Good morning, everyone.
I have a Sync 3 retrofitted into a Ford Edge Titanium that originally came with Sync 2. I did the retrofit using a screen and an APIM probably from a Ford Ranger (JB3T-14G370-MEF) with navigation. Because the front camera was not working, I made some updates using FORScan, and it did fix the camera, but it ended up causing a problem with the native navigation.
In an attempt to fix the navigation issue, I performed an update using Sync3 Updater, and since I was not completely sure whether my APIM was (or was not) a MY20 unit, I ran the update process using the downgrade option (MY20 protection ā auto-enable).
Anyway, the first part went well, and my Sync 3 went back to version 3.3.19052. The software then asked me to turn off the car, but right after that it went to a black screen and never came back. I tried the standard procedures, such as a soft reset, removing the fuse, and disconnecting the battery, but my Sync 3, which was working on 3.4.20146, apparently got ābrickedā (black screen).
Question: According to the logs, was my Sync 3 a MY20 unit? Is it really bricked?!
I ran the Interrogator beforehand exactly to try to make sure that the APIM was not a MY20 unit, in order to avoid this kind of problem. Another confusing point: the sticker on the APIM shows JB3T-14G370-MEF, but the Interrogator identifies it as KU5T-14G371-EJA.
Now, analyzing it more carefully using FORScan, I see that the āCalibration Levelā does not match the files. If the Sync 3 is not actually bricked, how can I fix this, since FORScan does not allow me to flash the file ā1U5T-14G375-DA.vbfā, which, according to my research, was the one installed before the update process?
Thanks for the help.
Bruno
SYNC Region: ANZ
Old SYNC Version: 3.4.20136
New SYNC Version: 3.4.20136
Current behavior: black screen only, with the USB ports lighting up blue for about 10 seconds.
https://drive.google.com/drive/folders/1PFXWcd3WaTjXwaOEgmJCFokAXJf_ZCef?usp=sharing
