I got a kuga from 2020 from the usa. It has a black screen, most likely someone did a reformat. How do I fix the unit ?? I read a dump eemc. Unfortunately, Please help.
If this is how you received the car then I would first try and take it up with whoever sold it to you. By attempting a reformat on a MY20+ vehicle they essentially bricked the unit.
The only way to recover from this is to either try attaching an older screen and downgrading the firmware on the APIM to accept the older screen (completing the reformat) or replacing it outright with a new one.
It’s the same, I would install the lastest one.
Just to be clear, reformat tool does not have proper drivers for the screen. Once you bypass that by changing to older hardware, then it should work. After your are done, it does not really matter which screen you leave on.
Issue is with the reformat tool not supporting that hardware, it’s not a Sync3 issue.
If I understand correctly. I will update the software itself and mark SYNC Updater MY20 (active), this should make me a proper flash drive that will bring the original screen back to life.
Well, no. Using the reformat tool has disabled the MY20 screen, since the drivers are not correct. You will need FORScan to correct this. Read the attached, it will help…
Hello, I just bought a SYNC 3 from ford it was manufactured in 2021 but it comes with version 3.0, here is its seire number L06R002M I would like to know if it is therefore a MY20? how can i find out if it’s a MY20?
Is it installed? You are looking for the production number, it will look something like LU5T-14G370-xx. It will be on the label on the back of the unit, the finned side.
Indeed it is for an older car not the transit. however I confirm manufacture 2021 purchase in concession. How can I find out if it’s a MY20? I have the log file
Syn3 Updater would tell you if you ran the interrogator tool though it and opened your XML log file with it, the starting letter e.g J means it’s old, 5 and L are new.
