Updating Module Firmware with FORScan, Program Guide Revised 09/2021
Revised Sep 05, 2021
Link to Programming Guide
If you are using FORScan to program firmware and you have not read the Program Guide completely, you should do so. You should understand the systems you are affecting and the proper procedures for firmware programming… From the FORScan team:
Please read the Program Guide before using it, it’s a requirement. Please remember you use it at your own risk. Support and Development teams may not be able to assist you quickly in recovery due to high load and limited resources.
You must obtain a paid license to use the FORScan 2.4.x software.
Standard and Extended licenses for Windows, version 2
