Sync 3.4 update with Nav F150 Lariat 2017 Ambient Lighting
Good day everyone. I’m new here
I recently performed the Sync 3.4 and Navigation update from 3.0
Really happy with all most everything, My ambient lighting only works with key off door open , once I start the engine lights dim away. The ambient selection is in settings but when it opens all light colors in circles are there but you not change anything. The colours or changing the brightness.
I have followed everything that has been on this topic in past posts. I did the reset. I did 5he master reset. I changed everything back to factory in FORScan Then performed another master reset. Nothing is helping.
Any help would be greatly appreciated
Thanks in advance all members.
Old SYNC Version: 3.4.20204
Syn3 Updater Version: 2.12.5.0 (Stable)
Version: 3.0.20204
Model: Lexar USB Flash Drive USB Device
Size:
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - RWData Cleaner
FILES (1)
[3/17/2024 12:27:05 PM] Selected Region:  - Release: RWData Cleaner - Map Version:
[3/17/2024 12:27:05 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[3/17/2024 12:27:05 PM] MY20 Protection: Auto-Detect
[3/17/2024 12:27:05 PM] Formatting USB drive
[3/17/2024 12:27:05 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[3/17/2024 12:27:13 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/17/2024 12:27:13 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[3/17/2024 12:27:13 PM] Preparing USB drive
[3/17/2024 12:27:13 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/17/2024 12:27:13 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/17/2024 12:27:13 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[3/17/2024 12:27:13 PM] Generating Autoinstall.lst
[3/17/2024 12:27:13 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
The Ambient Lighting feature was included with the 2017 Lariat’s optional Ultimate trim package, which was only available on the crew cab model.
It is possible that the APIM and BCM need to be reset. This can be done in FORScan. Also, if you performed asbuilt changes like returning modules to factory you should always reset the module. The APIM shows the controls for the ambient lighting, but when you try to adjust the controls do they snap back. Are the lights on or set to auto?
Performed reset n all modules, and master reset. The different closed lights do not move at all.
My truck is a crew cab
Sorry for the bad spelling
The circled coloured light selection d not move at all
Do the Ambient lights work when the Truck lights are on and it’s dark out? This was a change that was made. They don’t work during the daytime as you can’t see them anyways. This helped the lights last longer.
They are clearly working or they would not come on when you open the doors.
Yes I tried them at night in the dark. Headlight switch doesn’t matter if it is on auto or in the on position same result. When I started using FORScan 1 1/2 years ago before making any adjustments or changes I went into each module and saved as built After the update to 3.4 having this issue I went back into FORScan and changed all my modules back to orginal settings and performed a reset.
Good day all. Does anyone here have more ideas for me to try ?
Hi everyone I’m still looking for assistance with my issue
Can anyone please assist?
Thank you in advance
Hey team still waiting and looking for any help with my on going issues ?
Can you post your APIM AB settings?
Here yo go APIM As built F150 Lariat 2017 Crew cab
| APIM|7D0-01-01 |AA2A |0503 |06BB
| APIM|7D0-01-02 |02AB |0004 |820D |
| APIM|7D0-02-01 |4341 |0003 |C425 |
| APIM|7D0-02-02 |0A28 |8010 |44E1 |
| APIM|7D0-02-03 |2605 |07 | |
| APIM|7D0-03-01 |0000 |0103 |00DF |
| APIM|7D0-04-01 |0100 |1400 |0EFF |
| APIM|7D0-04-02 |0001 |DE | |
| APIM|7D0-05-01 |1A68 |1A68 |3D1E |
| APIM|7D0-05-02 |5432 | | |
| APIM|7D0-06-01 |805E | | |
| APIM|7D0-07-01 |4700 |3300 |0059 |
| APIM|7D0-07-02 |0000 |029A |007C |
| APIM|7D0-07-03 |0056 |5694 |0021 |
| APIM|7D0-07-04 |C8AA | | |
| APIM|7D0-08-01 |00E0 |0440 |0004 |
| APIM|7D0-08-02 |0000 |0000 |00E1 |
If these are your current AB settings than they all look correct. Maybe @F150Chief can take a look when he is back in and see what he thinks.
Thank you very much
I also just updated the APIM firmware
I wanted to add another issue that started after the sync update. My FordPass app doesn’t always connect like it did prior to update I have to cycle the key
There’s something you could try, that’s easy: try going back to 3.3.19xxxx.
You do not need to reformat if you keep your existing maps, then master reset and check if things get better.
Thank you very much I will try it and circle back with you.
Ok I have tried rolling it back. No change to my issues. Ambient lighting. FordPass not working all the time.
Just double checking but you have not changed any other modules or done any other wiring right?
There is nothing else other than the APIM that has been adjusted?
It was worth the shot, because 3.3.xxxxx is the closest to 3.0’s functionality and look&feel.
I’m also wondering if your vehicle is stock, or if there’s been some replacements in the past.
Another thing to consider is that maybe the upgrade / master reset reverted some values back, but the happens when the unit is not stock.
