Sync3 3.0.23219 is still slow and reluctant after Ford update - Map update not working
Sync3 update (from year2017) downloaded from Ford website got me 3.0.23219. But uploaded log.file has errors, so Ford would not share new maps now on website. Got stick from Ford dealer with maps only, but shows lic_err001. Found this thread here sync-3-0-20204-23219-with-eu-2-21-f11-or-eu-2-22-f12-or-eu-2-23-f13-eu-2-24-f14-map-installation/6771, but got lst_err05
My autoinstall.lst:
; SYNC3 Consumer Application Upgrade - Release 3.0.25 - Only for Nav/EU assemblies.
[SYNCGen3.0_3.0.23219_PRODUCT]
Item1 = HB5T-14G386-TJB
Open1 = SyncMyRide\HB5T-14G386-TJB.tar.gz
Item2 = JR3T-14G424-BL
Open2 = SyncMyRide\JR3T-14G424-BL.tar.gz
Item3 = JR3T-14G421-BL
Open3 = SyncMyRide\JR3T-14G421-BL.tar.gz
[SYNCGen3.0_3.0.23219]
Item1 = JR3T-14G421-BL
Open1 = SyncMyRide\JR3T-14G421-BL.tar.gz
Item2 = HB5T-14G386-TJB
Open2 = SyncMyRide\HB5T-14G386-TJB.tar.gz
Item3 = JR3T-14G422-BK
Open3 = SyncMyRide\JR3T-14G422-BK.tar.gz
Item4 = JR3T-14G423-AB
Open4 = SyncMyRide\JR3T-14G423-AB.tar.gz
Item1 = GB5T-14G386-AE
Open1 = SyncMyRide\GB5T-14G386-AE.tar.gz
Options = Delay,Include, Transaction
My SyMyRide:
GB5T-14G386-AE.tar 47KB
HB5T-14G386-TJB_133301.tar 24KB
JR3T-14G381-AX_1599788486000.TAR 417MB
JR3T-14G421-BL_1745605796000.TAR 16.37GB
JR3T-14G422-BK_1746043148000.TAR 9.15GB
JR3T-14G422-BK_1746043148000.TAR 728MB
JR3T-14G424-BL_1747337001000.TAR 2KB
GB5T-14G386-AE.tar is not available here, found it on stick after trying upgrades to 3.4 (which did not work either) using sync-updater, together with xml.file, attached down here…
As others posted also, if I put a installer stick in, even not installing though, the system becomes normal and snappy. Also restarts made it faster, but without stick, it remains slow and navigation srceen is non-accurate.
So, thanks for reading first and also thanks for any help on it!!
Old SYNC Version: 3.0
New SYNC Version: 3.0.23219
LST_ERR05
Sync_MW7T00KX_6FPPXXMJ2PHG14100.xml (10.8 KB)
AAAArgh: Now I see, the names of files do not fit! I will try again and post results.
… currently updating … :upside_down_face:
As mentioned before, use the -AD package instead (-AE has not been found). But it’s not required, it’s just the interrogator log.
So reinstall everything as per the guide, if you have any errors provide information like screenshot / description of the error, the USB structure (files and directories on it) and the .lst files you are using.
I’m thinking one of these is the Gracenote file above…728MB.
This is installed on the unit…the map and voice files are not from the same release, which can cause your unit to act slow, etc.
JR3T-14G391-AE
HB5T-14G422-BC
1U5T-14G424-BP
JR3T-14G423-AB
HB5T-14G421-BD
Thanks for looking into it! Can’t say, how such a mix came on it, but It is a company car, so don’t know, if somebody tried something before. But it was working fine with the old system files and old maps, before I got than that update from Ford website to 3.0.23219
However, it is working now fast and normal and with the new maps F14, so thanks for this tutorial!!
Was bumpy though, because it would never say about end of installation, so not sure, when to take the stick out. It was still missing it for a couple of days when starting the car, but now after 2-3 restarts it seems to be fine. :nerd_face:
