SYNC 3 v 3.4 22251 update
Hello.There are problems with operation SYNC 3 v 3.4 22251, namely the language is reset from the set one to English, and the Bluetooth connection is also lost. I’m trying to update via Syn3Updater with a downgrade, but the following error appears on the screen. INSTL_ERR12. This machine originally had version 2.2, but I updated it to version 3.4.20237 and then to version 3.4.22251. I used the current version (3.4.22251) for a year and a half until the errors described above appeared. Tell me what could be the problem? Thanks
Old SYNC Version: 2.2.16223
New SYNC Version: 3.4.22251
INSTL_ERR12
You need to get out of 3.4.22251 since it’s bugged.
Follow this guide → APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates (Solved)
And if you want to try using Ford’s method to get to 3.4.23188 which is the current release.
Here’s the link for:
EU\NAV
https://ivsu.binaries.ford.com/owner-package/8351300145/NU5T-14G381-AD.zip
