SYNC3 Update Defaults to No Navigation
I originally tried to program an 8GB Toshiba thumb drive. Around 80% of installation, I received a pop up message. stating I did not have enough memory.
I then got a 64GB ONN USB 2.0 Flash Drive. SYNC3 installation was installed. Then went to 2016 Ford Edge and tried to install SYNC 3.4.23188 and latest map version. The installation seem to be working, until I got a installation failure pop message shortly after starting install. Then I tried installing again without success; hence, I erased the flash drive and tried to reinstall the SYNC3 update. The new installation is now defaulting to a Non Nav APIM, even if I tried this process on a different computer.
Notes listed in SYNC3 New Version box:
Release Notes:
Technical Information from FMods
Package Name: NU5T-14G381-AD
Epoch: 1689364279000
Major Version: 3.4
Build: 23188
Build Date: 2023-07-07
Package Date: 2023-07-14
Release Date: 2023-08-02
List of Changed files: https://pastebin.com/CDJJW9mN
Changes (based on diff):
  • Updated several libs, bin, and ifs
  • Fixed SLOGS compression and purge
    Does JB works? WORKING (according to community members)
Old SYNC Version: 3.4.22251
Installation Failure
Syn3 Updater Version: SYNC3 Updater 2.14.2.0 (Stable)
I believe this was deleted when I reformatted the flash drive, but did get this log when I tried to correct the installation:
Unique ID:1f1086b4-38e6-6378-91ea-0242ac130005
Date Created: 12 February 2026 @ 23:33:41
Version: 3.4.22251
Model: General USB Flash Disk USB Device
Size:
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Gracenotes Removal
FILES (1)
[2/12/2026 4:33:23 PM] Selected Region:  - Release: Gracenotes Removal - Map Version:
[2/12/2026 4:33:23 PM] Install Mode: Auto-Detect (autoinstall) Forced: False
[2/12/2026 4:33:23 PM] MY20 Protection: Auto-Detect
[2/12/2026 4:33:23 PM] Formatting USB drive
[2/12/2026 4:33:23 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2/12/2026 4:33:29 PM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2/12/2026 4:33:29 PM] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[2/12/2026 4:33:29 PM] Preparing USB drive
[2/12/2026 4:33:29 PM] Copying: GB5T-14G386-SC_85041.tar.gz
[2/12/2026 4:33:29 PM] Validating: GB5T-14G386-SC_85041.tar.gz
[2/12/2026 4:33:29 PM] Copied: GB5T-14G386-SC_85041.tar.gz
[2/12/2026 4:33:29 PM] Generating Autoinstall.lst
[2/12/2026 4:33:29 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Try just running the RWData cleaner since you’re on .22251
Odd are if you run the interrogator it will show that partition as nearly full
The USB stick or the car?
I tried a new thumb drive and resolved the Non Nav APIM problem.
After trying to update system again, an Error Code: UBSTK_ERR12, flashed on screen within a short time, stating to “Download files again and retry to install.” Any suggestions on what my next action is much appreciated.
I also tried and still trying to download RWData cleaner, but have also having a problem. When I locate the download, the “Prepare USB” tab is not active. Again, I am trying to get over this system updating problem.
Thanks
Could you please comment about my last post, jonyrick7553. Thanks
He is out of town right now so you will need to wait.
I’ll be back Friday
Thanks for the reply/update.
You have not provided any meaningful information.
So, take your time and provide ALL the following information:
  • syn3updater log for the USB you used for upgrading (you didn’t provide that, just the gracenote removal package)
  • create, run and share the output from the interrogator log (redact the vin from the title and content if you care about that)
The log that I believe you need for my problem is below (taken from thumb drive):
Version: 3.4.22251
; CyanLabs Syn3Updater 2.14.2.0 Stable - downgrade Mode - Sync 3.4.23188 NA
FILES (19)
[2/17/2026 10:39:01 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.24 (2024) - NA
[2/17/2026 10:39:01 AM] Install Mode: Auto-Detect (downgrade) Forced: False
[2/17/2026 10:39:01 AM] MY20 Protection: Auto-Detect
[2/17/2026 10:39:01 AM] Formatting USB drive
[2/17/2026 10:39:01 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2/17/2026 10:39:14 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/17/2026 10:39:16 AM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:16 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2/17/2026 10:39:16 AM] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[2/17/2026 10:39:16 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2/17/2026 10:39:16 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2/17/2026 10:39:16 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2026 10:39:16 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:16 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/17/2026 10:39:17 AM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:17 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/17/2026 10:39:19 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:19 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2026 10:39:22 AM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:22 AM] Checking Existing File: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2/17/2026 10:39:26 AM] Validated: 4U5T-14G421-CAH_1739451493000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:26 AM] Checking Existing File: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2/17/2026 10:39:30 AM] Validated: 4U5T-14G421-CBH_1739452251000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:30 AM] Checking Existing File: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2/17/2026 10:39:34 AM] Validated: 4U5T-14G421-CCH_1739452486000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:34 AM] Checking Existing File: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2/17/2026 10:39:40 AM] Validated: 4U5T-14G421-CDH_1739454837000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:40 AM] Checking Existing File: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2/17/2026 10:39:44 AM] Validated: 4U5T-14G421-CEH_1739455023000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:44 AM] Checking Existing File: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2/17/2026 10:39:48 AM] Validated: 4U5T-14G421-CFH_1739455629000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:48 AM] Checking Existing File: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2/17/2026 10:39:53 AM] Validated: 4U5T-14G421-CGH_1739455773000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:53 AM] Checking Existing File: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2/17/2026 10:39:55 AM] Validated: 4U5T-14G421-CJH_1739456204000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:55 AM] Checking Existing File: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2/17/2026 10:39:59 AM] Validated: 4U5T-14G421-CHH_1739455946000.TAR.GZ (Skipping Download)
[2/17/2026 10:39:59 AM] Checking Existing File: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2/17/2026 10:40:04 AM] Validated: 4U5T-14G422-CAP_1739450358000.TAR.GZ (Skipping Download)
[2/17/2026 10:40:04 AM] Checking Existing File: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2/17/2026 10:40:06 AM] Validated: 4U5T-14G422-CBP_1739456391000.TAR.GZ (Skipping Download)
[2/17/2026 10:40:06 AM] Checking Existing File: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2/17/2026 10:40:08 AM] Validated: 4U5T-14G422-CCP_1739456546000.TAR.GZ (Skipping Download)
[2/17/2026 10:40:08 AM] Preparing USB drive
[2/17/2026 10:40:08 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/17/2026 10:40:08 AM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/17/2026 10:40:42 AM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/17/2026 10:41:10 AM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/17/2026 10:41:10 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2/17/2026 10:41:10 AM] Copying: GB5T-14G386-SC_85041.tar.gz
[2/17/2026 10:41:10 AM] Validating: GB5T-14G386-SC_85041.tar.gz
[2/17/2026 10:41:10 AM] Copied: GB5T-14G386-SC_85041.tar.gz
[2/17/2026 10:41:10 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2/17/2026 10:41:10 AM] Copying: 1u5t-14g386-cb.tar.gz
[2/17/2026 10:41:10 AM] Validating: 1u5t-14g386-cb.tar.gz
[2/17/2026 10:41:11 AM] Copied: 1u5t-14g386-cb.tar.gz
[2/17/2026 10:41:11 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2026 10:41:11 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2026 10:41:11 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2026 10:41:11 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/17/2026 10:41:11 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/17/2026 10:41:11 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/17/2026 10:41:46 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/17/2026 10:42:08 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/17/2026 10:42:08 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/17/2026 10:42:08 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/17/2026 10:43:57 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/17/2026 10:44:32 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/17/2026 10:44:32 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2026 10:44:32 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2026 10:47:19 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2026 10:48:14 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/17/2026 10:48:14 AM] Checking Existing File: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2/17/2026 10:48:14 AM] Copying: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2/17/2026 10:51:27 AM] Validating: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2/17/2026 10:52:31 AM] Copied: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2/17/2026 10:52:31 AM] Checking Existing File: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2/17/2026 10:52:31 AM] Copying: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2/17/2026 10:56:09 AM] Validating: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2/17/2026 10:57:22 AM] Copied: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2/17/2026 10:57:22 AM] Checking Existing File: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2/17/2026 10:57:22 AM] Copying: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2/17/2026 11:01:08 AM] Validating: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2/17/2026 11:02:22 AM] Copied: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2/17/2026 11:02:22 AM] Checking Existing File: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2/17/2026 11:02:22 AM] Copying: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2/17/2026 11:06:48 AM] Validating: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2/17/2026 11:08:16 AM] Copied: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2/17/2026 11:08:16 AM] Checking Existing File: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2/17/2026 11:08:16 AM] Copying: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2/17/2026 11:11:56 AM] Validating: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2/17/2026 11:13:10 AM] Copied: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2/17/2026 11:13:10 AM] Checking Existing File: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2/17/2026 11:13:10 AM] Copying: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2/17/2026 11:16:52 AM] Validating: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2/17/2026 11:18:05 AM] Copied: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2/17/2026 11:18:05 AM] Checking Existing File: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2/17/2026 11:18:05 AM] Copying: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2/17/2026 11:21:59 AM] Validating: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2/17/2026 11:23:16 AM] Copied: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2/17/2026 11:23:16 AM] Checking Existing File: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2/17/2026 11:23:16 AM] Copying: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2/17/2026 11:25:38 AM] Validating: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2/17/2026 11:26:25 AM] Copied: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2/17/2026 11:26:25 AM] Checking Existing File: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2/17/2026 11:26:25 AM] Copying: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2/17/2026 11:29:44 AM] Validating: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2/17/2026 11:30:49 AM] Copied: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2/17/2026 11:30:49 AM] Checking Existing File: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2/17/2026 11:30:49 AM] Copying: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2/17/2026 11:34:53 AM] Validating: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2/17/2026 11:36:12 AM] Copied: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2/17/2026 11:36:12 AM] Checking Existing File: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2/17/2026 11:36:12 AM] Copying: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2/17/2026 11:38:44 AM] Validating: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2/17/2026 11:39:34 AM] Copied: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2/17/2026 11:39:34 AM] Checking Existing File: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2/17/2026 11:39:34 AM] Copying: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2/17/2026 11:41:18 AM] Validating: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2/17/2026 11:41:53 AM] Copied: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2/17/2026 11:41:53 AM] Generating reformat.lst
[2/17/2026 11:41:53 AM] Generating autoinstall.lst
[2/17/2026 11:41:53 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
I am also trying to find or develop the interrogator log that will be sent soon. If you can provide any help after reviewing the log above, please do so.
Thanks,
Created an Interrogator thumb drive, installed in my Ford Edge and got an error message (Error Code: INSTL_ERR12). This is the same code that I got originally with the SYNC3 Updater.
Hi
I’m having the same issue trying to downgrade to upgrade my Sync 3.4.22251 to latest version
The same error message you get or it displays the installation complete remove USB message but nothing happens after that whether I leave it in or not, or leave car running or turn off and restart
Could you let me know if you sort it or get any answers
Thanks
Error 12 is a hardware error that is usually not repairable. Probably a bad APIM.
The APIM powers up and needs to be adjusted to get radio. The map works but no history is saved. Is there anyway to load a new SYNC3 program. Would loading the SYNC3.4.22251 again be a possible solution? Your reply is appreciated. Thanks
Based on the your profile this is a 2016 Edge?
You might want to try 3.4.21265 instead of going to a build with the RWData bug.
