Hello
I have a problem, I tried to update SYNC3 to 3.4 and after 25 minutes of update an error appeared.
The radio is not responding.
FordSyncDownloader 1.0.3.0
OLDER THAN 3.2
EU
WITH
3.4.20021
EU
Ford Galaxy 2016
How do I check which error occurs in my case?
What to do to restore the SYNC3 factory?
Once again, provide a photo of the error.
Thanks this is readable.
Did you have navigation before?
What region is your car?
My guess is the file is corrupt try to redownload it.
Yes, I had navigation.
The car is from Germany but it drives in Poland.
I download the file again and prepare USB again
As soon as I play everything, I go to the car to try.
looks like you are trying to prepare the USB while the file is still downloading
file not found, it’s not on the USB
you likely have a really small storage APIM, open the reformat.lst in notepad and remove the line for 4U5T-14G423-AA then save and retry
Thanks, I’ll try now
It turned out, thanks! In the morning I’ll check how it works. What did I lose by not installing 4U5T-14G423-AA_123694.tar?
You have no Gracenotes. In theory you can install a smaller language voice pack and Gracenotes
Thank! Checked, everything works.
