Sync 3.4.22251 - Feedback & Issues
Introduction
Sync 3.4.22251 has been found online and added to Syn3 Updater!
For each new release a specific thread will be created, please use this thread to post any feedback or issues you have noticed for the corresponding release.
Important Notes
This release only updates the APP package.
Rules
  • Do not reply to this thread with general issues that are not specific to 3.4.22251
  • If you notice a bug or change specific to this feature report it below
Failure to follow the above rules will result in your post either being moved (if moderators or myself are feeling generous) or deleted without prompt
To clarify, MEM_ERR’s, Missing Logos, LST_ERRS etc should not be posted here, make a new thread using this Support Link
Install Methods
Syn3 Updater
You can update using Syn3 Updater
Quick Links
China : syn3updater://Region=CN;Release=3.4.22251
Europe: syn3updater://Region=EU;Release=3.4.22251
North America: syn3updater://Region=NA;Release=3.4.22251
Australia: syn3updater://Region=ANZ;Release=3.4.22251
ROW: syn3updater://Region=ROW;Release=3.4.22251
Manual Method
It’s also added to the manual method available at the below link
App Package URL
SYNC 3 Common Issues and FAQ’s
Official Issues
TBC
Community Spotted Issues
:warning: There’s an ongoing issue where rwdata partition is getting full, triggering some issues like settings going back to defaults and/or problems with upgrading to a different version. Check these threads for reference and workarounds:
Also, make sure to check F150Chief’s tutorial about the available recovery procedures: APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates (Solved).
It’s not yet clear if this is 3.4.22251 specific or not, users that got those issues are currently testing other builds. As said before, this is still ongoing.
Community Spotted Changes
Clock now works correctly on Non Nav units, broken in previous version
Technical Information from FMods
Package Name: NU5T-14G381-AB
Epoch: 1665525837000
Major Version: 3.4
Build: 22251
Build Date: 2022-09-08
Package Date: 2022-10-11
Release Date: 2022-10-27
List of Changed files: https://pastebin.com/V1m9ay8Z
Changes (based on diff):
  • Updated some ifs, some bins and some libs
  • Added two BT Vehicle names: Mach-E and F-600
  • Some UI changes to Navigation view (10P Theme), Charge setting View (All themes), Customer Connectivity View (All Themes), System Update View (All Themes, but it’s not a UI change, just a logic behaviour change)
Most important thing:
Does JB works? YES
