Sync 3 GPS antenna cable
Can someone suggest a good aftermarket GPS antenna for my BTVC to sync 3 conversion of my 2012 Ford Focus ST in Australia. Is a setting that i need to set with forscan to make the navigation work properly. The apim originally came with sync 3.2.2 and navigation worked ok. But after upgrading to build 3.3 using syn 3 updater, the navigation is hit or miss Wether it wants to work. So i think the antenna is a bit of rubbish.
SYNC Region: ANZ
Old SYNC Version: 2.2.16280
New SYNC Version: 3.3.19052
Navigation fault. Navigation is not functioning properly. Please visit you dealer for service.
Syn3 Updater Version: Syn3 updater 2.0
CYANLABS - SYN3 UPDATER - V2.13.1.0
Version: 3.4.23188
Region: ANZ
Install Mode: downgrade (downgrade)
Install Mode Overridden: True
Model: Lexar USB Flash Drive USB Device
VOICE=4U5T-14G391-DJ_1552513867000.TAR.GZ
GRACENOTES=4U5T-14G423-DA_123696.tar.gz
; CyanLabs Syn3Updater 2.13.1.0 Stable - downgrade FORCED  Mode - Sync 3.3.19052 ANZ
FILES (6)
4U5T-14G391-DJ_1552513867000.TAR.GZ (1GB)
4U5T-14G423-DA_123696.tar.gz (716.5MB)
[13/03/2025 7:10:44 PM] Selected Region: ANZ - Release: Sync 3.3.19052 - Map Version: Keep Existing Maps
[13/03/2025 7:10:44 PM] Install Mode: downgrade (downgrade) Forced: True
[13/03/2025 7:10:44 PM] MY20 Protection: Disabled / Not MY20
[13/03/2025 7:10:44 PM] Formatting USB drive
[13/03/2025 7:10:44 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[13/03/2025 7:10:53 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:10:55 PM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[13/03/2025 7:10:55 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:10:55 PM] Downloading: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:10:56 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:10:56 PM] Downloaded: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:10:56 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[13/03/2025 7:10:57 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[13/03/2025 7:10:57 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[13/03/2025 7:10:57 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[13/03/2025 7:10:57 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:10:58 PM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[13/03/2025 7:10:58 PM] Checking Existing File: 4U5T-14G391-DJ_1552513867000.TAR.GZ
[13/03/2025 7:11:05 PM] Validated: 4U5T-14G391-DJ_1552513867000.TAR.GZ (Skipping Download)
[13/03/2025 7:11:05 PM] Checking Existing File: 4U5T-14G423-DA_123696.tar.gz
[13/03/2025 7:11:08 PM] Validated: 4U5T-14G423-DA_123696.tar.gz (Skipping Download)
[13/03/2025 7:11:08 PM] Preparing USB drive
[13/03/2025 7:11:08 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:11:08 PM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:11:50 PM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:11:51 PM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:11:51 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:11:51 PM] Copying: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:11:51 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:11:51 PM] Copied: GB5T-14G386-SC_85041.tar.gz
[13/03/2025 7:11:51 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[13/03/2025 7:11:51 PM] Copying: 1u5t-14g386-cb.tar.gz
[13/03/2025 7:11:52 PM] Validating: 1u5t-14g386-cb.tar.gz
[13/03/2025 7:11:52 PM] Copied: 1u5t-14g386-cb.tar.gz
[13/03/2025 7:11:52 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[13/03/2025 7:11:52 PM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[13/03/2025 7:11:52 PM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[13/03/2025 7:11:52 PM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[13/03/2025 7:11:52 PM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[13/03/2025 7:11:54 PM] 4U5T-14G381-AN_1552583626000.TAR.GZ exists and validated successfully, skipping copy
[13/03/2025 7:11:54 PM] Checking Existing File: 4U5T-14G391-DJ_1552513867000.TAR.GZ
[13/03/2025 7:11:54 PM] Copying: 4U5T-14G391-DJ_1552513867000.TAR.GZ
[13/03/2025 7:13:10 PM] Validating: 4U5T-14G391-DJ_1552513867000.TAR.GZ
[13/03/2025 7:13:14 PM] Copied: 4U5T-14G391-DJ_1552513867000.TAR.GZ
[13/03/2025 7:13:14 PM] Checking Existing File: 4U5T-14G423-DA_123696.tar.gz
[13/03/2025 7:13:14 PM] Copying: 4U5T-14G423-DA_123696.tar.gz
[13/03/2025 7:14:08 PM] Validating: 4U5T-14G423-DA_123696.tar.gz
[13/03/2025 7:14:11 PM] Copied: 4U5T-14G423-DA_123696.tar.gz
[13/03/2025 7:14:11 PM] Generating reformat.lst
[13/03/2025 7:14:11 PM] Generating autoinstall.lst
[13/03/2025 7:14:11 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
This would be the one that I use and F150Chief recommended in his write up.
With the car being an older model you might want to consider 3.4.21194 or 3.4.21265 for your 3.4 build
Thank you for this information. Will look into that.
