Update 3.0.19205 -> 3.4.26057 reformat with update maps SIGN_ERR02
Hi everyone,
I recently bought a 2016 Ford Mondeo MK5 with SYNC 3 v3.0.19205 and factory navigation (which was working perfectly before I started updating).
I wanted to update it to SYNC 3 v3.4.26057 together with the latest maps.
While writing this post I realized something that might be important: I think my first USB drive was formatted as GPT instead of MBR. Could that have caused any of these issues?
Here is what happened step by step:
I prepared the first USB with reformat and the latest maps.
During the installation I got:
Error in 4U5T-14G422-BBM_1748464677000.TAR.GZ: SIGN_ERR02
From what I have read, this file is one of the navigation voice packages. I don’t actually need all navigation voices since I only use Polish.
After this error, SYNC got stuck on the red reformat screen. I performed a reset (Power + Seek Forward).
After rebooting it was stuck on the “Insert USB” reformat screen.
I created another USB, this time without the navigation voice files, and the installation completed successfully.
However, after that navigation stopped working completely.
Current symptoms:
Every time the car starts I get a message saying that Navigation is not functioning properly.
There is a yellow warning triangle on the Home screen.
In the SYNC “About” menu, the Navigation Version field is completely blank.
After that I also:
Installed Jailbreak and tried a few mods.
Decided to return to a clean installation because I didn’t like one of the mods.
Downgraded to SYNC 3.3.
Then performed another reformat to 3.4.26057.
Unfortunately, the navigation problem is still exactly the same.
My main questions are:
Should I now downgrade to 3.3 again and perform a complete 3.4.26057 reformat with maps, or…
Is it enough to install only the missing maps/navigation files using AutoInstall?
Since my Navigation Version is empty, does that indicate that the map database was never installed correctly?
Can I install only selected map packages and only the voice files I actually need, or is it recommended to install the complete package?
I don’t use the built-in navigation very often because I normally use Android Auto or Apple CarPlay, but I would still like to restore the factory navigation so everything works correctly.
I’ve attached three logs:
  1. 3.0 → 3.4 reformat with the latest maps, which failed with the SIGN_ERR02 error.
  2. 3.0 → 3.4 reformat without any navigation files (maps, voices, etc.), which completed successfully but left the navigation non-functional.
  3. The package and log for the installation I was planning to perform next: installing only the latest maps on my current working SYNC 3.4.26057 using AutoInstall.
Thanks in advance for any advice.
Old SYNC Version: 3.0.19205
New SYNC Version: 3.4.26057
Syn3 Updater Version: 2.14.2. STABLE
--------- LOG 1 -- FAILED UPDATE 3.0-> 3.4 WITH FULL PACKAGE OF NAVI:
Version: 3.0.19205
Install Mode: Auto-Wykrywanie (reformat)
My20 Protection Enabled: Auto-Wykrywanie
Partition Type: GPT
APPS=NU5T-14G381-AE_1778770590000.TAR.GZ
MAP=1U5T-14G421-BAM_1748461682000.TAR.GZ
MAP=1U5T-14G421-BBM_1748459859000.TAR.GZ
MAP=1U5T-14G421-BCM_1748460093000.TAR.GZ
MAP=1U5T-14G421-BDM_1748460770000.TAR.GZ
MAP=1U5T-14G421-BEM_1748461035000.TAR.GZ
MAP=1U5T-14G421-BFM_1748461472000.TAR.GZ
MAP=1U5T-14G421-BGM_1748462187000.TAR.GZ
MAP=1U5T-14G421-BHM_1748462644000.TAR.GZ
MAP=1U5T-14G421-BJM_1748462970000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAM_1748464396000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBM_1748464677000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCM_1748464896000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDM_1748465073000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BP_1748959609000.TAR.GZ
; CyanLabs Syn3Updater 2.14.2.0 Stable - reformat  Mode - Sync 3.4.26057 EU
FILES (20)
1u5t-14g386-cb.tar.gz (8,5MB)
NU5T-14G381-AE_1778770590000.TAR.GZ (869,9MB)
1U5T-14G421-BAM_1748461682000.TAR.GZ (2,5GB)
1U5T-14G421-BBM_1748459859000.TAR.GZ (539,6MB)
1U5T-14G421-BCM_1748460093000.TAR.GZ (1,8GB)
1U5T-14G421-BDM_1748460770000.TAR.GZ (1,1GB)
1U5T-14G421-BEM_1748461035000.TAR.GZ (1,8GB)
1U5T-14G421-BFM_1748461472000.TAR.GZ (2,5GB)
1U5T-14G421-BGM_1748462187000.TAR.GZ (2,1GB)
1U5T-14G421-BHM_1748462644000.TAR.GZ (2,6GB)
1U5T-14G421-BJM_1748462970000.TAR.GZ (26MB)
4U5T-14G422-BAM_1748464396000.TAR.GZ (2,4GB)
4U5T-14G422-BBM_1748464677000.TAR.GZ (2,3GB)
4U5T-14G422-BCM_1748464896000.TAR.GZ (1,8GB)
4U5T-14G422-BDM_1748465073000.TAR.GZ (2,1GB)
1U5T-14G424-BP_1748959609000.TAR.GZ (1,7KB)
[21.07.2026 12:10:43] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: F13 (2024) - EU (09 2025)
[21.07.2026 12:10:43] Install Mode: Auto-Wykrywanie (reformat) Forced: False
[21.07.2026 12:10:43] MY20 Protection: Auto-Wykrywanie
[21.07.2026 12:10:43] Formatting USB drive
[21.07.2026 12:10:43] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[21.07.2026 12:10:51] Checking Existing File: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:10:51] Downloading: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:10:56] Validating: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:10:56] Downloaded: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:10:56] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:10:56] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:10:57] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:10:57] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:10:57] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:10:57] Downloading: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:11:19] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:11:23] Downloaded: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:11:23] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:11:23] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:11:33] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:11:35] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:11:35] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:11:35] Downloading: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:11:36] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:11:36] Downloaded: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:11:36] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:11:36] Downloading: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:11:49] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:11:51] Downloaded: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:11:51] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:11:51] Downloading: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:12:35] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:12:41] Downloaded: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:12:41] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:12:41] Downloading: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:12:49] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:12:51] Downloaded: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:12:51] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:12:51] Downloading: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:13:16] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:13:20] Downloaded: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:13:20] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:13:20] Downloading: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:13:37] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:13:40] Downloaded: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:13:40] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:13:40] Downloading: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:14:05] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:14:10] Downloaded: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:14:10] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:14:10] Downloading: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:14:46] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:14:52] Downloaded: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:14:52] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:14:52] Downloading: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:15:23] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:15:28] Downloaded: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:15:28] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:15:28] Downloading: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:16:36] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:16:42] Downloaded: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:16:42] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:16:42] Downloading: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:16:44] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:16:44] Downloaded: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:16:44] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:16:44] Downloading: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:17:17] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:17:23] Downloaded: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:17:23] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:17:23] Downloading: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:17:57] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:18:03] Downloaded: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:18:03] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:18:03] Downloading: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:18:32] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:18:37] Downloaded: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:18:37] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 12:18:37] Downloading: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 12:19:10] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 12:19:16] Downloaded: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 12:19:16] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 12:19:16] Downloading: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 12:19:16] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 12:19:16] Downloaded: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 12:19:16] Preparing USB drive
[21.07.2026 12:19:16] Checking Existing File: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:19:16] Copying: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:19:16] Validating: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:19:16] Copied: 1u5t-14g386-cb.tar.gz
[21.07.2026 12:19:16] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:19:16] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:19:16] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:19:16] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[21.07.2026 12:19:16] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:19:16] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:21:25] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:21:44] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[21.07.2026 12:21:44] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:21:44] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:22:39] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:22:47] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[21.07.2026 12:22:47] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:22:47] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:22:52] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:22:52] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[21.07.2026 12:22:52] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:22:52] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:24:01] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:24:12] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[21.07.2026 12:24:12] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:24:12] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:27:35] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:28:06] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[21.07.2026 12:28:06] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:28:06] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:28:49] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:28:55] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[21.07.2026 12:28:55] Checking Existing File: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:28:55] Copying: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:31:20] Validating: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:31:42] Copied: 1U5T-14G421-BCM_1748460093000.TAR.GZ
[21.07.2026 12:31:42] Checking Existing File: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:31:42] Copying: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:33:14] Validating: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:33:28] Copied: 1U5T-14G421-BDM_1748460770000.TAR.GZ
[21.07.2026 12:33:28] Checking Existing File: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:33:28] Copying: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:35:54] Validating: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:36:16] Copied: 1U5T-14G421-BEM_1748461035000.TAR.GZ
[21.07.2026 12:36:16] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:36:16] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:39:47] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:40:19] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[21.07.2026 12:40:19] Checking Existing File: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:40:19] Copying: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:43:11] Validating: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:43:37] Copied: 1U5T-14G421-BGM_1748462187000.TAR.GZ
[21.07.2026 12:43:37] Checking Existing File: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:43:37] Copying: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:47:14] Validating: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:47:47] Copied: 1U5T-14G421-BHM_1748462644000.TAR.GZ
[21.07.2026 12:47:47] Checking Existing File: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:47:47] Copying: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:47:50] Validating: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:47:50] Copied: 1U5T-14G421-BJM_1748462970000.TAR.GZ
[21.07.2026 12:47:50] Checking Existing File: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:47:50] Copying: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:51:12] Validating: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:51:43] Copied: 4U5T-14G422-BAM_1748464396000.TAR.GZ
[21.07.2026 12:51:43] Checking Existing File: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:51:43] Copying: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:54:55] Validating: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:55:25] Copied: 4U5T-14G422-BBM_1748464677000.TAR.GZ
[21.07.2026 12:55:25] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:55:25] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:57:49] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:58:11] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[21.07.2026 12:58:11] Checking Existing File: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 12:58:11] Copying: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 13:01:04] Validating: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 13:01:31] Copied: 4U5T-14G422-BDM_1748465073000.TAR.GZ
[21.07.2026 13:01:31] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 13:01:31] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 13:01:31] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 13:01:31] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[21.07.2026 13:01:31] Generating reformat.lst
[21.07.2026 13:01:32] Generating autoinstall.lst
[21.07.2026 13:01:32] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
LOG 2 ---- PASSED UPDATE WITH ONLY 3.0 -> 3.4 WITHOUT NAVI FILES
Version: 3.0.19205
FILES (7)
[22.07.2026 21:21:19] Selected Region: EU - Release: Sync 3.4.26057 - Map Version: F13 (2024) - EU (09 2025)
[22.07.2026 21:21:19] Install Mode: Auto-Wykrywanie (reformat) Forced: False
[22.07.2026 21:21:19] MY20 Protection: Auto-Wykrywanie
[22.07.2026 21:21:19] Formatting USB drive
[22.07.2026 21:21:19] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[22.07.2026 21:21:27] Checking Existing File: 1u5t-14g386-cb.tar.gz
[22.07.2026 21:21:27] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[22.07.2026 21:21:27] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.07.2026 21:21:27] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:27] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[22.07.2026 21:21:30] Validated: 5U5T-14G391-AT_1660763323000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:30] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22.07.2026 21:21:32] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:32] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[22.07.2026 21:21:32] Validated: 1U5T-14G658-AH_1644006443000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:32] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[22.07.2026 21:21:34] Validated: NU5T-14G381-AE_1778770590000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:34] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.07.2026 21:21:34] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[22.07.2026 21:21:34] Preparing USB drive
[22.07.2026 21:21:34] Checking Existing File: 1u5t-14g386-cb.tar.gz
[22.07.2026 21:21:34] Copying: 1u5t-14g386-cb.tar.gz
[22.07.2026 21:21:35] Validating: 1u5t-14g386-cb.tar.gz
[22.07.2026 21:21:35] Copied: 1u5t-14g386-cb.tar.gz
[22.07.2026 21:21:35] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.07.2026 21:21:35] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.07.2026 21:21:35] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.07.2026 21:21:35] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[22.07.2026 21:21:35] Checking Existing File: 5U5T-14G391-AT_1660763323000.TAR.GZ
[22.07.2026 21:21:35] Copying: 5U5T-14G391-AT_1660763323000.TAR.GZ
[22.07.2026 21:23:38] Validating: 5U5T-14G391-AT_1660763323000.TAR.GZ
[22.07.2026 21:23:42] Copied: 5U5T-14G391-AT_1660763323000.TAR.GZ
[22.07.2026 21:23:42] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22.07.2026 21:23:42] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22.07.2026 21:24:36] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22.07.2026 21:24:37] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[22.07.2026 21:24:37] Checking Existing File: 1U5T-14G658-AH_1644006443000.TAR.GZ
[22.07.2026 21:24:37] Copying: 1U5T-14G658-AH_1644006443000.TAR.GZ
[22.07.2026 21:24:42] Validating: 1U5T-14G658-AH_1644006443000.TAR.GZ
[22.07.2026 21:24:42] Copied: 1U5T-14G658-AH_1644006443000.TAR.GZ
[22.07.2026 21:24:42] Checking Existing File: NU5T-14G381-AE_1778770590000.TAR.GZ
[22.07.2026 21:24:42] Copying: NU5T-14G381-AE_1778770590000.TAR.GZ
[22.07.2026 21:25:50] Validating: NU5T-14G381-AE_1778770590000.TAR.GZ
[22.07.2026 21:25:52] Copied: NU5T-14G381-AE_1778770590000.TAR.GZ
[22.07.2026 21:25:52] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.07.2026 21:25:52] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.07.2026 21:25:52] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.07.2026 21:25:52] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[22.07.2026 21:25:52] Generating reformat.lst
[22.07.2026 21:25:52] Generating autoinstall.lst
[22.07.2026 21:25:52] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
------- LOG 3 ONLY UPDATE MAPS FILES AND SELECTED VOICE / MAP FILES WITH ACTUAL WORKING SYNC 3.4 (NOT DONE YET)
Version: 3.4.26057
; CyanLabs Syn3Updater 2.14.2.0 Stable - Autoinstall Mode - Only Update Maps EU
[SYNCGen3.0_3.0.1_PRODUCT]
Item2 = MAP_LICENSE - 1U5T-14G424-BP_1748959609000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G424-BP_1748959609000.TAR.GZ
Item3 = MAP - 1U5T-14G421-BFM_1748461472000.TAR.GZ
Open3 = SyncMyRide\1U5T-14G421-BFM_1748461472000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 1U5T-14G421-BAM_1748461682000.TAR.GZ
Open1 = SyncMyRide\1U5T-14G421-BAM_1748461682000.TAR.GZ
Item1 = VOICE_NAV - 4U5T-14G422-BCM_1748464896000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BCM_1748464896000.TAR.GZ
Item2 = MAP - 1U5T-14G421-BBM_1748459859000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G421-BBM_1748459859000.TAR.GZ
FILES (6)
[24.07.2026 00:10:03] Selected Region: EU - Release: Only Update Maps - Map Version: F13 (2024) - EU (09 2025)
[24.07.2026 00:10:03] Install Mode: Auto-Detect (autoinstall) Forced: False
[24.07.2026 00:10:03] MY20 Protection: Auto-Detect
[24.07.2026 00:10:03] Formatting USB drive
[24.07.2026 00:10:03] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[24.07.2026 00:10:11] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[24.07.2026 00:10:11] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:11] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[24.07.2026 00:10:17] Validated: 1U5T-14G421-BAM_1748461682000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:17] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[24.07.2026 00:10:18] Validated: 1U5T-14G421-BBM_1748459859000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:18] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[24.07.2026 00:10:24] Validated: 1U5T-14G421-BFM_1748461472000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:24] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[24.07.2026 00:10:28] Validated: 4U5T-14G422-BCM_1748464896000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:28] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[24.07.2026 00:10:28] Validated: 1U5T-14G424-BP_1748959609000.TAR.GZ (Skipping Download)
[24.07.2026 00:10:28] Preparing USB drive
[24.07.2026 00:10:29] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[24.07.2026 00:10:29] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[24.07.2026 00:10:29] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[24.07.2026 00:10:29] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[24.07.2026 00:10:29] Checking Existing File: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[24.07.2026 00:10:29] Copying: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[24.07.2026 00:13:44] Validating: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[24.07.2026 00:13:50] Copied: 1U5T-14G421-BAM_1748461682000.TAR.GZ
[24.07.2026 00:13:50] Checking Existing File: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[24.07.2026 00:13:50] Copying: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[24.07.2026 00:14:32] Validating: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[24.07.2026 00:14:33] Copied: 1U5T-14G421-BBM_1748459859000.TAR.GZ
[24.07.2026 00:14:33] Checking Existing File: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[24.07.2026 00:14:33] Copying: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[24.07.2026 00:17:58] Validating: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[24.07.2026 00:18:04] Copied: 1U5T-14G421-BFM_1748461472000.TAR.GZ
[24.07.2026 00:18:04] Checking Existing File: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[24.07.2026 00:18:04] Copying: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[24.07.2026 00:20:26] Validating: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[24.07.2026 00:20:30] Copied: 4U5T-14G422-BCM_1748464896000.TAR.GZ
[24.07.2026 00:20:30] Checking Existing File: 1U5T-14G424-BP_1748959609000.TAR.GZ
[24.07.2026 00:20:30] Copying: 1U5T-14G424-BP_1748959609000.TAR.GZ
[24.07.2026 00:20:30] Validating: 1U5T-14G424-BP_1748959609000.TAR.GZ
[24.07.2026 00:20:30] Copied: 1U5T-14G424-BP_1748959609000.TAR.GZ
[24.07.2026 00:20:30] Generating Autoinstall.lst
[24.07.2026 00:20:30] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Did you perform a master reset after the upload to the car…if not try that before doing anything else.
Yes, I did.
I performed a Master Reset before starting the updates, and I also performed another Master Reset after the updates were completed. Unfortunately, it didn’t make any difference—the navigation issue is still there, and the Navigation Version field is still blank.
Change the partition type to MBR
