I received the following error message and would like to ask if I can perform the update in the vehicle?
Old SYNC Version: 3.4.21194
New SYNC Version: 3.4.26057
Fehler
Die ausgewählte XML-Datei enthält keine gültige “ECU Delivery Assembly Number”. Es kann daher nicht festgestellt werden, ob es sich um ein My20+ APIM handelt oder nicht.
Erstelle einen Beitrag im Community-Forum oder auf unserem Discord, um das weitere Vorgehen zu bestimmen.
STOP!: FAHRE AUF KEINEN FALL OHNE HILFE EINES EXPERTEN FORT!
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2026-06-23" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0FXXWPMHNS85388</p:VIN>
<p:RequestRole>
</p:RequestRole>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>5U5T-14G381-ET</d2p1:Response>
</d2p1:DID>
<d2p1:Response>315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424648000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424848000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414700000000000000000000345535542d3134473432322d424146000000000000000000345535542d3134473432322d424246000000000000000000345535542d3134473432322d424346000000000000000000345535542d3134473432322d424446000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415200000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>N12T00DK</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>
</d2p1:Response>
</d2p1:DID>
<d2p1:Response>3c:e4:b0:07:b8:72</d2p1:Response>
</d2p1:DID>
<d2p1:Response>3c:e4:b0:07:b8:73</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2026-06-23T17:01:00+00:00" RAM="1031282688" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="892K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="21M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="396K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.7M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="24M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="27M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.9G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.3G" available="25M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.6G" available="35M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="820M"/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="87M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="132M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="71M" available="476K"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="11G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>MIIEdAYJKoZIhvcNAQcDoIIEZTCCBGECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBAJ6E8nLXR4MBDt5KAWFvaPkCURM9hhmd/Uj2aZODu/mtSlMHH4Ep5XFpALBFdkGc2g8OkFwGGVfEdcdieG8v9J7hPcGmUNUrcGfTjqWMxyxRYlAAEOlfOFvNbCqlH3qEDSZo76s1WFdHcGJmk7fB96zC4LwffOo5KvxauxNs0lwjUcOX5os3t+pqBaJQ+7wpKko2q//zBbjOQDO8IZzfIYlWhTwMhp86fTLQ9fEax/cGBicq0rT5JEkVdsWrdS8aoBIHspuKYvQzZ/E6ZeDXAyFr8nuCjM0yeNj+scebqSAkXC7gdCwLcHeNYHqNlQE0DvrQQrKhs0hYFhmxNDYQEKMwggKeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBDpUMQbZzSRx221Vm0+QHBhgIICcNqslbc3KsZlC/NzW6t/JcO/1xNIdEmogk7p4OsLGzzzwx2THJiHsfNENfNnI8CS+yzlahXgVUEPn9u/yJqSD1SiRKezRHeQImEhzC7btI5I7KBNOCNj6RzEu8sTBs7H2qf53FTWGPpkIWOiBypZwNICjwUmPoggpgKHiiDyG4Ak6JVbYS4kN9wz8I0dNx3O1mD0PkMbFWXg+5pSEme6b2xJ+WCcOEb18K2Ix8OLlYQg70uMe9OPpQAthtNs9Eu7MKjbtUCr7LAWbyGqTDQ6SUroByxZcPTINtcka+cqaQcxvV36ppTn8RtyTOxVHnm3L2thaxgN3gu/z0sR6Vu4VH9SdpHHbRobFW3GyJI3snNy9AKPpzieYUO6XTXq0xs2pgoMunsLBBPAuLPVNRBGPI3/6MY1y/pjO6+HA+LCHdAK7DUzEx+b6z3SCxvADWWlf31kDDPjcqklbNieMlXgVzCpeJ8AuTPhCUS9PI8WJ/liaycjwVdYG1ufrJ3VmE9gGo5nv6VAo/HdKy7L/uhoBHKEe9UXXvYk6xoYgPDsriVKSP2zKG2ZO8jNY3/JgAAlZFnKvNM/H/7xW+C2izWVBnmzJIGXLZaM78luY2fC5Pql9I1OL6K3zejeUcst/U1jFsyZBHyo1s4zhgxB6gnuI8URRDxx+CVnvLsZWQTL7WRMHPkDe7X6vKTgZfitq1YrJ8+HFoSxi4NvL/Y43jx4T19fO03CntleN08vg9FPaEFk7zfgoTXzvSYzQrf+XLUVRSwYIxSV6puBantznsuvz+KSPudGGHLfu+VyiUUBKppMqgLNyerII3R7uZdR9xd9Dw==</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Version: 3.4.21194
Install Mode: Automatische Erkennung (autoinstall)
My20 Protection Enabled: Aktiviert
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Sync 3.4.26057 EU
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 1U5T-14G424-BP_1748959609000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G424-BP_1748959609000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BHM_1748462644000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BHM_1748462644000.TAR.GZ
Item4 = MAP - 1U5T-14G421-BAM_1748461682000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G421-BAM_1748461682000.TAR.GZ
Item5 = VOICE_NAV - 4U5T-14G422-BAM_1748464396000.TAR.GZ
Open5 = SyncMyRide\4U5T-14G422-BAM_1748464396000.TAR.GZ
Item6 = APPS - NU5T-14G381-AE_1778770590000.TAR.GZ
Open6 = SyncMyRide\NU5T-14G381-AE_1778770590000.TAR.GZ
Item7 = MAP - 1U5T-14G421-BBM_1748459859000.TAR.GZ
Open7 = SyncMyRide\1U5T-14G421-BBM_1748459859000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 1U5T-14G421-BFM_1748461472000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G421-BFM_1748461472000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BGM_1748462187000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BGM_1748462187000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BEM_1748461035000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BEM_1748461035000.TAR.GZ
Item4 = MAP - 1U5T-14G421-BCM_1748460093000.TAR.GZ
Open4 = SyncMyRide\1U5T-14G421-BCM_1748460093000.TAR.GZ
Item5 = GRACENOTES - 4U5T-14G423-AC_1615425645000.TAR.GZ
Open5 = SyncMyRide\4U5T-14G423-AC_1615425645000.TAR.GZ
Item6 = ENH_DAB - 1U5T-14G658-AH_1644006443000.TAR.GZ
Open6 = SyncMyRide\1U5T-14G658-AH_1644006443000.TAR.GZ
Item7 = MAP - 1U5T-14G421-BJM_1748462970000.TAR.GZ
Open7 = SyncMyRide\1U5T-14G421-BJM_1748462970000.TAR.GZ
Item1 = VOICE_NAV - 4U5T-14G422-BBM_1748464677000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BBM_1748464677000.TAR.GZ
Item2 = VOICE_NAV - 4U5T-14G422-BDM_1748465073000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G422-BDM_1748465073000.TAR.GZ
Item3 = VOICE_NAV - 4U5T-14G422-BCM_1748464896000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G422-BCM_1748464896000.TAR.GZ
Item4 = VOICE - 5U5T-14G391-AT_1660763323000.TAR.GZ
Open4 = SyncMyRide\5U5T-14G391-AT_1660763323000.TAR.GZ
Item5 = MAP - 1U5T-14G421-BDM_1748460770000.TAR.GZ
Open5 = SyncMyRide\1U5T-14G421-BDM_1748460770000.TAR.GZ
FILES (19)
NU5T-14G381-AE_1778770590000.TAR.GZ (869,9MB)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2,5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539,6MB)
1U5T-14G421-BCM_1748460093000.TAR.GZ (1,8GB)
1U5T-14G421-BDM_1748460770000.TAR.GZ (1,1GB)
1U5T-14G421-BEM_1748461035000.TAR.GZ (1,8GB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2,5GB)
1U5T-14G421-BGM_1748462187000.TAR.GZ (2,1GB)
1U5T-14G421-BHM_1748462644000.TAR.GZ (2,6GB)
1U5T-14G421-BJM_1748462970000.TAR.GZ (26MB)
4U5T-14G422-BAM_1748464396000.TAR.GZ (2,4GB)
4U5T-14G422-BBM_1748464677000.TAR.GZ (2,3GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1,8GB)
4U5T-14G422-BDM_1748465073000.TAR.GZ (2,1GB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1,7KB)
[25.06.2026 08:00:24] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: F13 (2024) - EU (09 2025)
[25.06.2026 08:00:24] Install Mode: Automatische Erkennung (autoinstall) Forced: False
[25.06.2026 08:00:24] MY20 Protection: Aktiviert
[25.06.2026 08:00:24] Formatting USB drive
[25.06.2026 08:00:24] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[25.06.2026 08:00:34] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.06.2026 08:00:34] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[25.06.2026 08:00:34] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.06.2026 08:00:41] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[25.06.2026 08:00:41] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.06.2026 08:00:44] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[25.06.2026 08:00:44] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.06.2026 08:00:44] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[25.06.2026 08:00:44] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[25.06.2026 08:00:49] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[25.06.2026 08:00:49] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[25.06.2026 08:01:00] Validated: 1U5T-14G421-BAM_1748461682000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:00] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[25.06.2026 08:01:02] Validated: 1U5T-14G421-BBM_1748459859000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:02] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[25.06.2026 08:01:11] Validated: 1U5T-14G421-BCM_1748460093000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:11] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[25.06.2026 08:01:17] Validated: 1U5T-14G421-BDM_1748460770000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:17] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[25.06.2026 08:01:25] Validated: 1U5T-14G421-BEM_1748461035000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:25] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[25.06.2026 08:01:38] Validated: 1U5T-14G421-BFM_1748461472000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:38] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[25.06.2026 08:01:48] Validated: 1U5T-14G421-BGM_1748462187000.TAR.GZ (Skipping Download)
[25.06.2026 08:01:48] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[25.06.2026 08:02:01] Validated: 1U5T-14G421-BHM_1748462644000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:01] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[25.06.2026 08:02:01] Validated: 1U5T-14G421-BJM_1748462970000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:01] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[25.06.2026 08:02:12] Validated: 4U5T-14G422-BAM_1748464396000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:12] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[25.06.2026 08:02:23] Validated: 4U5T-14G422-BBM_1748464677000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:23] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[25.06.2026 08:02:32] Validated: 4U5T-14G422-BCM_1748464896000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:32] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[25.06.2026 08:02:42] Validated: 4U5T-14G422-BDM_1748465073000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:42] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[25.06.2026 08:02:42] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[25.06.2026 08:02:42] Preparing USB drive
[25.06.2026 08:02:42] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.06.2026 08:02:42] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.06.2026 08:02:42] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.06.2026 08:02:42] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[25.06.2026 08:02:42] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.06.2026 08:02:42] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.06.2026 08:03:41] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.06.2026 08:03:54] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[25.06.2026 08:03:54] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.06.2026 08:03:54] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.06.2026 08:04:24] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.06.2026 08:04:31] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[25.06.2026 08:04:31] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.06.2026 08:04:31] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.06.2026 08:04:35] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.06.2026 08:04:36] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[25.06.2026 08:04:36] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[25.06.2026 08:04:36] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[25.06.2026 08:05:17] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[25.06.2026 08:05:28] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[25.06.2026 08:05:28] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[25.06.2026 08:05:28] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[25.06.2026 08:07:26] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[25.06.2026 08:08:09] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[25.06.2026 08:08:09] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[25.06.2026 08:08:09] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[25.06.2026 08:08:35] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[25.06.2026 08:08:44] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[25.06.2026 08:08:44] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[25.06.2026 08:08:44] Copying: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[25.06.2026 08:10:10] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[25.06.2026 08:10:41] Copied: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[25.06.2026 08:10:41] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[25.06.2026 08:10:41] Copying: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[25.06.2026 08:11:28] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[25.06.2026 08:11:47] Copied: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[25.06.2026 08:11:47] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[25.06.2026 08:11:47] Copying: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[25.06.2026 08:13:14] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[25.06.2026 08:13:43] Copied: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[25.06.2026 08:13:43] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[25.06.2026 08:13:43] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[25.06.2026 08:15:41] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[25.06.2026 08:16:24] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[25.06.2026 08:16:24] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[25.06.2026 08:16:24] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[25.06.2026 08:18:02] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[25.06.2026 08:18:38] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[25.06.2026 08:18:38] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[25.06.2026 08:18:38] Copying: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[25.06.2026 08:20:39] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[25.06.2026 08:21:22] Copied: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[25.06.2026 08:21:22] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[25.06.2026 08:21:22] Copying: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[25.06.2026 08:21:23] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[25.06.2026 08:21:24] Copied: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[25.06.2026 08:21:24] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[25.06.2026 08:21:24] Copying: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[25.06.2026 08:23:25] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[25.06.2026 08:24:06] Copied: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[25.06.2026 08:24:06] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[25.06.2026 08:24:06] Copying: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[25.06.2026 08:26:00] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[25.06.2026 08:26:45] Copied: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[25.06.2026 08:26:45] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[25.06.2026 08:26:45] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[25.06.2026 08:28:03] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[25.06.2026 08:28:32] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[25.06.2026 08:28:32] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[25.06.2026 08:28:32] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[25.06.2026 08:30:14] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[25.06.2026 08:30:52] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[25.06.2026 08:30:52] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[25.06.2026 08:30:52] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[25.06.2026 08:30:52] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[25.06.2026 08:30:52] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[25.06.2026 08:30:52] Generating Autoinstall.lst
[25.06.2026 08:30:52] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
