Sync 3 sound settings not saving
Hello All, I did a Sync 1-3 swap in my focus. The Apim is from a 2016 titanium with navigation. ACM is original. I used a AB for a similar model Focus with Sync3 and it worked all but the Sound settings and volume message does not pop up when changing volume. I am updated to the latest 3.4 at time of this post.
Install Type: OEM Replacement
Old SYNC Version: 1.0
Unable to connect to ACM
Syn3 Updater Version: Newest
Can't rn
The APIM config is wrong for your car, the Ti has the Sony audio, you’ve got the basic audio.
This is something you fix with ForScan, its not a Sync problem.
I understand. I guess my problem is other than just copying Apim data with one from a similar year with Sync 3 I have no idea where to to start on what line to adjust to make the two be able to communicate. Any help would be good
This database is you friend….
Sync 3 APIM Database - CyanLabs
If you cant figure out what to change than start by posting your APIM AB here so we can look at it.
You’re not copying directly APIM to APIM.
An APIM from a Ti will be expecting a Sony DSP and a XM radio capable ACM.
Look at 7D0-01-01
Thank you guys using the database I got my solution. I had never seen that database before. Thank you!
