Depends if we can find the license file
Sync 3; Non Navigation; ROW (India) ;
- Updated to 3.4.22110 from 3.4.22048 through auto Downgrade reformat method.
- Replaced the voice package by small NA voice package to empty storage for Gracenotes installation
- Then installed Gracenotes for ROW
- Ran the Interrogator log empty space left is 1.1 GB
- Now I want to reinstall the ROW voice package which is of 1.36 GB
- Can I reduce the size of ROW voice package by selecting only English language India or UK ?
- Even if size of voice package is reduced, is it possible to install the same on leftout space of 1.1 GB
Experts may kindly help
9 posts were split to a new topic: Clock issue
Regarding the bug of phone button while using carplay now even I downgraded to other version 3.4 still happeningā¦
I update back to sync 3.3 and work well but now any version of sync 3.4 the trouble will come back
did you master reset? if not then this means nothing unfortunately.
Surely, master reset is first step when we update software.
Now only sync 3.3 is working well with phone button direct to carplay
All sync 3.4 will lead to Bluetooth pair screen even the phone had connect and using carplay well
I dont really see how this is possible, any one else confirm similiar outcome?
@NGUYEN_HUU_HUNG: Which Builds of 3.4 did you try?
While I canāt confirm it, there is a chance, that this Bug is also present in 22020 and 22048 as there were some USB/BT related changes which made it into this release.
Last Build I know this 100% works is 21265.
(Edit: Sorry for the Mention. Somehow selected the wrong message)
Both 22020 and 22048 i tried and faced with this issue
Let me test again with 21265
You cannot place Gracenote on a NON-NAV 8GB APIM with Sync 3.4 and the regional voice package for ROW.
5U5T-14G381-EZ 869Mb Sync3 v3.4.22110 10.05.2022
5U5T-14G391-FS 1.36Gb Sync3 v3.2.21336 (12)
4U5T-14G423-FC 924Mb Sync3 v3.3.20342 1.1.1.2325 (GL-0011)
The files above total 3.154 GB COMPRESSED, which is more than the storage available anyways. Uncompressed, the files will take about 4.7 GB of space.
Just updated from 21265 to this. apps package only. No problems so far.
Just updated after returning from vacation. No issues to speak of so far. Straightforward downgrade moving from 22048 and adding NA 221 maps. Format step took about 25 minutes or so on my cheap Microcenter USB 3 flash drive.
Just confirmed 21265 ran as normal as your mentioned
Can I install the F11 maps without updating the system? I have an āaftermarketā camera, which only ran up to one version. I would hate to update the system, just the maps. Is that possible because of other language packs?
if you are EU and not My20 Reformat is best option, just reformat back to 3.3/3.4 version that worked.
Working without any issues.
Went from 21194 to 22110 on a US 2016 Fiesta ST with Nav. Took 25 minutes.
Just to be sure, I have a 2021 Explorer. Can I update this? Iām a little confused by the MY20 stuff. Is the known issues only for model year 2020, or any year after 2020? Thanks!
MY20 + canāt reformat, depending on your region you may be able to autoinstallā¦
however looking at your profile it looks like you are NA so you are SOL (Shit Outta Luck) as they are ESN locked
Ok - I just ran the Syn3 updater, did the interrogator and it said I was good to go. Itās creating a USB stick now. So I should hold off?
If you have a MY20 APIM and didnāt lie when asked at the prompt iām confused how Syn3 Updater would say you are good to go, post your interrogator log
