I tried updating using the downgrade method. When I first inserted the USB it said updating at the top. Walked away for a few minutes. Came back to a black screen. Let it keep doing it for about 20 more minutes before performing a soft reset. Nothing happened. Have no sound, no back up camera, nothing. I turned the vehicle off. Let it sit for about 15 minutes and still a totally black screen. The USB ports will charge my phone but nothing else happens. I’m assuming I’ve bricked my AIPM.
Here is my Interrogator Log :
<?xml version="1.0" encoding="UTF-8"?><p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2026-06-01” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>1FTFW1ET3DFC49638</p:VIN>
<p:RequestRole>
d2p1:RoleCONSUMER</d2p1:Role>
d2p1:RoleDescSYNCGEN3</d2p1:RoleDesc>
d2p1:RoleIDOTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue=“c155000b”/>
<d2p1:DTC DTCValue=“e101000b”/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
d2p1:ResponseNU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
d2p1:Response345535542d3134473432312d434a47000000000000000000345535542d3134473432312d434847000000000000000000345535542d3134473432312d434747000000000000000000345535542d3134473432312d434647000000000000000000345535542d3134473432312d434547000000000000000000345535542d3134473432312d434447000000000000000000345535542d3134473432312d434347000000000000000000345535542d3134473432312d434247000000000000000000345535542d3134473432312d434147000000000000000000355535542d3134473339312d435300000000000000000000345535542d3134473432322d43434e000000000000000000345535542d3134473432322d43424e000000000000000000345535542d3134473432322d43414e000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response8442ff28</d2p1:Response>
</d2p1:DID>
d2p1:Responseb7038998</d2p1:Response>
</d2p1:DID>
d2p1:Responsea2218001e20201420002</d2p1:Response>
</d2p1:DID>
d2p1:Response555300030002020000000000</d2p1:Response>
</d2p1:DID>
d2p1:Response0f4b570300</d2p1:Response>
</d2p1:DID>
d2p1:Response01030200000001</d2p1:Response>
</d2p1:DID>
d2p1:Response198c198c2e0e</d2p1:Response>
</d2p1:DID>
d2p1:Response80</d2p1:Response>
</d2p1:DID>
d2p1:Response00000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
d2p1:ResponseDS-GB5T-14G371-CD</d2p1:Response>
</d2p1:DID>
d2p1:ResponseHL1T-14G380-BB</d2p1:Response>
</d2p1:DID>
d2p1:ResponseJL7T-14G371-CCC</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
d2p1:ResponseWWAYB97L</d2p1:Response>
</d2p1:DID>
d2p1:ResponseBlank</d2p1:Response>
</d2p1:DID>
d2p1:Response03</d2p1:Response>
</d2p1:DID>
d2p1:ResponseGB5T-14G374-CD</d2p1:Response>
</d2p1:DID>
d2p1:Response</d2p1:Response>
</d2p1:DID>
d2p1:Responsed4:36:39:0b:5b:27</d2p1:Response>
</d2p1:DID>
d2p1:Responsed4:36:39:0b:5b:28</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2026-06-01T09:08:29+00:00” RAM=“1018011648” vmcuVersion=“Vector_VMCU_05.02.05”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.6G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“12M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“10M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1003M” available=“3.1M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“8.3M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.8G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.7G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.3G” available=“6.4M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.7G” available=“16M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.1G” available=“10M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“2.5G” available=“23M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“465M” available=“3.2M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/grace” total=“775M” available=“5.8M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“852M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“496K” available=“17K”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“83M”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“25G” available=“3.7G”/>
d2p1:InstallationLog/
d2p1: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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Here is the Install Log:
Version: 3.4.23088
APPS=NU5T-14G381-AE_1778770590000.TAR.GZ
VOICE_NAV=4U5T-14G422-CCR_1774002344000.TAR.GZ
VOICE_NAV=4U5T-14G422-CBR_1774002523000.TAR.GZ
VOICE_NAV=4U5T-14G422-CAR_1774002538000.TAR.GZ
MAP=4U5T-14G421-CJJ_1773881407000.TAR.GZ
MAP=4U5T-14G421-CHJ_1773881581000.TAR.GZ
MAP=4U5T-14G421-CGJ_1773881595000.TAR.GZ
MAP=4U5T-14G421-CFJ_1773883381000.TAR.GZ
MAP=4U5T-14G421-CEJ_1773883394000.TAR.GZ
MAP=4U5T-14G421-CDJ_1773883409000.TAR.GZ
MAP=4U5T-14G421-CCJ_1773882977000.TAR.GZ
MAP=4U5T-14G421-CBJ_1773882394000.TAR.GZ
MAP=4U5T-14G421-CAJ_1773882382000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - downgrade Mode - Sync 3.4.26057 NA
FILES (19)
NU5T-14G381-AE_1778770590000.TAR.GZ (869.9MB)
4U5T-14G422-CCR_1774002344000.TAR.GZ (548.1MB)
4U5T-14G422-CBR_1774002523000.TAR.GZ (812.4MB)
4U5T-14G422-CAR_1774002538000.TAR.GZ (1.2GB)
4U5T-14G421-CJJ_1773881407000.TAR.GZ (742.8MB)
4U5T-14G421-CHJ_1773881581000.TAR.GZ (1GB)
4U5T-14G421-CGJ_1773881595000.TAR.GZ (1.2GB)
4U5T-14G421-CFJ_1773883381000.TAR.GZ (1.1GB)
4U5T-14G421-CEJ_1773883394000.TAR.GZ (1.1GB)
4U5T-14G421-CDJ_1773883409000.TAR.GZ (1.3GB)
4U5T-14G421-CCJ_1773882977000.TAR.GZ (1.1GB)
4U5T-14G421-CBJ_1773882394000.TAR.GZ (1.1GB)
4U5T-14G421-CAJ_1773882382000.TAR.GZ (1GB)
[6/1/2026 9:15:53 AM] Selected Region: NA - Release: Sync 3.4.26057 - Map Version: 2.25 (2025) - NA
[6/1/2026 9:15:53 AM] Install Mode: Auto-Detect (downgrade) Forced: False
[6/1/2026 9:15:53 AM] MY20 Protection: Disabled / Not MY20
[6/1/2026 9:15:53 AM] Formatting USB drive
[6/1/2026 9:15:53 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[6/1/2026 9:16:00 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:16:00 AM] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:17:12 AM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:17:13 AM] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:17:13 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:17:13 AM] Downloading: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:17:13 AM] Validating: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:17:13 AM] Downloaded: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:17:13 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:17:13 AM] Downloading: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:17:15 AM] Validating: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:17:15 AM] Downloaded: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:17:15 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:17:15 AM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:17:15 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:17:15 AM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:17:15 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:17:15 AM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:18:10 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:18:11 AM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:18:11 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:18:11 AM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:19:32 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:19:34 AM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:19:34 AM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:19:34 AM] Downloading: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:21:37 AM] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:21:40 AM] Downloaded: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:21:40 AM] Checking Existing File: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:21:40 AM] Downloading: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:22:58 AM] Validating: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:22:59 AM] Downloaded: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:22:59 AM] Checking Existing File: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:22:59 AM] Downloading: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:24:25 AM] Validating: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:24:28 AM] Downloaded: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:24:28 AM] Checking Existing File: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:24:28 AM] Downloading: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:26:40 AM] Validating: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:26:44 AM] Downloaded: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:26:44 AM] Checking Existing File: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:26:44 AM] Downloading: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:28:01 AM] Validating: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:28:04 AM] Downloaded: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:28:04 AM] Checking Existing File: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:28:04 AM] Downloading: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:29:52 AM] Validating: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:29:55 AM] Downloaded: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:29:55 AM] Checking Existing File: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:29:55 AM] Downloading: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:31:56 AM] Validating: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:32:00 AM] Downloaded: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:32:00 AM] Checking Existing File: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:32:00 AM] Downloading: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:33:47 AM] Validating: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:33:50 AM] Downloaded: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:33:50 AM] Checking Existing File: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:33:50 AM] Downloading: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:35:42 AM] Validating: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:35:45 AM] Downloaded: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:35:45 AM] Checking Existing File: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:35:45 AM] Downloading: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:37:43 AM] Validating: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:37:47 AM] Downloaded: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:37:47 AM] Checking Existing File: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 9:37:47 AM] Downloading: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 9:39:20 AM] Validating: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 9:39:24 AM] Downloaded: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 9:39:24 AM] Checking Existing File: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 9:39:24 AM] Downloading: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 9:41:01 AM] Validating: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 9:41:04 AM] Downloaded: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 9:41:04 AM] Checking Existing File: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 9:41:04 AM] Downloading: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 9:42:29 AM] Validating: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 9:42:32 AM] Downloaded: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 9:42:32 AM] Preparing USB drive
[6/1/2026 9:42:32 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:42:32 AM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:43:13 AM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:43:17 AM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[6/1/2026 9:43:17 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:43:17 AM] Copying: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:43:17 AM] Validating: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:43:17 AM] Copied: GB5T-14G386-SC_85041.tar.gz
[6/1/2026 9:43:17 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:43:17 AM] Copying: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:43:18 AM] Validating: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:43:18 AM] Copied: 1u5t-14g386-cb.tar.gz
[6/1/2026 9:43:18 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:43:18 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:43:18 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:43:18 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[6/1/2026 9:43:18 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:43:18 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:43:55 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:43:58 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[6/1/2026 9:43:58 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:43:58 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:44:35 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:44:40 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[6/1/2026 9:44:40 AM] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:44:40 AM] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:45:52 AM] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:46:00 AM] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[6/1/2026 9:46:00 AM] Checking Existing File: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:46:00 AM] Copying: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:46:45 AM] Validating: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:46:50 AM] Copied: 4U5T-14G422-CCR_1774002344000.TAR.GZ
[6/1/2026 9:46:50 AM] Checking Existing File: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:46:50 AM] Copying: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:47:50 AM] Validating: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:47:57 AM] Copied: 4U5T-14G422-CBR_1774002523000.TAR.GZ
[6/1/2026 9:47:57 AM] Checking Existing File: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:47:57 AM] Copying: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:49:32 AM] Validating: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:49:43 AM] Copied: 4U5T-14G422-CAR_1774002538000.TAR.GZ
[6/1/2026 9:49:43 AM] Checking Existing File: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:49:43 AM] Copying: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:50:39 AM] Validating: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:50:45 AM] Copied: 4U5T-14G421-CJJ_1773881407000.TAR.GZ
[6/1/2026 9:50:45 AM] Checking Existing File: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:50:45 AM] Copying: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:52:14 AM] Validating: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:52:23 AM] Copied: 4U5T-14G421-CHJ_1773881581000.TAR.GZ
[6/1/2026 9:52:23 AM] Checking Existing File: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:52:23 AM] Copying: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:54:01 AM] Validating: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:54:12 AM] Copied: 4U5T-14G421-CGJ_1773881595000.TAR.GZ
[6/1/2026 9:54:12 AM] Checking Existing File: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:54:12 AM] Copying: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:55:26 AM] Validating: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:55:36 AM] Copied: 4U5T-14G421-CFJ_1773883381000.TAR.GZ
[6/1/2026 9:55:36 AM] Checking Existing File: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:55:36 AM] Copying: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:57:02 AM] Validating: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:57:12 AM] Copied: 4U5T-14G421-CEJ_1773883394000.TAR.GZ
[6/1/2026 9:57:12 AM] Checking Existing File: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:57:12 AM] Copying: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:58:51 AM] Validating: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:59:03 AM] Copied: 4U5T-14G421-CDJ_1773883409000.TAR.GZ
[6/1/2026 9:59:03 AM] Checking Existing File: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 9:59:03 AM] Copying: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 10:00:30 AM] Validating: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 10:00:39 AM] Copied: 4U5T-14G421-CCJ_1773882977000.TAR.GZ
[6/1/2026 10:00:39 AM] Checking Existing File: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 10:00:39 AM] Copying: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 10:02:16 AM] Validating: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 10:02:26 AM] Copied: 4U5T-14G421-CBJ_1773882394000.TAR.GZ
[6/1/2026 10:02:26 AM] Checking Existing File: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 10:02:26 AM] Copying: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 10:03:48 AM] Validating: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 10:03:57 AM] Copied: 4U5T-14G421-CAJ_1773882382000.TAR.GZ
[6/1/2026 10:03:57 AM] Generating reformat.lst
[6/1/2026 10:03:57 AM] Generating autoinstall.lst
[6/1/2026 10:03:57 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Install Type: OEM Replacement
Old SYNC Version: 3.4.23188
New SYNC Version: 3.4.26057
Have a black screen. No audio or anything. Tried a soft reset to no aval.
Syn3 Updater Version: 2.14.2.0 (Stable)
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2026-06-01" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:RequestRole>
</p:RequestRole>
<d2p1:DTC DTCValue="c155000b"/>
<d2p1:DTC DTCValue="e101000b"/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>NU5T-14G381-AD</d2p1:Response>
</d2p1:DID>
<d2p1:Response>345535542d3134473432312d434a47000000000000000000345535542d3134473432312d434847000000000000000000345535542d3134473432312d434747000000000000000000345535542d3134473432312d434647000000000000000000345535542d3134473432312d434547000000000000000000345535542d3134473432312d434447000000000000000000345535542d3134473432312d434347000000000000000000345535542d3134473432312d434247000000000000000000345535542d3134473432312d434147000000000000000000355535542d3134473339312d435300000000000000000000345535542d3134473432322d43434e000000000000000000345535542d3134473432322d43424e000000000000000000345535542d3134473432322d43414e000000000000000000345535542d3134473432332d434300000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>8442ff28</d2p1:Response>
</d2p1:DID>
<d2p1:Response>b7038998</d2p1:Response>
</d2p1:DID>
<d2p1:Response>a2218001e20201420002</d2p1:Response>
</d2p1:DID>
<d2p1:Response>555300030002020000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0f4b570300</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01030200000001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>198c198c2e0e</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>00000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CD</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HL1T-14G380-BB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>JL7T-14G371-CCC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>WWAYB97L</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CD</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>d4:36:39:0b:5b:27</d2p1:Response>
</d2p1:DID>
<d2p1:Response>d4:36:39:0b:5b:28</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2026-06-01T09:08:29+00:00" RAM="1018011648" vmcuVersion="Vector_VMCU_05.02.05">
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.6G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="12M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="10M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1003M" available="3.1M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="8.3M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.8G" available="14M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.7G" available="17M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.3G" available="6.4M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.7G" available="16M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="1.1G" available="10M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="2.5G" available="23M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="465M" available="3.2M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="775M" available="5.8M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="852M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="496K" available="17K"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="83M"/>
<d2p1:PartitionHealth type="/fs/images/" total="25G" available="3.7G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</p:Node>
