I currently have SYNC 3, Software Version: 2.0 Build 16074 which was not in the drop down menu. I typed it in manually and after the download was complete I got this message. How do I resolve this problem to update to 3.4?
Old SYNC Version: 3.2.16074
New SYNC Version: 3.4.26057
Notice
The Download and Copying of all required files is now complete.
Simply eject the USB from your computer insert it in to your car.
Turn the engine on, and wait for the install process to begin!
Syn3Updater will now open you directly to the documentation relevant to the InstallMode Syn3Updater used.
if you have found Syn3 Updater useful considering donating at https:// Support Us - CyanLabs
Please note Syn3 Updater no longer updates your Current Version in the configuration so make sure to update this manually once you verify SYNC 3 has updated correctly
If you are having issues join our discord or community forum. links can be found
in the About tao and on our website.
You cannot go directly to 3.4 from 3.0 as Ford does not support 3.4 being installed on your vehicle (think of this as being a PC running Win7 and you’re trying to install Win11).
The only option to get to 3.4 is to reformat the APIM and should you have issues with 3.4 you cannot revert to 3.0 without replacing the APIM with one that has 3.0 on it.
I had 2017 focus with 2.2 or so. 1st i downloaded update from Ford page and it updated it to 3.0 ( latest what ford gave)and then i went to 3.4 downloaded from cyanlabs.
Because Ford released it, with this logic why have any old build available either, archival purposes.
Also, the “Does not update current version” simply means that once you have updated, make sure you go back in the Syn3 Updater configuration and set your “new current version”
The updater has the builds Ford has out on their cloud (which is where the updater downloads from) and Ford doesn’t provide a change log or model/year/brand supported list for a build.
The highest Ford supported build for your VIN is always on owner.ford.com .
Right now for quite a few MY2020+ vehicles it shows .26057 as available, but the link provided actually still downloads .23188.
Using the updater to update the Sync version isn’t a Ford supported method, just like using ForScan to do anything isn’t supported by Ford.
