jm1
(J M)
17 October 2022 16:09
1
I need help, after update sync 3 on latest version my screen is blank.
Master reset doesn´t work.
BR
Jozef M.
SYNC Region: Europe
Navigation Variant: Yes
Old SYNC Version: 3.4.21265
New SYNC Version: 3.4.22200
only black screen
Syn3 Updater Version:
SaNdMaN
(SaNdMaN)
17 October 2022 16:14
2
As requested by the template, provide the log of the USB you used.
But since you have a black screen and your vehicle is 2021, it seems you have just bricked your unit.
Either way, post your logs.
jm1
(J M)
17 October 2022 16:24
4
Thanks for answer.
in attched please see log
Sync_WZ823SX2_WF02K8GY3LGC84345.xml (12.1 KB)
SaNdMaN
(SaNdMaN)
17 October 2022 16:30
5
That’s not what I asked, that’s an interrogator log.
From that, the part number for the APIM is 5U5T-14G371-GMD.
What we need to see is your syn3updater log.
It’s on the USB’s root, or in the computer you used to create the USB.
jm1
(J M)
17 October 2022 16:50
10
It seem that I don´t have it. Problem became when I start NAV update.
JM
SaNdMaN
(SaNdMaN)
17 October 2022 16:51
11
Unless you erased it, you must have it.
Check syn3updater, the LOGs tab.
Here is the deal: your APIM is MY20.
If the log says you attempted a reformat or downgrade to update maps, then the unit is DEAD.
But I need to see the log to confirm that.
Right now, based on your description, I’m 90% certain this is the case.
jm1
(J M)
17 October 2022 16:52
12
If I have bricked SYNC unit , is there possibility solve it.If I have bricked SYNC unit , is there possibility solve it.
SaNdMaN
(SaNdMaN)
17 October 2022 16:53
13
Sadly, no.
As a consumer, we do not have the required tools.
jm1
(J M)
17 October 2022 16:56
14
But the vehicle is still under warranty
SaNdMaN
(SaNdMaN)
17 October 2022 16:57
15
But you didn’t use Ford’s method to upgrade, right?.
So that warranty is now voided.
jm1
(J M)
17 October 2022 16:58
16
I used official way for update.
SaNdMaN
(SaNdMaN)
17 October 2022 17:00
17
Let me get this clear…
You didn’t use Syn3updater at any point?.
If you didn’t, upload the contents of the USB Ford Provided you.
Specially the autoinstall.lst file, or any other .lst file on the USB’s root.
jm1
(J M)
17 October 2022 17:04
19
autoinstall.lst (1.5 KB)
in attachment please find
SaNdMaN
(SaNdMaN)
17 October 2022 17:07
20
Thank you. That’s the only .lst file, right?.
Also, does the unit work besides the black screen?.
I mean, does the audio work for example?.
Are USB ports powered?.
jm1
(J M)
17 October 2022 17:16
21
Yes, radio is working, USB is only flashing.
jm1
(J M)
17 October 2022 17:27
23
please see printscreen of usb
CyanLabs
(CyanLabs)
17 October 2022 17:42
25
If you have used an official update take the car to ford for warranty
jm1
(J M)
17 October 2022 17:53
26
I unplugged sync fuse no. 15 position.
jm1
(J M)
17 October 2022 18:06
28
yes I will, but way they offering for owners and it isn´t working.
Thanks for time.
Jozef
