Unknown Region - Please advice
What is your SYNC Region?
UNKNOWN
3.0.19080
Do you have Navigation?
YES
NOT YET
Hello,
I am seeking your assistance.
I have a 2017 F150 Platinum trim bought in the GCC. I am unsure of what HW/SW Version I have so I can update it to 3.4 without loosing my maps or them changing to NA.
Diagnostic page says:
JR3T-14G381-AX 3.0.20204
JR3T-14G391-FF 3.2.19056
JR3T-14G423-FB 3.0.19080
HB5T-14G421-FAB 2.1.16118
Version: JR3T-14G381-AX
APIM Model: HP5T-14G371-GBA
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 19G
3/30/2021 12:25:30 PM +00:00
Partition Type = Free / Total
/fs/usb0/ = 30G / 30G
/fs/tmpfs/ = 126M / 128M
/fs/sd/MAP/ = 20M / 3.3G
/fs/Nuance/ = 3.6M / 1.6G
/fs/Nuance/grace = 6.0M / 1.1G
/fs/rwdata/ = 724M / 1024M
/fs/mp/ = 40M / 1024M
/fs/images/ = 19G / 26G
APIM AsBuilt
DE00: 8A2A05031404AB020481
DE01: 51410103F402038000000005
DE02: 0000010300
DE03: 010014000E0001
DE04: 1A681A6838A4
DE05: 80
DE06: 46003300000000029A000056569200C8
Please let me know if there is any more info I can provide.
Thanks in advance
Hello.
There are some database available in the FHUB β†’ Ford Hub - CyanLabs
Try the SW database for the ISVUs that are installed, and the HW one for the APIM itself.
The SW says you have a package for ANZ (maps) and another one for ROW (gracenotes)…
What’s the deal with that APIM?
Do you know its history?
I am a complete noob.
The car was purchased from the Ford dealer in Qatar. No mods or similar.
I don’t want to update if I loose the NAV system, support in this part of the world is almost non existent.
Thanks
You will need to get maps for Middle East, this can be done for a small fee from Cut Down Map Package Generator - CyanLabs
Only select Middle East And North Africa
alternatively you can try to update with Syn3 Updater to β€œ2019 Q4 - ROW (All)” but you may not have enough storage space.
I will definitely look into that. I have the feeling I have some weird configuration out of the dealership and I am afraid to screw things up beyond repair. How can I make shut what version I have and how much storage? As I said I am a complete noob on these matters.
Thank you so much
Looking at the APIM asbuilt configuration, you are already set for the correct region, 5141=Qatar. The Sync version is 3.0.20204. The settings in the APIM were most likely modified by the dealer in Qatar, as they also turned off your parking assist features. (GCC). The rest of the asbuilt is correct for your model of vehicle.
As far as upgrading to Sync 3.4 and adding maps, this should not be an issue. You can either select the one set of maps for the Middle East, North Africa as mentioned above, or install the entire ROW package. (The values below are approximate based on 25% file compression.) The new formatting will look like this:
Partition = Total under Sync 3.4:
Total =β€œ1.5G” type=β€œ/fs/Nuance/”
Total =β€œ1.0G” type=β€œ/fs/Nuance/grace”
Total =β€œ1.2G” type=β€œ/fs/rwdata/”
Total =β€œ35M” type=β€œ/fs/rwdata/quip/”
Total =β€œ90M” type=β€œ/fs/rwdata/quip/”
Total =β€œ1.4G” type=β€œ/fs/mp/”
SubTotal =β€œ5.225G”
Total =β€œ12.5G” type=β€œ/fs/sd/MAP/” ROW (ALL FILES) = β€œ9.825G” Compressed
Total =β€œ17.725G” type=β€œ/fs/images/”
Free =β€œ11.175G”
Total Formatted Available = β€œ28.9G”
ROW MAPS:
4U5T-14G421-FAH 4.9Gb Sync3 v3.2.20147 CAM (19Q4), Caribbean (1912), India (19Q4), Israel (1912), MENA (19Q4), SAF (19Q4), SEA (1912)
4U5T-14G421-FBH 672Mb Sync3 v3.2.20183 Middle East, North Africa (19Q4)
4U5T-14G421-FCH 1.8Gb Sync3 v3.2.20183 India and Sri Lanka (19Q4)
4U5T-14G421-FDH 174Mb Sync3 v3.2.20183 Israel (19Q4)
4U5T-14G421-FEH 1.1Gb Sync3 v3.2.20183 South East Asia (19Q4)
4U5T-14G421-FFH 1.1Gb Sync3 v3.2.20183 Southern Africa (19Q4)
4U5T-14G421-FGH 56Mb Sync3 v3.2.20183 Caribbean (19Q4)
4U5T-14G421-FHH 66Mb Sync3 v3.2.20183 Central America (19Q4)
APP:
5U5T-14G381-EM 849Mb Sync3 v3.4.20351 06.12.2020
System Voice:
5U5T-14G391-FN 1.4Gb Sync3 v3.2.20142
Gracenotes:
4U5T-14G423-FB 919Mb Sync3 v3.3.20178 1.1.1.2220 (GL-0011) (24.05.2020)
Thank you very much for your answer. I will go ahead and order the custom maps. Thanks again
