Trying to resolve GPS problems.
Hey all
Car is a 2019 Ford Ka 1.5 TiVCT (Brazilian car), it comes with sync 3, 8gb non nav unit but i’m using an APIM from a 2017 EcoSport, which is a 32gb nav unit (this unit was given to me bricked and i fixed it with help from here)
The map works fine when i start driving but after a few minutes, it just wanders in a random direction and takes a whole lot of time to fix it self only to start wandering again a couple minutes later, essentialy making the navigation pretty much useless whenever you really need it.
This car has a gps antenna from the factory, code GCPT-19C175-AA and around here i can’t really find much info on whats fitted on the EcoSport with sync 3, but i believe it should be pretty similar. I bought one of those cheap aftermarket gps antennas to test it before i buy a new oem antenna.
This is currently my ab for the APIM.
7D0-01-01 0A68 0004 105F
7D0-01-02 0008 1608 8080
7D0-02-01 4252 0106 81F6
7D0-02-02 6224 8009 806A
7D0-02-03 0105 E2
7D0-03-01 0100 0100 00DD
7D0-04-01 0000 2EE1 1F0A
7D0-04-02 0001 DE
7D0-05-01 170A 16C3 26FD
7D0-05-02 4B29
7D0-06-01 401E
7D0-07-01 0A00 3300 001C
7D0-07-02 0000 0000 00E0
7D0-07-03 5A56 5657 0040
7D0-07-04 4729
7D0-08-01 0C80 0000 006C
7D0-08-02 0000 0000 10F1
And here are some photos i took of the location diagnostics screen. First pic is when i start driving, 2nd and 3rd happen after a few minutes.
https://imgur.com/a/apim-location-diags-AYrdWd8
Anything suggestions before i fit a new antenna? Could this be happening due to me using wrong calibration files?
SYNC Region: ANZ
Install Type: OEM Replacement
Old SYNC Version: 3.0.20204
No error.
Find a similar vehicle to yours and download the factory asbuilt for that vehicle with Sync 3. The issue is most likely the data here:
7D0-05-02 4B29
7D0-06-01 401E
7D0-07-04 4729
This is likely the wrong parameters for your vehicle which will cause this issue.
Those are the parameters from factory, copied them from the original 8gb non nav apim… I tried using the parameters for the 2017 EcoSport but it obviously got worse since it has bigger wheels and stuff.
Looking at the pics you posted, the GPS is fine, your antenna is fine.
What maps are loaded on the unit.
Run the Interrogator Utility and post the XML here.
Sync_WW6M7G6H_9BFZH55S8K8320958.xml (10.4 KB)
Here’s my xml
There are errors in your asbuilt.
Change this to 7D0-02-01 4252 0106 80xx
xx = Checksum bits, let FORScan calculate this.
Change this to 7D0-02-02 6200 8009 80xx
This is your OEM asbuilt. You should load this and perform a master reset.
7D0-01-01 0868 0006 105F
7D0-02-01 4252 0106 80F5
7D0-02-02 6200 8009 8046
7D0-02-03 0105 E2
7D0-04-02 0001 DE
7D0-05-02 4B29
7D0-06-01 401E
7D0-07-03 5A56 5657 003E
7D0-07-04 4729
Place this file in your Asbuilt folder for FORScan in My Documents on your computer. You can use this to reload your OEM asbuilt.
9BFZH55S8K8320958.ab (21.8 KB)
Loaded my cars oem asbuilt, only change i did is enabling the navigation since it comes disabled and did a master reset..
Unfortunately, same behaviour with oem asbuilt… However, i turned off my navigation so i can see compass in the main screen and noticed it seems to be frozen in the north direction, im thinking maybe theres something faulty within the apim itself?
It’s really weird because when i start driving, it changes directions perfectly fine, only being a tiny bit off… until it goes complety off haha
On a 2015 which came with Sync 2, There is a GPSM module. This is separate than the GPS antenna you added when you swapped in Sync 3. Did you disconnect that or is it still connected?
My car comes with sync 3 from the factory so i believe it does not come with a gpsm module. Correct me if im wrong!
Also i did not add the gps antenna, it already came in the car from the factory… Should i try with another antenna?
Look in the Sync 3 test menu and see what the GPS readings are.
load factory asbuilt erase forscan profile then reload it again that should solve your issue
Tried another cheap antenna but the signal was very weak. I’ll keep running the stock antenna, see if it gets better over time
As i stated before, i loaded my oem asbuit and enabled the nav, not much changed.
