Not tested the voice controls since the update. Will try it today.
Update. Works fine. See detailed reply below.
I installed EU map F12 and got "system updated# but it still show F11.
Post a new topic, using the template, providing all the information!
Updated my S-Max 2017 from 3.4.22251 and F11 to 3.4.23088 and F12 and it alle went very smooth. Very user friendly, without shutting down/restart the engine. Whole procedure tooks about 55 minutes, from downgrading to install the latest version and maps. Donated you some cups of coffee. Many thanks!
Yes, it works
Voice Nav address entry tested on a 3 stage journey. 1) Spoke the entire address, which was found correctly. 2) Spoke a postcode, found correctly, 3) Spoke destination favourites, spoke results line No, found correctly. 4) Spoke Cancel Route. So voice seems to work very well.
A major retrograde change introduced in my previous version (3.4.22251, F11 maps) has been reversed.
The issue with that version (donât know if it was due to Sync version or F11 maps) was that you could no longer enter a complete address via voice. You had to spell the town, spell the street, say the house number. On many occasions the house number could not be found, so the street mid-point was the only option.
Now, with 3.4.23088 and F12 maps, itâs back to the way it always was and the complete address can be spoken and entered in one go.
Installed 23088 last week. Master Reset. Changed a few settings, including Display to Night. No issues for a few days. Yesterday noticed the Display changed back to default (Auto).
Update: now settings going back to default occuring frequently. Especially the Displaying going to Auto when I had set it on Night. Does this while driving in the car even.
A post was split to a new topic: [MOVED] Help upgrading maps
I updated my 2017 F150 from 3.4.22251 and NA 2.21 to 3.4.23088 and NA 2.22 and all went perfectly. The entire thing took 25 minutes, from downgrading to 3.3 and then installing the latest version and maps. I also did this on my wifeâs 2011 Edge which was upgraded to Sync 3 about a year ago with the same configuration as my truck and it works perfectly.
After a few days of testing, I can confirm the Navigation bug is still present with 23088.
The two settings that keep reactivating themselves after disabling them are âBreadcrumbsâ together with the âNorth upâ maps view.
Itâs not a big deal since it happens once in a while, but since itâs not related with the out of memory scenario, perhaps itâs worth mentioning it.
EDIT: iâm driving a 2018 Focus, ANZ region
My 1st post here. Started using SYN3 Updater last summer and updated to 3.4.22200, 22251, and now 23088 without issue. Cyan Labs made the update process very easy to do.
Just a couple of suggestions:
In your training manuals, please make it clear that even though SYNC tells you to remove the USB and restart the car in the first couple of minutes of the process, SYN3 Updater needs to have the USB inserted for the entire process. I followed the carâs instructions the first time and had to restart the process.
Make it a little clearer that users will need to pair their smart phones again after the process has completed. This time it was not a big deal for me, as I just replaced my smart phone and had to remove the old one from SYNC.
While I have a dedicated USB drive for SYN3 Updater, I let the program reformat the drive each update. That may address some issues other user have with their USB drives.
Add my name to the list of those wanting SYN3 Updater to update the radio station/satellite radio logos with each update. Iâm in the USA so I would need Sirius/XM and HD Radio logos.
Iâve been so satisified with Cyan Labs that I went ahead and became an annual supporter so they can continue their work in making our lives easier. Thanks again guys.
CAR INFOâ2017 Ford Escape Titanium with the Sony Infotainment system
REGIONâNorth America/USA
CURRENT VERSION of SYNCâ3.4.23088
MAP VERSIONâNA 2 22
Have you master reset?
Did you upgrade via reformat?
If youâre asking me:
Yes I did the master reset
I used the defaults to upgrade. After I hit START, I get the 3 pop ups
- I confirm this is not a MY20 system
- Since I used this drive with SYN3 Updater before do I want to reformat the USB for this useâYES
- Acknowledge Iâm using this product at my own risk and wonât hold Cyan Labs responsible if my system gets bricked.
Of course, in fact iâve tried master reset several times back in 22251 when this issue first appeared, no changes.
As for reformat, I believe itâs the only available method for installing a full APPS+MAPS package here in Argentina with no ESN, I could be wrong.
Anyway, a few minor settings being activated itâs not a huge inconvinence, just wanted to let you know about it.
Thank you for confirming.
If a reformat and master reset was made, then yes, itâs a bug. No issues with the rwdata partition, since the unit has been reformatted.
You may want to check if older versions solve that.
My thoughts exactly. Just seems weird no one else has reported it.
As for downgrading yes, I could try it as I am 99% sure this wasnât present a few builds ago. For the time being Iâll keep things as they are.
A post was split to a new topic: [MOVED] Random discussion
Hi, Thanks for the positive words and support.
About your suggestions though, unfortunately i donât agree on any of them, as explained below.
I fail to see how i can make this any clearer (unless there is some other location where the documentation doesnât mention this?)
Failing to follow the instructions in our document will just mean you have to re-insert the USB again, nothing bad will happen.
A master reset is pretty self explanatory, if you factory/master reset any device it loses itâs configuration, tablets, phones, tvâs, computers, etc. I donât think more text to clarify this point (so even less people read it will help)
The issues are not related to this but it never does any harm to run a quick format on the USB drive via Syn3 Updater.
I donât understand what list, nor what this is even about, Sirus XM logos are not controlled by SYNC 3 IVSUâs, this is not something CyanLabs can ever resolve.
No, @SaNdMaN wasnât replying to you. You can see in the top right corner of the post who the reply was directed at.
Appreciate your feedback.
Your message is offtopic, and has been deleted, twice (as per the very first message on this thread).
Create a new thread using the template, complete all the fields.
GUYS! how is it so difficult to understand that any issues not related to this build do not go here. people want to know what issues exist in builds, when itâs full of 100+ BS non related shit posts they canât do that. keep it clean!, from now on i wonât be moving posts that are wrongly posted here, instead they will be deleted without warning!
