Sync 3 v3.4.20282 Officially Releases
@hallstevenson,
The non-nav units have issues with logos. Have you seen any solution over on the Fusion forum?
Nope. I suspect there is no solution and it’s working as-designed.
I tried downloading the files from the FORD site for my 2020 Expedition. The VIN check advised an update was available. There were only 6 files in the I went to the CYAN app and it only downloaded 3 files, same result. Any idea what I can do now?
Ford uses scripting to check for hardware and software versions to determine if you are eligible for an update. The CyanLabs method does not include those files, therein lies the difference. They are exactly the same files in either case, you can check the file hash values in the Software Database on this site.
Ok so when I try and install the usb, I get a red screen with the ERROR UPDATE PACKAGE NOT FOUND. Do you have experience with that?
Can you take a pic and post it here?
Did you use the Syn3 Updater? If so, can you post the log file from the usb or app
These are the files from the Ford site
Couple of things,
  1. you appear to be using a external hard drive, this is not a good idea, atleast i assume so based on “EXHDD”
  2. Do you have other devices plugged in?
  3. Your APIM is currently in Reformat mode and you are trying to install autoinstall.lst this WILL not work
This is clearly a 4 inch screen, you are in reformat mode, and you are trying to autoinstall. I don’t understand how you got to this point using a manufacturer package pictured. At some point you used an autoinstall with the reformat file, and now you are stuck in reformat mode.
Maybe this will work. We are going to use only 2 of the file in the picture and make a reformat installation disk. Use a real thumb drive, please. USB 3.0 if you have it.
5U5T-14G381-FK
5U5T-14G391-BM
Place these 2 files on the usb in a folder named SyncMyRide.
Create a text file using notepad and name it ‘reformat.lst’. Make sure it does not have a .txt extension. This file will be placed in the root of the USB.
Copy this into the file and save it.
APPS=5U5T-14G381-FK.TAR.GZ
VOICE=5U5T-14G391-BM.TAR.GZ
Copy the DONTINDX.MSA file from your other source and place it in the root of the USB.
You should now have this:
Usb (root)
> reformat.lst
> DONTINDX.MSA
> SyncMyRide (folder)
Place this in the vehicle and see if it installs. Unplug all other devices, including phones.
This at worked thank you
Glad to help.
If you want to load Gracenotes, you can do this separately
See this tutorial:
Tutorial: No Gracenotes After Sync 3.4 Installation. Manual Installation Instructions - Ford / Guides & Info - CyanLabs Official Community
Item1 = GRACENOTES - 4U5T-14G423-CB_1598636132000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-CB_1598636132000.TAR.GZ
Options = Autoinstall
