I recently updated my Sync 3.0 to Sync 3.423188 with the updated maps. Everything was great until I tried to use voice commands (Find a POI/Find an address). The voice says “feature unavailable, please complete map update”. Voice commands work for phone calls and changing radio stations. I tried to downgrade to Sync 3.3, then redownloaded 3.42 3188, did a master reset, still no voice for navigation. I’m not very tech adept but have tried to read all the Q&A’s in the forum and can’t figure out next steps. |I’ve removed everything from the USB (32g) and started fresh each time.
Old SYNC Version: 3.0.20204
Voice says “Feature unavailable, please complete map update”
Syn3 Updater Version: 23188
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Only Update Maps EU
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 1U5T-14G424-BM_1683133039000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G424-BM_1683133039000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BHK_1682468092000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BHK_1682468092000.TAR.GZ
Item4 = VOICE_NAV - 4U5T-14G422-BAK_1682464728000.TAR.GZ
Open4 = SyncMyRide\4U5T-14G422-BAK_1682464728000.TAR.GZ
Item5 = VOICE_NAV - 4U5T-14G422-BDK_1682464885000.TAR.GZ
Open5 = SyncMyRide\4U5T-14G422-BDK_1682464885000.TAR.GZ
Item6 = MAP - 1U5T-14G421-BBK_1682466740000.TAR.GZ
Open6 = SyncMyRide\1U5T-14G421-BBK_1682466740000.TAR.GZ
Item7 = MAP - 1U5T-14G421-BJK_1682469041000.TAR.GZ
Open7 = SyncMyRide\1U5T-14G421-BJK_1682469041000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 1U5T-14G421-BFK_1682467908000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G421-BFK_1682467908000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BAK_1682464992000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BAK_1682464992000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BCK_1682467250000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BCK_1682467250000.TAR.GZ
Item4 = MAP - 1U5T-14G421-BDK_1682467734000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G421-BDK_1682467734000.TAR.GZ
Item1 = VOICE_NAV - 4U5T-14G422-BBK_1682464776000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BBK_1682464776000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BGK_1682467948000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BGK_1682467948000.TAR.GZ
Item3 = VOICE_NAV - 4U5T-14G422-BCK_1682464838000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G422-BCK_1682464838000.TAR.GZ
Item4 = MAP - 1U5T-14G421-BEK_1682467790000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G421-BEK_1682467790000.TAR.GZ
I would try a manual install of the .23188 voice file and a manual reinstall of the NAV voice.
SaNdMaN
(SaNdMaN)
August 26, 2024, 8:27pm
3
A) Perform a master reset
B) Once the master reset is done, create and run an interrogator log against the unit; share the resulting XML with us.
Did a master re-set, did the interrogator log (which took me way longer than it should have to figure out). Below is the Log (removing my VIN as instructed). I really appreciate your help, I have no idea what any of this means.
VIN: XXXXX
Version NU5T-14G381-AD
APIM Model: HB5T-14G371-CCA
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 18G
2024-08-26 5:12:48 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 8.3M / 1.3G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.4M / 1.3G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 945M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 18G / 25G
Installed Packages
4U5T-14G421-CHG
4U5T-14G421-CBG
4U5T-14G421-CAG
5U5T-14G391-CS
4U5T-14G423-CC
APIM AsBuilt
DE00: AB2845038002AA15000A
DE01: 434101044003401000000005
DE02: 0000010200
DE03: 01000601080007
DE04: 18061810295F
DE05: 80
DE06: 1604330000000000FA00000430700057
SaNdMaN
(SaNdMaN)
August 26, 2024, 11:35pm
5
Thank you for the data.
There’s something wrong that, it’s an incomplete installation.
Your unit is NA, right?.
It should have 9 map files, you only have 3.
It should have 3 voice_nav files, you have none.
Do you have the USB log for the USB you used for upgrading?, something is not right.
Since you went from 3.0 to 3.4, I would recommend you to create a new USB and share that log with us… if that’s ok, you can “upgrade it” again…
This one seemed to take longer to download onto the USB, I don’t have the original one. I didn’t think I needed it anymore so deleted it earlier today:
Version: 3.4.23188
Model: USB DISK 3.0 USB Device
; CyanLabs Syn3Updater 2.12.5.0 Stable - downgrade Mode - Sync 3.4.23188 NA
FILES (19)
[2024-08-26 5:55:32 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.23 (2023) - NA
[2024-08-26 5:55:32 PM] Install Mode: Auto-Detect (downgrade) Forced: False
[2024-08-26 5:55:32 PM] MY20 Protection: Disabled / Not MY20
[2024-08-26 5:55:32 PM] Formatting USB drive
[2024-08-26 5:55:32 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2024-08-26 5:56:05 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 5:56:05 PM] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 5:56:17 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 5:56:18 PM] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 5:56:18 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 5:56:18 PM] Downloading: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 5:56:18 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 5:56:18 PM] Downloaded: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 5:56:18 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2024-08-26 5:56:18 PM] Downloading: 1u5t-14g386-cb.tar.gz
[2024-08-26 5:56:21 PM] Validating: 1u5t-14g386-cb.tar.gz
[2024-08-26 5:56:21 PM] Downloaded: 1u5t-14g386-cb.tar.gz
[2024-08-26 5:56:21 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-08-26 5:56:21 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2024-08-26 5:56:21 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 5:56:21 PM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 5:56:30 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 5:56:31 PM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 5:56:31 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 5:56:31 PM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 5:56:43 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 5:56:45 PM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 5:56:45 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 5:56:45 PM] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 5:57:04 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 5:57:06 PM] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 5:57:06 PM] Checking Existing File: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 5:57:06 PM] Downloading: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 5:57:20 PM] Validating: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 5:57:22 PM] Downloaded: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 5:57:22 PM] Checking Existing File: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 5:57:22 PM] Downloading: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 5:57:38 PM] Validating: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 5:57:41 PM] Downloaded: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 5:57:41 PM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 5:57:41 PM] Downloading: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 5:58:09 PM] Validating: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 5:58:13 PM] Downloaded: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 5:58:13 PM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 5:58:13 PM] Downloading: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 5:58:29 PM] Validating: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 5:58:31 PM] Downloaded: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 5:58:31 PM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2024-08-26 5:58:35 PM] Validated: 4U5T-14G421-CHG_1709609492000.TAR.GZ (Skipping Download)
[2024-08-26 5:58:35 PM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 5:58:35 PM] Downloading: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 5:59:01 PM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 5:59:05 PM] Downloaded: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 5:59:05 PM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 5:59:05 PM] Downloading: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 5:59:31 PM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 5:59:34 PM] Downloaded: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 5:59:34 PM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 5:59:34 PM] Downloading: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:00:00 PM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:00:04 PM] Downloaded: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:00:04 PM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:00:04 PM] Downloading: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:00:35 PM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:00:40 PM] Downloaded: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:00:40 PM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:00:40 PM] Downloading: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:01:04 PM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:01:08 PM] Downloaded: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:01:08 PM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2024-08-26 6:01:13 PM] Validated: 4U5T-14G421-CBG_1709587496000.TAR.GZ (Skipping Download)
[2024-08-26 6:01:13 PM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2024-08-26 6:01:16 PM] Validated: 4U5T-14G421-CAG_1708029977000.TAR.GZ (Skipping Download)
[2024-08-26 6:01:16 PM] Preparing USB drive
[2024-08-26 6:01:17 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 6:01:17 PM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 6:02:01 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 6:02:07 PM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2024-08-26 6:02:07 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 6:02:07 PM] Copying: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 6:02:07 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 6:02:07 PM] Copied: GB5T-14G386-SC_85041.tar.gz
[2024-08-26 6:02:07 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2024-08-26 6:02:07 PM] Copying: 1u5t-14g386-cb.tar.gz
[2024-08-26 6:02:08 PM] Validating: 1u5t-14g386-cb.tar.gz
[2024-08-26 6:02:08 PM] Copied: 1u5t-14g386-cb.tar.gz
[2024-08-26 6:02:08 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-08-26 6:02:08 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-08-26 6:02:08 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-08-26 6:02:08 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2024-08-26 6:02:08 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 6:02:08 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 6:02:43 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 6:02:47 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2024-08-26 6:02:47 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 6:02:47 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 6:03:37 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 6:03:43 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2024-08-26 6:03:43 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 6:03:43 PM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 6:05:03 PM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 6:05:13 PM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2024-08-26 6:05:13 PM] Checking Existing File: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 6:05:13 PM] Copying: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 6:06:02 PM] Validating: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 6:06:08 PM] Copied: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[2024-08-26 6:06:08 PM] Checking Existing File: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 6:06:08 PM] Copying: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 6:07:20 PM] Validating: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 6:07:30 PM] Copied: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[2024-08-26 6:07:30 PM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 6:07:30 PM] Copying: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 6:09:26 PM] Validating: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 6:09:40 PM] Copied: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2024-08-26 6:09:40 PM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 6:09:40 PM] Copying: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 6:10:42 PM] Validating: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 6:10:50 PM] Copied: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2024-08-26 6:10:50 PM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2024-08-26 6:10:50 PM] Copying: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2024-08-26 6:12:23 PM] Validating: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2024-08-26 6:12:35 PM] Copied: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2024-08-26 6:12:35 PM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 6:12:35 PM] Copying: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 6:14:23 PM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 6:14:37 PM] Copied: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2024-08-26 6:14:37 PM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 6:14:37 PM] Copying: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 6:16:23 PM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 6:16:36 PM] Copied: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2024-08-26 6:16:36 PM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:16:36 PM] Copying: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:18:21 PM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:18:34 PM] Copied: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2024-08-26 6:18:34 PM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:18:34 PM] Copying: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:20:38 PM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:20:55 PM] Copied: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2024-08-26 6:20:55 PM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:20:55 PM] Copying: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:22:42 PM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:22:56 PM] Copied: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2024-08-26 6:22:56 PM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2024-08-26 6:22:56 PM] Copying: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2024-08-26 6:24:44 PM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2024-08-26 6:24:57 PM] Copied: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2024-08-26 6:24:57 PM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2024-08-26 6:24:57 PM] Copying: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2024-08-26 6:26:30 PM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2024-08-26 6:26:42 PM] Copied: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2024-08-26 6:26:42 PM] Generating reformat.lst
[2024-08-26 6:26:42 PM] Generating autoinstall.lst
[2024-08-26 6:26:42 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
SaNdMaN
(SaNdMaN)
August 27, 2024, 12:43am
7
That looks good.
Don’t you have a quality branded USB pendrive?, like Sandisk or Kingston…
The device you are using is generic… You can try that of course, but should it fail, consider using something better than that…
Thank you. I will try again. If it fails, I will buy a better USB and try that next week when I’m back from vacation. Very much appreciate your help.
SaNdMaN
(SaNdMaN)
August 27, 2024, 12:49am
9
Fair enough.
If everything goes ok remember to perform a master reset once it’s done.
It worked!!! I’ll do a master reset now. thank you so much for your time.
SaNdMaN
(SaNdMaN)
August 27, 2024, 8:44am
11
You are welcome, I’m glad everything went ok.
Take care.
