The updater isn’t giving me the option for 2021 NA Maps under stable or beta, with MY20 enabled (or disabled). Does it just need to work it’s way through?
Because you have my20 enabled there is no solution
No if the app isn’t offering it then it’s because he is my20 and it only shows non ESN maps.
And as he is my20 and NA he can not install manually
Yes but as stated it is ESN locked so of literally 0 use to us!
As for Gracenotes, i can say it is indeed working. Haven’t tested it throutfully though.
As for the clock, it definitely worked with ignition Off as soon as it acquired GPS lock, but since the last master reset i did was indoors, i couldn’t tell if it stopped “timing” during the night. Might check it tomorrow.
I installed everything today and Gracenote seems to work fine. My clock did not have any issues.
EDIT: No issues 3 days running.
good evening everyone i started the 22110 update before checking that the na license had been uploaded, how would i go about just updating the maps when the install is complete? 21 maps doesnt show as an option when trying to just update the map, i apoligize in advanced if this has been answered already. non my20, NA.
You cant do just the maps. You will need to do the whole image again with maps. The 2-21 maps are missing the Key and are ESN locked.
10 4. Will do again.
RTFM dude all answers are there
How long will they support maps for Sync 3? or is that independed of the Sync version at the moment?
If you have a SSD USB stick it takes 50min reformat mode+maps+update
How would i know, i’m not Ford.
Any decent USB drive (so any that meet USB 3.0 specs) will take about 50 minutes via USB 2.0 via reformat, but still takes 1.5-2.5 hours via autoinstall (for EU)
Fair enough! i was curious if by chance, somebody knows something
@CyanLabs Hey Scott - I am in the U.k have a 2018 Ford Focus currently on V3.4.21265 with EU F10 maps package. I want the latest version including the latest F11 maps, you mention that format is not available above a certain version so how do I format? It’s saying it will be downgrade, so will it downgrade then reformat itself or do I need to repeat once it has downgraded?
Thank you
Correct ![]()
@CyanLabs so there is no further file updates to this package to come then? People said further up that it was taking forever to do by upgrading, so will the updater do it quickly by downgrading then reformating?
Reformat will be about 50 minutes, no other files to come (atleast not for EU)
Downgrade before hand will take about 5-15mins
So from start of process to end of process you think 50 minutes? I am just trying to understand what order it comes in, downgrade then reformat for my car? Reformat comes 2nd so how long will downgrade take before @CyanLabs ?
