hi, After a successful update to F13, the old F9 maps are still on the info screen
Install Type: Unknown
Old SYNC Version: 3.4.20237
New SYNC Version: 3.4.20237
no error message
…đ$ d„U\e„U\d„U\d Ŕ %"A b b Á u t l o g g i n g u t i l i t Á y . I n t e r l o g _ u t i l Á i t y . l o g …6i e„U\e„U\e„U\ Ŕ «! Y, Y, Á I n t e r r o g a t o r _ L o Á g . x m l 1:Response>
</d2p1:DID>
<d2p1:Response>01000200030001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1ac21aa42bd0</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>07003300000000171c000056566d006a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G380-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G371-FCA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-FA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>WW8U6VP2</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>50:f1:4a:10:42:09</d2p1:Response>
</d2p1:DID>
<d2p1:Response>50:f1:4a:10:42:0a</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2026-02-21T16:35:09+00:00" RAM="1124814848" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.2G" available="976K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.7G" available="16M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="9.3M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.4G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="26M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="308K"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.4G" available="4.9M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.6G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="5.0G" available="29M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="5.2G" available="30M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="3.9G" available="38M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="59M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="948M"/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="87M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="113M"/>
<d2p1:PartitionHealth type="/fs/mp/resources" total="74M" available="1.2M"/>
<d2p1:PartitionHealth type="/fs/images/" total="54G" available="14G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>MIIEtAYJKoZIhvcNAQcDoIIEpTCCBKECAQAxggG4MIIBtAIBADCBmzCBhjEbMBkGA1UEChMSRm9yZCBNb3RvciBDb21wYW55MQswCQYDVQQGEwJVUzERMA8GA1UEBxMIRGVhcmJvcm4xHjAcBgkqhkiG9w0BCQEWD21nbXNlY0Bmb3JkLmNvbTEnMCUGA1UEAxMeU3luYyBNb2R1bGUgRW5jcnlwdGlvbiBHZW4zIEEyAhDfwyMpAoa+v0vYmqleqJR7MA0GCSqGSIb3DQEBAQUABIIBAKOqcIsge9tuF6EpmMUdPnd186bQFGJs5B887I5IveNNvyZGFJ7wRtkod0u8/pT1d5nR9+Ph3fLM6q4Xa4chhLRKFSedvWJHhA1q2B2NhXumnxZBqflVhzPS13wuHOJ849Lh66jIk5ONbaHmfJmlPdZDUkwVzkTrwafYvUCkFh6AOTta/3UaDhw2jQmgHzW+cj9VNUIB//h4kba7KeuzCt3c5xDvOSMAA8hp9JxJute2KqGVnI5L1u4+vquVN95GRPfu4C82PUeTNyAjvmqer2HhVm8H9BWGJDhfzqq6AxwrZKgrma6+bczJ1L4QkwrzAJhOQbQICRP33apdkOrqI7AwggLeBgkqhkiG9w0BBwEwHQYJYIZIAWUDBAEqBBB+bODcyaYo/u1tBRgWNrX3gIICsKgY5LPvRq47rJcNHlEbNhJTLwsDFrBOawXZGLijP2u6zOSbrnNoAO/3bX1kQPYaZ6vS8xntNwzSNqmIenQ8JfNpoKi24QUfaQXUwD+fFBmEWUQOR5R9cj3TiTnQu6emygdsz2UjY3De4CGK0RM6bqpiukzN2kSy9Q3JnulnboNfyTaK7AiZe5hMxrxhoWZYYuup2GsAKlMCAueclU6m4xYck6C3N/gbrWUCC3PwMZV3+TvP6KxmSaUYzwosFUzCSh+7/UwQWRrRbkGf0I3kvCa/knb38BnlRoERVJ//5SbLxEFdzc1GVn4LXkUONC1xA9V+pYdVAlxXbjqxMu65BUdvNwCqgfV193fnkGJ1xASXV9xIpBBpGpub8q+q4/B72wg+/fiz2xplE7+fQ4qJGf7fdL7YyOxee6rtpwB7eBjd1anzVVwPYhirx+9uwU9LuN6gDKWuzghmkmUdhrsuf8yocxCkbnrYlq9BPIgLCxqTqN5HmGcv61cm6FLVuzn6Rn1nRp6+LiRJYAhoqs+vR4uR6q96x1KMtDmH9nEyvS1nMTDmrATjDChbUJjiOQc27+zrbj+FIQ5z4Y5v+Rr9rvRC24Ycr0NxnXzU20bsId4h7RkmFDqy3I2R+9dWeYRRNax1u6+MKEccG5Wa2ko6zObpit5qSVmIenBCHkXtr4E3urikO7yuLNO1+BcuNVLJ2wR+5knAbUCCv41cCgLV6ZEQTQ3imeMwL4cmbj1bZC1aGZ8MRXsFCobuJw/0tZSzdYcwIA2TtMRJoYx779Y+sLREEM+WWiVU2M25hy+Za2Vli3bogh/hBtV4ApYx/Kp/By5u0IsvzPINKAaBwCWKVXASSZArPyrk74J6ncaYHv34qXu6m3If6InTIWhGwV8BTcQHTjUh3eXksBpMeiw2V7I=</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
