system info does not give build number
i am trying to down load the need files for update to 3.4 however my sync info only states sync 3, software version: build.
what wiul i use in the cconfiguration to run the update?
Old SYNC Version: 3.000
New SYNC Version: 123456789
none
Syn3 Updater Version: 121345
none
Perform a master reset to see if that shows anything, otherwise create and run an interrogator log against the unit, share the XML produced.
Well the present current version that you probably should be aiming for is sync 3.4.23188 and maps NA 2.24.
Your present version is apparently version 3.0 so based on your current map version NA1.17 (2017) use one of the earlier 3.0 versions listed on the Syn3Updater as your current version for the download unless you know what year it was last updated.
Perhaps 2018, so look for the numbers 18 or 19 included as the first numerals in the version list on the updater.
Truck is a 2019 so i would think it would be at least something in 2019, but who knows. Hard to belive that the maps are 17
Thank you
The maps are usually a year behind so they could have been uploaded in 2019 along with a 2018 or 2019 sync version.
Based on your VIN lookup:
Your maps are 2017. Your APIM is a 2019. It is NOT MY20+.
7D0
F10A>GB5T-14G379-AA
F110>DS1U5T-14G371-DA
F111>GU5T-14G380-ED NOT MY20+
F113>KU5T-14G371-CDG APIM Part Number, 2019.
F124>1U5T-14G375-DA
F141>VY2V1F1D
F144>Q8775D0E
F16B>JB5T-14G379-BA
F188>1U5T-14G374-DA
F1D0>6847496B6A33
F1D1>6847496B6A34
Who ever owned the truck had a few years of free map updates but never did them.
It is odd that the maps are so old on a 2019, yes. However, a simple reformat and upgrade will solve the issue.
master reset got me the info. it is 3.3.18351.
hopefully this will work and get my wife off my back about her update.
thank you for your help. I will discuss what going on with my truck on another post. I think it gonna be more involved, LOL
Thank you all
