Sync 3 Retrofit Illumination Issue
I have retrofitted Sync3 to my 2015 S-Max (early mk2) but I seem to be having an issue with the screen thinking it is dark.
The screen boots up, but then immediately dims, and goes into night mode.
I have tried reconfiguring and building from the ground up. The asbuilt appears to be correct for my vehicle type.
AsBuilt
7D0-01-01 0B6A 255A B0**
7D0-01-02 023E 6A46 C2**
7D0-02-01 554B 0104 03**
7D0-02-02 5354 8020 20**
7D0-02-03 2660 **
7D0-03-01 0200 0002 00**
7D0-04-01 0100 1B00 26**
7D0-04-02 0007 **
7D0-06-01 80**
All other illumination in the cabin works as expected.
I do have an active DTC U0155 so i know there is a communication issue between APIM and IPC
Install Type: Replica
Old SYNC Version: 2.0
No error
Not sure if this helps.
APIM S/N: WV6000GB
Assembly part number: HB5T-14G371-CAG
H/W Part Number: HB5T-14G380-BA
CCPU S/W Part Number: NU5T-14G381-AD
Or if any of the other part numbers or whatever will help.
