Tried updating my sync3 and got an error message
That won’t work, you didn’t follow the guide:
So all the compressed files (GZ ones) must be under that folder, not on the root.
Also, there are 2 issues with the autoinstall.lst file:
  1. there’s strange coding at the options statement, maybe due to copying from the webpage. Check the page you downloaded the files from, there’s an option to download the autoinstall.lst file from there directly
  2. windows says it’s a text file, so I think that file is named autoinstall.lst.txt in reality. So make Windows display the file extensions to ensure it’s .lst and not .lst.txt
