Where are you actually located, in Europe, Middle East?
If you load EU maps, it should work with just a location (region) change for the APIM. If you load ROW maps, there are more changes to make.
Latest Ford/Guides & Info topics - CyanLabs Official Community
SaNdMaN
November 3, 2021, 8:17pm
#5
As long as none of the components are MY20, then you will be good.
As said before, depending on your current location, you will need to perform some changes.
Just a disclaimer, Cyanlabs does not support changing region, which does not mean you won’t be able to find information about the process.
Thanks again. Here is the info from the Interrogator:
Version 5U5T-14G381-EG
APIM Model: GB5T-14G371-CFC
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 50G
11/3/2021 10:13:35 PM +00:00
Jordan_Knight:
GB5T-14G371-CFC
2016 Gen 1 APIM with NAV which is safe to upgrade/reformat.
I am in the Middle East now, Jordan specifically. I just want to install the ROW maps and the latest Sync version on the Module
Here is the Interrogator data
APIM Size: 64GB
Tutorial: Installation of ROW (NNG) Maps on NA 32GB Sync 3 APIM - Ford / Guides & Info - CyanLabs Official Community
Ignore the fact this is 32GB APIM, it will be the same.
Note that the maps will no longer appear on the ‘Home’ screen as noted in the tutorial.
Thank you sir. Will try and report back.
Could you please tell me how to know my country code? Jordan in this case
SaNdMaN
November 3, 2021, 9:37pm
#12
From the tutorial:
So, it’s:
Please, make sure to read the tutorial carefully, you are about to perform a lot of sensitive changes… Mistakes will have impact…
I did the tutorial step-by-step and had already taken backups of my modules AB data. I also prepared the USB as set in the tutorial but I still get that pkg004 error
SaNdMaN
November 3, 2021, 9:52pm
#14
Then you have misconfigured Syn3updater.
That error states you are trying tu use the reformat on a later 3.4.xxxx build.
Post the log for the USB creation please.
you are correct. The version I currently have is 3.4 build 20196
What to do now?
SaNdMaN
November 3, 2021, 9:56pm
#16
Since you are not posting your log, I can only assume you have a wrong current version set in Syn3updater. Check those parameters.
CYANLABS - SYN3 UPDATER - V2.10.6.0
Version: 3.4.20196
Install Mode: reformat (reformat)
Install Mode Overridden: True
Model: SMI USB DISK USB Device
GRACENOTES=4U5T-14G423-FC_1615431949000.TAR.GZ
VOICE=5U5T-14G391-FR_1626960707000.TAR.GZ
APPS=5U5T-14G381-EU_1634769242000.TAR.GZ
MAP=4U5T-14G421-FAH_1598637879000.TAR.GZ
MAP_LICENSE=4U5T-14G424-FAH_1598638505000.TAR.GZ
; CyanLabs Syn3Updater 2.10.6.0 Stable - reformat FORCED Mode - Sync 3.4.21265 ROW
SaNdMaN
November 3, 2021, 10:01pm
#18
Ok, there’s another issue.
You are forcing installation method to reformat, which is wrong.
Set it to autodetect
Since you are on 3.4.20196, you can’t use the reformat tool.
You need to downgrade and then reformat.
So let it to auto-detect, do not force anything unless you know what you are doing.
I sincerely appreciate your help, will try and report back.
SaNdMaN
November 3, 2021, 10:10pm
#20
You are welcome.
If you want, you can post the log for the USB you are creating now, so that we can check everything is fine before proceeding.
Appreciate it. The process is underway now. The pkg004 error disappeared after I checked to Autodetect. Will soon update your with the outcome.
Guys this is so cool. I would like to thank you very much for the help. It WORKED!
SaNdMaN
November 3, 2021, 10:37pm
#23
Glad it worked, enjoy your new system.
Just remember to perform a master reset if you haven’t done so, and also disable auto updates or wifi altogether if you installed the latest 3.4 build.
