Sync3 freezing after attempt to upgrade Maps
I had some old version of Syn3, I believe 3.2. I have succesfully updated it with official Ford update. Then tried to update maps which failed with MEM ERR 003. After that, I have problem: when starting Syn3 keep asking about automatic updates, always switch to English and freeze after some time of usage. Pressing power + Fast forward sometimes help. I have run the diagnostics tool from Cyanlabs (results below). I tried to install cut down (only one region) version of maps but immediately failed with MEM ERR 003.
How can I fix Sync3 and update the maps?
How can I fix Sync3 and inst
VIN: WF0JXXWPCJJP17516
Model APIM: 3U5T-14G371-GDD
Typ APIM: Navigation
Rozmiar APIM: 64GB
Wolne miejsce APIM: 15G
Wersja 3.4.23188 (NU5T-14G381-AD)
14.09.2024 07:43:59 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 60M / 1.1G
/fs/sd/MAP/ = 66M / 2.3G
/fs/sd/MAP/ = 68M / 2.1G
/fs/sd/MAP/ = 42M / 1.4G
/fs/sd/MAP/ = 69M / 2.0G
/fs/sd/MAP/ = 17M / 2.6G
/fs/sd/MAP/ = 488K / 24M
/fs/sd/MAP/ = 81M / 2.8G
/fs/sd/MAP/ = 107M / 2.8G
/fs/Nuance/ = 269M / 4.5G
/fs/Nuance/ = 278M / 4.6G
/fs/Nuance/ = 248M / 4.1G
/fs/Nuance/ = 182M / 3.3G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 0 / 1.2G
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 15G / 54G
(/fs/rwdata/quip = 0 / 35M
Installed Packages
1U5T-14G658-AH
1U5T-14G421-BAD
1U5T-14G421-BBD
1U5T-14G421-BCD
1U5T-14G421-BDD
1U5T-14G421-BED
1U5T-14G421-BFD
1U5T-14G421-BGD
1U5T-14G421-BHD
1U5T-14G421-BJD
4U5T-14G423-AC
1U5T-14G422-BAE
1U5T-14G422-BBE
1U5T-14G422-BCE
1U5T-14G422-BDE
5U5T-14G391-AT
1U5T-14G424-BM
APIM AsBuilt
DE00: 0A6A059A10027E4206C2
DE01: 474D0104C00B488000001405
DE02: 0200000004
DE03: 01001B00260107
DE04: 1BA318B02BD0
DE05: 80
DE06: 08003300000000186A00005656750070
Old SYNC Version: 3.2
MEM ERR 003
That’s the issue, and this is how to solve it APIM Sync Settings Not Saving, VER_ERR08 Errors, Cannot Perform Master Reset or Upgrades/Updates (Solved)
If none of those methods work, we do not have anything else to recommend at the moment.
