This is a list of common error messages you may see:
Error Codes
NAVVOICE_ERR01 – Error is NAV_VOICE_ERROR
BGMAP_ERR01 – Error is BGMAP_ERROR
LIC_ERR01 – Error is MAP_LICENSE_MISMATCH_ERROR
LIC_ERR02 – Error is LICENSE_READING_ERROR
INSTL_ERR03 – Error is SCRIPT_PERMISSION_CHANGE_ERROR
INSTL_ERR04 – Error is SCRIPT_FILE_NOT_PRESENT_ERROR
INSTL_ERR05 – Error is POPUP_UTILITY_EXECUTION_ERROR
INSTL_ERR06 – Error is IMAGE_MOVING_ERROR
INSTL_ERR07 – Error is WRITING_NAV_LICENSE_TO_DPS_ERROR
INSTL_ERR08 – Error is APPS_TOGGLE_ERROR
INSTL_ERR09 – Error is IMAGE_TOGGLE_ERROR
INSTL_ERR10 – Error is APPS_UPDATE_BOOT_ERROR
INSTL_ERR11 – Error is APPS_UPDATE_PART_ERROR
INSTL_ERR12 – Error is DIR_CREATION_ERROR
INSTL_ERR13 – Error is UNMOUNT_ERROR
INSTL_ERR14 – Error is ACTIVATION_PENDING_ERROR
INSTL_ERR15 – Error is UNABLE_TO_FIND_PASSIVE_PARTITION_ERROR
LST_ERR03 – Error is LST_ERR_NO_APPROPRIATE_SECTION
LST_ERR04 – Error is LST_ERR_NO_SECTION
LST_ERR05 – Error is LST_PKG_FILE_NOT_FOUND
LST_ERR06 – Error is LST_ERR_MALICIOUS_CHAR – Fix: Make sure there are no spaces in filenames or other strange characters in the autoinstall.lst file
LST_ERR07 – Error is LST_ERR_NO_OPEN1_PARAM
LST_ERR08 – Error is LST_ERR_OPEN_LIMIT_EXCEEDED – Fix: you can only have 10 items in the autoinstall.lst, remove extras.
VER_ERR01 – Error is VER_UNABLE_TO_FIND_VER_FILE
VER_ERR02 – Error is VER_FPN_EMPTY
VER_ERR03 – Error is VER_ERR_PARSE_VER_INF
VER_ERR04 – Error is VER_FILENAME_EMPTY
VER_ERR05 – Error is VER_VIN_MISMATCH
VER_ERR06 – Error is VER_ESN_MISMATCH
VER_ERR07 – Error is VER_TIME_LIMIT_EXCEED
VER_ERR08 – Error is VER_SETTING_VER_INFO_ERROR
VER_ERR09 – Error is VER_SAVE_LOCATION_EMPTY_INVALID_ERROR
VER_ERR10 – Error is VER_FPN_VERSION_MOVING_IN_TMP_ERROR
VER_ERR11 – Error is VER_FPN_IMAGE_FILE_NOT_PRESENT
VER_ERR12 – Error is VER_FILE_HASH_VALUE_NOT_PRESENT
VER_ERR13 – Error is VER_FILE_SIZE_NOT_PRESENT
VER_ERR14 – Error is VER_PKG_TYPE_NOT_PRESENT
VER_ERR15 – Error is VER_FILE_NOT_PRESENT_TO_CALC_HASH
MEM_ERR01 – Error is MEM_NOSPACE_TO_COPY
MEM_ERR03 – Error is MEM_NOSPACE_TO_EXTRACT
PKG_ERR02 – Error is PKG_DWNLD_PKG_NOT_FOUND
PKG_ERR03 – Error is PKG_UNTAR_FAILURE
PKG_ERR04 – Error is PKG_REVOKED (Package has been blacklisted)
PKG_ERR06 – Error is UNKNOWN (Restart usually fixes this)
Signature Errors (Issues caused by invalid Version.der files)
SIGN_ERR01 – Error is UNSIGN_ERROR
SIGN_ERR02 – Error is SIGN_HASH_VALUE_MISMATCH
SIGN_ERR03 – Error is SIGN_CERTS_NOT_PRESENT_ON_SYNC
SIGN_ERR04 – Error is INSTALL_ERROR
SIGN_ERR05 – Error is SCRIPT_INSTALL_ERROR
