Sync 3 Update Failed Leading To Issues
The car is a 2015 F150 xl orignally with a sync 1 and I swapped it to a sync 3 and everything was working fine, I went to update the sync 3 and after pluggin in the usb to update for like 2 minutes the screen went black and then a hour passed and I tried staring the screen it wouldn’t start, I tried many things from rebooting the APIM to creating a reformat and many other solutions from help from ai (A lot of methods, A lot) the usb doesn’t work the screen is black, using Forscan I can connect to the APIM and configure it and it reads normally, there is not DTCs on the APIM, Please help me.
SYNC Region: ROW
Old SYNC Version: 3.0.20204
The Screen Is Black So I Can’t See Anything
Version: 3.0.20204
Region: ROW
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat  Mode - Sync 3.4.23188 ROW
FILES (4)
[1/10/2026 12:28:05 AM] Selected Region: ROW - Release: Sync 3.4.23188 - Map Version: Non Nav APIM
[1/10/2026 12:28:05 AM] Install Mode: Auto-Detect (reformat) Forced: False
[1/10/2026 12:28:05 AM] MY20 Protection: Disabled / Not MY20
[1/10/2026 12:28:05 AM] Formatting USB drive
[1/10/2026 12:28:05 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[1/10/2026 12:28:14 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/10/2026 12:28:14 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[1/10/2026 12:28:14 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/10/2026 12:28:14 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[1/10/2026 12:28:14 AM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[1/10/2026 12:28:14 AM] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[1/10/2026 12:28:14 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/10/2026 12:28:18 AM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[1/10/2026 12:28:18 AM] Preparing USB drive
[1/10/2026 12:28:18 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[1/10/2026 12:28:18 AM] Copying: 1u5t-14g386-cb.tar.gz
[1/10/2026 12:28:19 AM] Validating: 1u5t-14g386-cb.tar.gz
[1/10/2026 12:28:19 AM] Copied: 1u5t-14g386-cb.tar.gz
[1/10/2026 12:28:19 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/10/2026 12:28:19 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/10/2026 12:28:20 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/10/2026 12:28:20 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[1/10/2026 12:28:20 AM] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[1/10/2026 12:28:20 AM] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[1/10/2026 12:28:23 AM] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[1/10/2026 12:28:23 AM] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[1/10/2026 12:28:23 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/10/2026 12:28:23 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/10/2026 12:29:08 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/10/2026 12:29:11 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[1/10/2026 12:29:11 AM] Generating reformat.lst
[1/10/2026 12:29:11 AM] Generating autoinstall.lst
[1/10/2026 12:29:12 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Since you have forscan, share the APIM model.
It just says sync 3
The module listing says just Sync3 for the APIM? Share a screenshot…
I can’t at the moment but yes the warning it usually gives before entering the module configuration
I do not know what you mean, you do not need to enter the configuration to see the module’s model, like any other module on the car (BCM, ACM…)
Review Forscan and once you get the APIM model (PN contains 14G371 in the middle), share it with us. Or unmount the unit and share a picture of the sticker on its back.
Ok I will try to get that done, how can I do it through for scan?
I’m not a Forscan user, so I cannot guide you. You are looking for something like this:
Try googling for it, or watching some tutorial on Youtube for step by step.
it sounds like MY20 unit
It’s not there isn’t the u3000 code which mean its bricked
What do I do once I get this number?
What now?
APIM JR3T-14G371-BJD is MY20, you can’t reformat MY20 hardware as clearly warned, so you killed it by reformatting it.
Your options are limited:
