Sync 3 very laggy but fine with USB stick inserted. Sync 3.0.20204 with EU2.21 maps failing installation
Run the Interrogator Utility as @SaNdMaN suggested so we can take a look. Post the results here…
I wasn’t too much bothered about the Gracenotes, but will run the Interrogator and post it, just to see if everything is ok! I may even give a try to the Gracenotes installation, as found in this thread!
Thanks again!
Hello,
this is the log from the interrogator:
Sync_LW1T00YP_WF0AXXWPMAHU17389.xml (10.3 KB)
Thanks,
Daka
These are the installed files:
JR3T-14G381-AX
JR3T-14G422-BF
JR3T-14G391-AE
JR3T-14G423-AB
HB5T-14G424-BD
HB5T-14G421-BD
You have basically the same issue. I’ll write out your installation and post it…later tonight.
@Rip
@Daka
Please see this new tutorial that addresses this issue. Let me know if this needs anything.
@Daka
Follow this tutorial.
Tutorial: Sync 3.0.20204 with 2022 EU2.21 (F11) Map Installation - Ford / Guides - CyanLabs Official Community
@F150Chief that looks good to me, if @Daka can follow it from start to finish that would confirm it all makes sense. That also reminded me I still need to do the master reset :+1:t2:
It looks all fine and well described! I will give it a go at some point this week and will report back as soon as.
Thanks for all the help!!
