Please tell me where to get a smaller language voice pack and Gracenotes
I try all the ways, downloading the tutorial files, and also with the program. I had no luck, I stay in updating spend half an hour and does nothing, it should be fast since I have no maps
Hi Adam, were you able to solve this problem? I have the same configuration as you and want to upgrade to 3.4 but I’m little bit afraid now. Hope you’ve fixed it.
Welcome to the forum. Post a pic of the content of your USB.
Your usb is not created properly providing details of what you have done will help.
Thank you for taking the time…
So I think your on Mac or Linux. Your usb is likely formatted as gpt not mbr. It needs to be master boot record and exfat not anything else.
Took the drive to my office and formatted on my windows pc, reinserted it and I get the screen “starting update”…it never starts.
You still are not making sure it’s MBR not GPT
Is this a NON-NAV unit? If so why use reformat? Where are the maps?
Can you post the contents of the reformat.lst file?
It’s the non nav version
Should reformat be removed?
I suppose the contents of the autoinstall.lst file are just the boot loader, 1u5t-14g386-cb?
The reformat tool should not have been used, as this is a non-nav unit. (And not a 3.0 software.) However, try this:
Make a new usb formatted exfat.
Make a SyncMyRide folder with the three files above in it.
5U5T-14G381-ED_1591670365000.TAR.GZ
5U5T-14G391-CL_1580862907000.TAR.GZ
4U5T-14G423-CA_123766.TAR.GZ -
Copy DONTINDX.MSA to the root of the usb. (If you don’t have it, leave it out.)
Make a new autoinstall.lst file. Copy this:
Item1 = 5U5T-14G381-ED_1591670365000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G381-ED_1591670365000.TAR.GZ
Item2 = 5U5T-14G391-CL_1580862907000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-CL_1580862907000.TAR.GZ
Item3 = 4U5T-14G423-CA_123766.TAR.GZ
Open3 = SyncMyRide\4U5T-14G423-CA_123766.TAR.GZ
Options = Delay,AutoInstall -
Save and copy to root of usb.
Install.
What year is the F150 you are installing this into? Is this a Sync hardware upgrade? Obviously the usb worked the first time as you were able to load the bootloader and get to this point. Let us know if this works…
A 2019 xlt, thank You for the help. I will give it a try
