Using a different brand of USB Stick fixed this issue
If I was running 22251 do I already have the 2.22 NA maps? Should I just run an update to 23088 with keep existing maps?
No. 2 22 NA was just found by Cyanlabs. Ford has not even released it yet to the public.
OK. Wasn’t sure. I can try the full update. Hoping I don’t run into issues. I have had the occasional APIM issues that some other people had but not very often.
Hey, just installed the latest build with 2022 NA maps and everything works good… Mind you, the memory stick can get picky… I got errors on one of them and the other it worked flawless on my 2017 Escape TI! Cheers.
Is it safe to do the map key to upgrade the maps on a 2020 esplorer? Still stuck at NA 2 20
what year model and region?
If you have a MY20+ vehicle you cannot reformat, you would need to use autoinstall for the maps. However, if you do not have the proper license file for your vehicle for ESN locked maps, the installation will fail.
His profile is NA.
Vehicle Make: Ford
Vehicle Model: Escape TI
Vehicle Year: 2017
Vehicle Region: NA
You should be getting free maps from Ford for 5 years. Have you tried looking at the Ford site because you can at least upgrade to 2.21 right now or just wait till they put out 2.22
@screaminfast …As @C_Wu suggested the 2.22 maps came out linked to the 23088 Cyanlabs software update. I just uploaded both to my 2017 Escape with no issues so far from version 22251 2.21 maps.
Hello community,
“Done”
My hands get sweaty every time I try the Sync 3 update.
In short: the update worked wonderfully
I couldn’t find any errors until I had to put the clock forward by an hour.
After the update I did a master reset - thumbs up!
“My special thanks to wiz043 and of course to CyanLabs.
Thank you for your helpful and well explained support!”
Thank you for your understanding and your efforts,
With kind regards
bachi1968
Just updated to 23088 and clock keeps resetting, maps show a blank map but can see my icon and settings. Anything i search says 0 miles. I did do a master reset as well issue still there. I did do this while working at airport so not sure if being in the garage is the issue or not. Will test when i leave in 5 hours and update if that was the issue no update then issue still there
You got the clock to set properly? How i did master reset and same issue
Updated yesterday from 3.4.22251 and F11 maps, to 3.4.23088 and F12 maps. No issues with installation other than instructions for downgrade method omitting to mention the 2nd automatic restart before reformat starts.
The update has fixed an issue with nav voice prompts. Now they are as expected, i.e. a prompt some distance before a turn or exit, repeated immediately before the turn, and timed correctly.
On 22251 and F11 maps, the voice prompt was not repeated, or was mis-timed or missing, especially at roundabouts. All good now.
Another issue fixed is the touch screen lag, e.g. when typing an address there was a delay between touching a letter and it appearing in the address. Now it responds immediately.
If anyone knows how to report map errors to the nav data provider I’d be grateful for the info. There’s a new bypass in my town. Nav instructions include a right-turn, where no right-turn is possible due to a central reservation with a metal fence.
After the update and master - reset
I put the clock forward 1 hour.
The time is now displayed correctly
Best regards
bachi1968
The clock and maps use GPS for proper function. You will need to get out of the garage…
Downgrade instructions located at Downgrade Mode Instructions - CyanLabs (last updated about a year ago) clearly mention that automatic restart in step 4.
So, where did you read that?.
Thanks.
CAn you speak to the navigation , because i cant
You are right of course. Sorry, was driving and not reading instructions during the update.
