SYNC 3 APIM WITH NO TOUCHSCREEN UPDATING 3.4
Hello ,
I have updated my FORD TRANSIT COURRIER 2021 to sync 3.4
But i have the sync 3 interface to big for the screen and no touchscreen
The keys for phone - setting and other not work
It’s possible to downgrade firmware for no touchscreen version ?
OEM VERSION BEFORE UPDATE SYNC 3.3.19066_PRODUCT
Thank you
APIM - Module d’interface de protocole des accessoires
Numéro de pièce: KU5T-14G371-KJA
Calibration level: KU5T-14G371-KJC (latest known: NU5T-14G371-KAC)
Strategie: 1U5T-14G374-DA
Calibration: 1U5T-14G375-AA
ACM - Module de commande audio
Numéro de pièce: JT76-18C815-HD
Calibration level: JT76-18C815-HD
Strategie: JT76-14C044-HD
SYNC Region: Europe
Navigation Variant: No
Old SYNC Version: 3.3.19066
New SYNC Version: SYNC 3.4
Syn3 Updater Version: -
So the APIM is a retrofit? A 2021 Transit Courrier would have had Sync 2.5 with the small screen?
The fix is to set the proper theme from 10" screen back to 8" screen with FORScan or UCDS and the recommended OBD adapter.
FORScan Tutorial Links - Ford / Information - CyanLabs Official Community
YES IS 2.5 SCREEN ONBOARD WITH NO TOUCHSCREEN
BEFORE UPDATE THE FIRMWARE IS 3.3 19066 PRODUCT
AFTER THE UPDATE ON 3.4 SEE THE PROBLEM ON THE PICTURE ATTACHED
AFTER UPDATE
AND VERSION OEM BEFORE UPDATE
You installed the 8" screen version of Sync 3.4. You will need to install the 4" screen version.
The latest version for the 4" screen is 5U5T-14G381-FS 409Mb Sync3 v3.4.21098 08.04.2021
Thank you very much for the quick response
Do you have à link for acces to software data base for 4 version ?
And just put the file in usb and insert in the car ?
Or it’s needed to use sync3 updater soft ?
Thanks :wink:
You can’t do this with the updater. But follow this:
Download the file 5U5T-14G381-FS
You need a blank USB formatted exfat. Just delete everything from the one you used before.
On the USB, make a folder called SyncMyRide.
Place the file on the USB in the SyncMyRide folder.
Copy the autoinstall.lst file to the root of the USB.
autoinstall.lst (219 Bytes)
USB
autoinstall.lst
SyncMyRide folder
5U5T-14G381-FS_1619032391000.TAR.GZ
Hi ,
After update i have ford boot logo and after black screen
The same after power and seek up key
Possible help me ?
Thank you :slight_smile:
Your unit might not like Sync 3.4.
Perform the same procedure again but with Sync 3.3.19066. See if it will go back to where it was.
Download the file 4U5T-14G381-BK
autoinstall.lst (205 Bytes)
Yes all it’s ok with 3.3 version
Thank you very much for the quick response and support :slight_smile:
Possible closed the request ?
It appears that the unit does not have enough memory to support Sync 3.4, as it is twice as large as Sync 3.3. Happy to help.
