Sync 3 with Hazard light / door locked backlight problems
Hi all,
I just upgraded to Sync 3 from Sync 1 on my 2013 Focus ST. After using a conversion adapter to connect the original 8-pin dash plug to the new hazard light / door lock button, the button backlight stays permanently illuminated—even after the car has been turned off all day.
My wiring setup from the switch to the original 8-pin plug (left to right, High to low, 4 pins upper 4 pins lower) is currently configured as follows:
Pin 3: Button backlight ground signal
Pin 4: Hazard light flash trigger
Pin 5: Constant 12V power
Pin 7: Door lock signal trigger
Pin 8: Ground wire
I verified with a multimeter that Pin 5 on the original plug carries constant 12V power, which explains why the light stays on. My current wiring is shown in the attached picture. Could anyone advise on which pin/wire I should tap into so the backlight turns off with the car, or let me know if my pinout is incorrect? Thank you!
SYNC Region: CN
Install Type: OEM Replacement
Old SYNC Version: 1.1.511
New SYNC Version: 3.4 23188
no
This isn’t a Sync3 problem, its a harness/adapter issue.
Have you contacted the seller?
