14:23:04] Copied: 1U5T-14G421-BEJ_1644010041000.TAR.GZ
[04/06/2022 14:23:04] Checking Existing File: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 14:23:04] Copying: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 14:26:38] Validating: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 14:27:46] Copied: 1U5T-14G421-BFJ_1644010644000.TAR.GZ
[04/06/2022 14:27:46] Checking Existing File: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 14:27:46] Copying: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 14:30:44] Validating: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 14:31:37] Copied: 1U5T-14G421-BGJ_1644011311000.TAR.GZ
[04/06/2022 14:31:37] Checking Existing File: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 14:31:37] Copying: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 14:35:39] Validating: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 14:36:51] Copied: 1U5T-14G421-BHJ_1644011371000.TAR.GZ
[04/06/2022 14:36:51] Checking Existing File: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 14:36:51] Copying: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 14:36:53] Validating: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 14:36:54] Copied: 1U5T-14G421-BJJ_1644011473000.TAR.GZ
[04/06/2022 14:36:54] Checking Existing File: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 14:36:54] Copying: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 14:40:12] Validating: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 14:41:12] Copied: 4U5T-14G422-BAG_1644245686000.TAR.GZ
[04/06/2022 14:41:12] Checking Existing File: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 14:41:12] Copying: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 14:44:10] Validating: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 14:45:03] Copied: 4U5T-14G422-BDG_1644012081000.TAR.GZ
[04/06/2022 14:45:03] Checking Existing File: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 14:45:03] Copying: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 14:48:19] Validating: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 14:49:17] Copied: 4U5T-14G422-BBG_1644011700000.TAR.GZ
[04/06/2022 14:49:17] Checking Existing File: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:49:17] Copying: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:51:42] Validating: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:52:25] Copied: 4U5T-14G422-BCG_1644011850000.TAR.GZ
[04/06/2022 14:52:25] Checking Existing File: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:52:25] Copying: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:52:25] Validating: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:52:25] Copied: 1U5T-14G424-BL_1646159765000.TAR.GZ
[04/06/2022 14:52:25] Generating reformat.lst
[04/06/2022 14:52:25] Generating autoinstall.lst
[04/06/2022 14:52:25] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY! "
Run the Interrogator Utility in the Syn3 Updater and post the results. Redact your VIN.
Another car updated successfully
Sync 3 2.2 to Sync 3.4 (latest) - Master reset after, all seems perfect ![]()
Did the upgrade aswell. First attempt (package downgrade went well) after 2nd reboot the reformat screen came up and my usb drive wasn’t recognized. So had to redownload on a borrowed (slow….) usb drive, took overall 51min. Did two master resets and all is working again. No issues so far
EU NAV 2018 unit ![]()
This update seems to have solved the skipping usb media playback issue.
I tried to do only a map update to F11 without a new version. the stick was prepared for “automatic detection” with my20. then I ran the update in my s-max and it came the message “successful”. when checking under the licenses is the f10 card still listed, as well as my version 21098 (because of the aftermarket camera). should there not be f11?
or do i have to go the roundabout way, first the current complete update incl. cards and then do a downgrade?
or should I have loaded the version 21098 again with f11 cards on the usb?
Could you please post your Updater log file?
